I followed this link to install IIO-Oscilloscope on Ubuntu 18.04
https://wiki.analog.com/resources/tools-software/linux-software/iio_oscilloscope
In step 3, build and install the libad9166-iio and libad9361-iio libraries, by following:
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms5-ebz/multi-chip-sync#linux
But after "make", I got this error: I don't know where I am wrong:
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~/libad9361-iio$ sudo make install
[ 52%] Built target ad9361
[ 57%] Linking C executable FilterDesignerTest
../libad9361.so.0.2: undefined reference to `iio_device_attr_write'
../libad9361.so.0.2: undefined reference to `iio_channel_attr_write'
../libad9361.so.0.2: undefined reference to `iio_buffer_end'
../libad9361.so.0.2: undefined reference to `iio_device_attr_read'
../libad9361.so.0.2: undefined reference to `iio_buffer_first'
../libad9361.so.0.2: undefined reference to `iio_buffer_refill'
../libad9361.so.0.2: undefined reference to `iio_buffer_step'
collect2: error: ld returned 1 exit status
test/CMakeFiles/FilterDesignerTest.dir/build.make:98: recipe for target 'test/FilterDesignerTest' failed
make[2]: *** [test/FilterDesignerTest] Error 1
CMakeFiles/Makefile2:178: recipe for target 'test/CMakeFiles/FilterDesignerTest.dir/all' failed
make[1]: *** [test/CMakeFiles/FilterDesignerTest.dir/all] Error 2
Makefile:165: recipe for target 'all' failed
make: *** [all] Error 2
Any one can help please!
Thank you very much
Did you do step 2? The error points to libiio missing. Has that been installed?
-Travis
Yes, It was installed without errors.
pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~$ sudo apt-get install libxml2 libxml2-dev bison flex libcdk5-dev cmake
Reading package lists... Done
Building dependency tree
Reading state information... Done
bison is already the newest version (2:3.0.4.dfsg-1build1).
flex is already the newest version (2.6.4-6).
libcdk5-dev is already the newest version (5.0.20161210-5).
cmake is already the newest version (3.10.2-1ubuntu2.18.04.2).
libxml2 is already the newest version (2.9.4+dfsg1-6.1ubuntu1.9).
libxml2-dev is already the newest version (2.9.4+dfsg1-6.1ubuntu1.9).
The following packages were automatically installed and are no longer required:
gir1.2-goa-1.0 gir1.2-snapd-1
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~$ sudo apt-get install libaio-dev libusb-1.0-0-dev libserialport-dev libxml2-dev libavahi-client-dev doxyge
E: Unable to locate package doxyge
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~$ git clone github.com/.../libiio.git
Cloning into 'libiio'...
remote: Enumerating objects: 18699, done.
remote: Counting objects: 100% (1655/1655), done.
remote: Compressing objects: 100% (707/707), done.
remote: Total 18699 (delta 1038), reused 1360 (delta 881), pack-reused 17044
Receiving objects: 100% (18699/18699), 17.48 MiB | 2.75 MiB/s, done.
Resolving deltas: 100% (12467/12467), done.
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~$ cd libiio/
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~/libiio$ mkdir build && cd build && cmake ../ && make && sudo make install
-- cmake version: 3.28.0-rc1
-- The C compiler identification is GNU 7.5.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Performing Test HAS_WPEDANTIC
-- Performing Test HAS_WPEDANTIC - Success
-- Performing Test HAS_WSHADOW
-- Performing Test HAS_WSHADOW - Success
-- Looking for strdup
-- Looking for strdup - found
-- Looking for strndup
-- Looking for strndup - found
