FMCW_RADAR_Waterfall_ChirpSync.py Issue
Please I got the error below when i run the FMCW_RADAR_Waterfall_ChirpSync.py  file. Can you assist please
0.0.20
file not found, loading default (all gain at maximum)
file not found, loading default (no phase shift)
requested freq dev time = 500
actual freq dev time = 500
fft_size = 8192
Total Time for all Chirps: 1.5 ms
buffer_size: 8192
buffer_time: 1.6384003276800656 ms
CONFIG:
Sample rate: 4.999999MHz
Num samples: 2^13
Bandwidth: 500.0MHz
Ramp time: 0.5ms
Output frequency: 10000.0MHz
IF: 100.0kHz
Traceback (most recent call last):
File "<string>", line 464, in update
File "/usr/local/lib/python3.9/dist-packages/adi/rx_tx.py", line 275, in rx
data = self.__rx_complex()
File "/usr/local/lib/python3.9/dist-packages/adi/rx_tx.py", line 240, in __rx_complex
x = self._rx_buffered_data()
File "/usr/local/lib/python3.9/dist-packages/adi/compat.py", line 148, in _rx_buffered_data
self._rxbuf.refill()
File "/usr/local/lib/python3.9/dist-packages/iio.py", line 1003, in refill
_buffer_refill(self._buffer)
File "/usr/local/lib/python3.9/dist-packages/iio.py", line 62, in _check_negative
raise OSError(-result, _strerror(-result))
TimeoutError: [Errno 110] Connection timed out
Program finished and Pluto Tx Buffer Cleared
Process ended with exit code 0.
Python 3.9.2 (/usr/bin/python3)
Thread Notes
