I'm trying to run the software for the AD5259 evaluation board, but when I try to run it I get an error that says the VI is not executable, and that a full installation of labview is required to fix the problem.
A little research indicates that the problem stems from the fact that my system is funning .net framework 4.0, not 3.5. However, when I try to activate 3.5 my computer just hangs. I've tried everything that Microsoft's support has suggested, including running the dotnet installer directly, but have had no luck.
Is there any other way to get the evaluation software running on a windows 11 machine?