-- Looking for strerror_r
-- Looking for strerror_r - found
-- Looking for strtok_r
-- Looking for strtok_r - found
-- Looking for newlocale
-- Looking for newlocale - found
-- Looking for in6addr_any
-- Looking for in6addr_any - found
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for module 'libusb-1.0'
-- Found libusb-1.0, version 1.0.21
-- Looking for libusb_get_version
-- Looking for libusb_get_version - found
-- Found Git: /usr/bin/git (found version "2.17.1")
-- Performing Test WITH_NETWORK_EVENTFD
-- Performing Test WITH_NETWORK_EVENTFD - Success
-- Found LibXml2: /usr/lib/x86_64-linux-gnu/libxml2.so (found version "2.9.4")
-- Found BISON: /usr/bin/bison (found version "3.0.4")
-- Found FLEX: /usr/bin/flex (found version "2.6.4")
-- Looking for pthread_setname_np
-- Looking for pthread_setname_np - found
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of struct usb_functionfs_descs_head_v2
-- Check size of struct usb_functionfs_descs_head_v2 - done
-- Features enabled : xml zstd network dns-sd avahi ipv6 local local-dmabuf local-mmap hwmon usb utils iiod udev-rule iiod-serial iiod-aio iiod-usb man-utils
-- Features disabled: bonjour serial examples modules usb-dynamic network-dynamic serial-dynamic iiod-systemd iiod-sysvinit iiod-upstart doc man python-bindings c#-bindings c++-bindings
-- LOG_LEVEL set to "Info"
-- Configuring done (1.2s)
-- Generating done (0.0s)
-- Build files have been written to: /home/pc/libiio/build
[ 1%] Building C object CMakeFiles/iiod-responder.dir/iiod-responder.c.o
[ 3%] Linking C static library libiiod-responder.a
[ 3%] Built target iiod-responder
[ 5%] Building C object CMakeFiles/iio.dir/backend.c.o
[ 7%] Building C object CMakeFiles/iio.dir/block.c.o
[ 8%] Building C object CMakeFiles/iio.dir/channel.c.o
[ 10%] Building C object CMakeFiles/iio.dir/device.c.o
[ 12%] Building C object CMakeFiles/iio.dir/context.c.o
[ 14%] Building C object CMakeFiles/iio.dir/buffer.c.o
[ 15%] Building C object CMakeFiles/iio.dir/mask.c.o
[ 17%] Building C object CMakeFiles/iio.dir/utilities.c.o
[ 19%] Building C object CMakeFiles/iio.dir/scan.c.o
[ 21%] Building C object CMakeFiles/iio.dir/sort.c.o
[ 22%] Building C object CMakeFiles/iio.dir/task.c.o
[ 24%] Building C object CMakeFiles/iio.dir/stream.c.o
[ 26%] Building C object CMakeFiles/iio.dir/usb.c.o
[ 28%] Building C object CMakeFiles/iio.dir/local.c.o
[ 29%] Building C object CMakeFiles/iio.dir/deps/libini/libini.c.o
[ 31%] Building C object CMakeFiles/iio.dir/local-dmabuf.c.o
[ 33%] Building C object CMakeFiles/iio.dir/local-mmap.c.o
[ 35%] Building C object CMakeFiles/iio.dir/network.c.o
[ 36%] Building C object CMakeFiles/iio.dir/network-unix.c.o
[ 38%] Building C object CMakeFiles/iio.dir/dns_sd.c.o
[ 40%] Building C object CMakeFiles/iio.dir/dns_sd_avahi.c.o
[ 42%] Building C object CMakeFiles/iio.dir/xml.c.o
[ 43%] Building C object CMakeFiles/iio.dir/lock.c.o
[ 45%] Building C object CMakeFiles/iio.dir/iiod-client.c.o
[ 47%] Linking C shared library libiio.so
[ 47%] Built target iio
[ 49%] Building C object CMakeFiles/iio-compat.dir/compat.c.o
[ 50%] Building C object CMakeFiles/iio-compat.dir/dynamic-unix.c.o
[ 52%] Linking C shared library libiio.so.0
[ 52%] Built target iio-compat
[ 54%] Building C object utils/CMakeFiles/iio_tests_helper.dir/iio_common.c.o
[ 56%] Building C object utils/CMakeFiles/iio_tests_helper.dir/gen_code.c.o
[ 57%] Linking C static library libiio_tests_helper.a
[ 57%] Built target iio_tests_helper
