Multi-channel transmission/reception using pyadi-iio
Product Number: Jupiter SDR
Software Version: Stock Jupiter SDR software + pyadi-iio (0.0.19) + pylibiio (0.25)
Hi!
Jupiter SDR platform has to tx/rx ports, and several examples on how to use one of the two. An example can be found here (github.com/.../adrv9002_example.py), where two rx-channels are configured, but only one is actually used.  Example script is attached here, but where amount of data received from rx2 is only 1024 samples, not sdr.rx_buffer_size.
import time
import adi
import matplotlib.pyplot as plt
import numpy as np
from scipy import signal
sdr = adi.adrv9002(uri="ip:<>")
print(sdr._num_rx_channels_enabled)
sdr.rx0_en = 1
sdr.rx1_en = 1
sdr.rx_ensm_mode_chan0 = "rf_enabled"
sdr.rx_ensm_mode_chan1 = "rf_enabled"
print(sdr.rx0_sample_rate)
print(sdr.rx1_sample_rate)
sdr.rx_buffer_size = 2 ** 18
print(sdr.rx_buffer_size)
# Collect data
x = sdr.rx1()
print(x.shape)
x2 = sdr.rx2()
print(x2.shape)
Rx0/1 sample rates are identical, and sdr._num_rx_channels_enabled is always 1. What is wrong/missing in this script?
Henning
Thread Notes