[ 59%] Building C object utils/CMakeFiles/iio_genxml.dir/iio_genxml.c.o
[ 61%] Linking C executable iio_genxml
[ 61%] Built target iio_genxml
[ 63%] Building C object utils/CMakeFiles/iio_info.dir/iio_info.c.o
[ 64%] Linking C executable iio_info
[ 64%] Built target iio_info
[ 66%] Building C object utils/CMakeFiles/iio_attr.dir/iio_attr.c.o
[ 68%] Linking C executable iio_attr
[ 68%] Built target iio_attr
[ 70%] Building C object utils/CMakeFiles/iio_rwdev.dir/iio_rwdev.c.o
[ 71%] Linking C executable iio_rwdev
[ 71%] Built target iio_rwdev
[ 73%] Building C object utils/CMakeFiles/iio_reg.dir/iio_reg.c.o
[ 75%] Linking C executable iio_reg
[ 75%] Built target iio_reg
[ 77%] Building C object utils/CMakeFiles/iio_stresstest.dir/iio_stresstest.c.o
[ 78%] Linking C executable iio_stresstest
[ 78%] Built target iio_stresstest
[ 80%] [BISON][parser] Building parser with bison 3.0.4
[ 82%] [FLEX][lexer] Building scanner with flex 2.6.4
[ 84%] Building C object iiod/CMakeFiles/iiod.dir/iiod.c.o
[ 85%] Building C object iiod/CMakeFiles/iiod.dir/ops.c.o
[ 87%] Building C object iiod/CMakeFiles/iiod.dir/responder.c.o
[ 89%] Building C object iiod/CMakeFiles/iiod.dir/thread-pool.c.o
[ 91%] Building C object iiod/CMakeFiles/iiod.dir/parser.c.o
[ 92%] Building C object iiod/CMakeFiles/iiod.dir/lexer.c.o
[ 94%] Building C object iiod/CMakeFiles/iiod.dir/usbd.c.o
[ 96%] Building C object iiod/CMakeFiles/iiod.dir/serial.c.o
[ 98%] Building C object iiod/CMakeFiles/iiod.dir/dns-sd.c.o
[100%] Linking C executable iiod
[100%] Built target iiod
Install the project...
-- Install configuration: "RelWithDebInfo"
-- Installing: /usr/lib/x86_64-linux-gnu/pkgconfig/libiio.pc
-- Installing: /usr/lib/x86_64-linux-gnu/libiio.so.1.0
-- Up-to-date: /usr/lib/x86_64-linux-gnu/libiio.so.1
-- Installing: /usr/include/iio/iio.h
-- Installing: /usr/include/iio/iio-debug.h
-- Installing: /usr/include/iio/iio-lock.h
-- Installing: /usr/include/iio/iiod-client.h
-- Installing: /usr/lib/x86_64-linux-gnu/libiio.so.0
-- Installing: /usr/bin/iio_genxml
-- Installing: /usr/bin/iio_info
-- Installing: /usr/bin/iio_attr
-- Installing: /usr/bin/iio_rwdev
-- Installing: /usr/bin/iio_reg
-- Installing: /usr/bin/iio_stresstest
-- Installing: /lib/udev/rules.d/90-libiio.rules
-- Installing: /usr/sbin/iiod
-- Set non-toolchain portion of runtime path of "/usr/sbin/iiod" to ""
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~/libiio/build$ cd ..
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~/libiio$ PATH=/usr/lib/:$PATH
Which branch of libiio are you building?
Could you try using this branch, instead ? https://github.com/analogdevicesinc/libiio/tree/libiio-v0
The main branch of libiio will not work with IIO-Oscilloscope.
Let us know if this fixes your issue.
--Cristina
Moved inquiry to software interface tools.
I used main branch of libiio
With the branch that you have just sent me, everything is ok now
I have install ibad9166-iio and libad9361-iio libraries without errors.
I used the branch 2021_R2 to install iio-oscilloscope
(base) pc@pc-HP-ZBook-15v-G5:~$ git clone github.com/.../iio-oscilloscope.git --branch 2021_R2
Cloning into 'iio-oscilloscope'...
remote: Enumerating objects: 12011, done.
remote: Counting objects: 100% (444/444), done.
remote: Compressing objects: 100% (214/214), done.
remote: Total 12011 (delta 268), reused 331 (delta 209), pack-reused 11567
Receiving objects: 100% (12011/12011), 168.73 MiB | 4.09 MiB/s, done.
Resolving deltas: 100% (8672/8672), done.
(base) pc@pc-HP-ZBook-15v-G5:~$ cd iio-oscilloscope
(base) pc@pc-HP-ZBook-15v-G5:~/iio-oscilloscope$ git checkout origin/master
Note: checking out 'origin/master'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at 584eccc oscplot: ensure channels dispalyed in save dialog are all inputs
(base) pc@pc-HP-ZBook-15v-G5:~/iio-oscilloscope$ mkdir build && cd build
(base) pc@pc-HP-ZBook-15v-G5:~/iio-oscilloscope/build$ cmake ../ && make -j $(nproc)
-- Checking for module 'glib-2.0'
-- Found glib-2.0, version 2.56.4
-- Checking for module 'gtk+-3.0'
-- Found gtk+-3.0, version 3.22.30
-- Checking for module 'gthread-2.0'
-- Found gthread-2.0, version 2.56.4
-- Checking for module 'gtkdatabox'
-- Found gtkdatabox, version 1.0.0
-- Checking for module 'fftw3'
-- Found fftw3, version 3.3.7
-- Checking for module 'libxml-2.0'
-- Found libxml-2.0, version 2.9.4
-- Checking for module 'libcurl'
-- Found libcurl, version 7.58.0
-- Checking for module 'jansson'
-- Found jansson, version 2.11
-- Checking for module 'matio'
-- Found matio, version 1.5.11
-- Configuring done (0.5s)
-- Generating done (0.1s)
-- Build files have been written to: /home/pc/iio-oscilloscope/build
[ 2%] Building C object CMakeFiles/osc.dir/oscplot.c.o
[ 2%] Building C object CMakeFiles/osc.dir/osc.c.o
[ 4%] Building C object CMakeFiles/osc.dir/iio_widget.c.o
[ 4%] Building C object CMakeFiles/osc.dir/datatypes.c.o
[ 6%] Building C object CMakeFiles/osc.dir/iio_utils.c.o
[ 8%] Building C object CMakeFiles/osc.dir/fru.c.o
[ 8%] Building C object CMakeFiles/osc.dir/dialogs.c.o
[ 9%] Building C object CMakeFiles/osc.dir/trigger_dialog.c.o
[ 10%] Building C object CMakeFiles/osc.dir/xml_utils.c.o
[ 12%] Building C object CMakeFiles/osc.dir/libini/libini.c.o
[ 13%] Building C object CMakeFiles/osc.dir/libini2.c.o
[ 14%] Building C object CMakeFiles/osc.dir/phone_home.c.o
[ 15%] Building C object CMakeFiles/osc.dir/plugins/dac_data_manager.c.o
[ 16%] Building C object CMakeFiles/osc.dir/plugins/fir_filter.c.o
[ 18%] Building C object CMakeFiles/osc.dir/eeprom.c.o
[ 19%] Building C object CMakeFiles/osc.dir/osc_preferences.c.o
[ 20%] Linking C shared library libosc.so
[ 20%] Built target osc
[ 22%] Building C object plugins/CMakeFiles/fmcomms2.dir/fmcomms2.c.o
[ 22%] Building C object plugins/CMakeFiles/generic_dac.dir/generic_dac.c.o
[ 25%] Building C object plugins/CMakeFiles/fmcomms1.dir/fmcomms1.c.o
[ 25%] Building C object plugins/CMakeFiles/fmcomms6.dir/fmcomms6.c.o
[ 26%] Building C object plugins/CMakeFiles/fmcomms2_adv.dir/fmcomms2_adv.c.o
[ 27%] Building C object plugins/CMakeFiles/fmcomms5.dir/fmcomms5.c.o
[ 28%] Building C object CMakeFiles/oscmain.dir/oscmain.c.o
[ 30%] Building C object plugins/CMakeFiles/fmcomms11.dir/fmcomms11.c.o
[ 31%] Linking C shared library generic_dac.so
[ 32%] Linking C shared library fmcomms6.so
[ 33%] Linking C executable osc
[ 34%] Linking C shared library fmcomms11.so
[ 34%] Built target generic_dac
[ 36%] Building C object plugins/CMakeFiles/ad9371.dir/ad9371.c.o
[ 36%] Built target fmcomms6
[ 37%] Building C object plugins/CMakeFiles/ad9371_adv.dir/ad9371_adv.c.o
[ 37%] Built target fmcomms11
[ 38%] Building C object plugins/CMakeFiles/adrv9009.dir/adrv9009.c.o
[ 39%] Linking C shared library fmcomms2_adv.so
[ 39%] Built target fmcomms2_adv
[ 40%] Building C object plugins/CMakeFiles/adrv9009_adv.dir/adrv9009_adv.c.o
[ 40%] Built target oscmain
[ 42%] Building C object plugins/CMakeFiles/ad6676.dir/ad6676.c.o
[ 43%] Linking C shared library fmcomms5.so
[ 44%] Linking C shared library ad9371_adv.so
[ 44%] Built target fmcomms5
[ 45%] Building C object plugins/CMakeFiles/fmcadc3.dir/fmcadc3.c.o
[ 46%] Linking C shared library fmcomms2.so
[ 48%] Linking C shared library fmcomms1.so
[ 48%] Built target ad9371_adv
[ 49%] Building C object plugins/CMakeFiles/daq2.dir/daq2.c.o
[ 50%] Linking C shared library adrv9009_adv.so
[ 51%] Linking C shared library ad6676.so
[ 51%] Built target fmcomms2
[ 53%] Building C object plugins/CMakeFiles/ad9739a.dir/ad9739a.c.o
[ 53%] Built target fmcomms1
[ 54%] Building C object plugins/CMakeFiles/AD5628_1.dir/AD5628_1.c.o
[ 54%] Built target adrv9009_adv
[ 55%] Building C object plugins/CMakeFiles/cn0357.dir/cn0357.c.o
[ 55%] Built target ad6676
[ 56%] Building C object plugins/CMakeFiles/cn0508.dir/cn0508.c.o
[ 57%] Linking C shared library fmcadc3.so
[ 59%] Linking C shared library ad9371.so
[ 59%] Built target fmcadc3
[ 60%] Building C object plugins/CMakeFiles/cn0511.dir/cn0511.c.o
[ 61%] Linking C shared library adrv9009.so
[ 62%] Linking C shared library daq2.so
[ 62%] Built target ad9371
[ 63%] Building C object plugins/CMakeFiles/cn0540.dir/cn0540.c.o
[ 65%] Linking C shared library AD5628_1.so
[ 66%] Linking C shared library ad9739a.so
[ 66%] Built target adrv9009
[ 67%] Building C object plugins/CMakeFiles/pr_config.dir/pr_config.c.o
[ 67%] Built target daq2
[ 67%] Built target AD5628_1
[ 68%] Building C object plugins/CMakeFiles/motor_control.dir/motor_control.c.o
[ 69%] Building C object plugins/CMakeFiles/lidar.dir/lidar.c.o
[ 69%] Built target ad9739a
[ 71%] Building C object plugins/CMakeFiles/dmm.dir/dmm.c.o
[ 72%] Linking C shared library cn0357.so
[ 73%] Linking C shared library cn0508.so
[ 74%] Linking C shared library cn0511.so
[ 74%] Built target cn0357
[ 74%] Built target cn0508
[ 75%] Building C object plugins/CMakeFiles/debug.dir/debug.c.o
[ 77%] Building C object plugins/CMakeFiles/spectrum_analyzer.dir/spectrum_analyzer.c.o
[ 77%] Built target cn0511
[ 78%] Building C object plugins/CMakeFiles/scpi.dir/scpi.c.o
[ 79%] Linking C shared library pr_config.so
[ 80%] Linking C shared library cn0540.so
[ 81%] Linking C shared library lidar.so
[ 81%] Built target pr_config
[ 83%] Building C object plugins/CMakeFiles/ad9081.dir/ad9081.c.o
[ 84%] Linking C shared library dmm.so
[ 84%] Built target cn0540
[ 84%] Built target lidar
[ 85%] Building C object plugins/CMakeFiles/ad9084.dir/ad9084.c.o
[ 86%] Building C object plugins/CMakeFiles/adrv9002.dir/adrv9002.c.o
[ 86%] Built target dmm
[ 87%] Building C object plugins/CMakeFiles/cf_axi_tdd.dir/cf_axi_tdd.c.o
[ 89%] Linking C shared library spectrum_analyzer.so
[ 90%] Linking C shared library motor_control.so
[ 90%] Built target spectrum_analyzer
[ 91%] Building C object plugins/CMakeFiles/xmw.dir/xmw.c.o
[ 91%] Built target motor_control
[ 92%] Linking C shared library scpi.so
[ 92%] Built target scpi
[ 93%] Linking C shared library cf_axi_tdd.so
[ 95%] Linking C shared library ad9081.so
[ 96%] Linking C shared library debug.so
[ 97%] Linking C shared library ad9084.so
[ 97%] Built target cf_axi_tdd
[ 97%] Built target ad9081
[ 97%] Built target ad9084
[ 97%] Built target debug
[ 98%] Linking C shared library xmw.so
[ 98%] Built target xmw
[100%] Linking C shared library adrv9002.so
[100%] Built target adrv9002
(base) pc@pc-HP-ZBook-15v-G5:~/iio-oscilloscope/build$ sudo make install
[ 22%] Built target oscmain
[ 25%] Built target generic_dac
[ 27%] Built target fmcomms1
[ 30%] Built target fmcomms2
[ 32%] Built target fmcomms2_adv
[ 34%] Built target fmcomms5
[ 37%] Built target fmcomms6
[ 39%] Built target fmcomms11
[ 42%] Built target ad9371
[ 44%] Built target ad9371_adv
[ 46%] Built target adrv9009
[ 49%] Built target adrv9009_adv
[ 51%] Built target ad6676
[ 54%] Built target fmcadc3
[ 56%] Built target daq2
[ 59%] Built target ad9739a
[ 61%] Built target AD5628_1
[ 63%] Built target cn0357
[ 66%] Built target cn0508
[ 68%] Built target cn0511
[ 71%] Built target cn0540
[ 73%] Built target pr_config
[ 75%] Built target motor_control
[ 78%] Built target lidar
[ 80%] Built target dmm
[ 83%] Built target debug
[ 85%] Built target spectrum_analyzer
[ 87%] Built target scpi
[ 90%] Built target ad9081
[ 92%] Built target ad9084
[ 95%] Built target adrv9002
[100%] Built target xmw
-- Install configuration: ""
-- Installing: /usr/local/lib/libosc.so.0.8
-- Up-to-date: /usr/local/lib/libosc.so.0
-- Set runtime path of "/usr/local/lib/libosc.so.0.8" to ""
-- Installing: /usr/local/bin/osc
-- Set runtime path of "/usr/local/bin/osc" to ""
-- Installing: /usr/share/polkit-1/actions/org.adi.pkexec.osc.policy
-- Installing: /usr/local/bin/osc-wrapper
-- Installing: /usr/local/share/osc/glade/AD5628_1.glade
-- Installing: /usr/local/share/osc/glade/AD7303.glade
-- Installing: /usr/local/share/osc/glade/ad6676.glade
-- Installing: /usr/local/share/osc/glade/ad9081.glade
-- Installing: /usr/local/share/osc/glade/ad9084.glade
-- Installing: /usr/local/share/osc/glade/ad9371.glade
-- Installing: /usr/local/share/osc/glade/ad9371_adv.glade
-- Installing: /usr/local/share/osc/glade/ad9739a.glade
-- Installing: /usr/local/share/osc/glade/adrv9002.glade
-- Installing: /usr/local/share/osc/glade/adrv9009.glade
-- Installing: /usr/local/share/osc/glade/adrv9009_adv.glade
-- Installing: /usr/local/share/osc/glade/cf_axi_tdd.glade
-- Installing: /usr/local/share/osc/glade/cn0357.glade
-- Installing: /usr/local/share/osc/glade/cn0508.glade
-- Installing: /usr/local/share/osc/glade/cn0511.glade
-- Installing: /usr/local/share/osc/glade/cn0540.glade
-- Installing: /usr/local/share/osc/glade/daq2.glade
-- Installing: /usr/local/share/osc/glade/debug.glade
-- Installing: /usr/local/share/osc/glade/dmm.glade
-- Installing: /usr/local/share/osc/glade/fmcadc3.glade
-- Installing: /usr/local/share/osc/glade/fmcomms1.glade
-- Installing: /usr/local/share/osc/glade/fmcomms11.glade
-- Installing: /usr/local/share/osc/glade/fmcomms2.glade
-- Installing: /usr/local/share/osc/glade/fmcomms2_adv.glade
-- Installing: /usr/local/share/osc/glade/fmcomms5.glade
-- Installing: /usr/local/share/osc/glade/fmcomms6.glade
-- Installing: /usr/local/share/osc/glade/generic_dac.glade
-- Installing: /usr/local/share/osc/glade/lidar.glade
-- Installing: /usr/local/share/osc/glade/motor_control.glade
-- Installing: /usr/local/share/osc/glade/osc.glade
-- Installing: /usr/local/share/osc/glade/oscplot.glade
-- Installing: /usr/local/share/osc/glade/pr_config.glade
-- Installing: /usr/local/share/osc/glade/scpi.glade
-- Installing: /usr/local/share/osc/glade/spectrum_analyzer.glade
-- Installing: /usr/local/share/osc/glade/xmw.glade
-- Installing: /usr/local/share/osc/glade/ADIlogo.png
-- Installing: /usr/local/share/osc/glade/IIOlogo.png
-- Installing: /usr/local/share/osc/glade/ch_color_icon.png
-- Installing: /usr/local/share/osc/glade/laser_symbol.png
-- Installing: /usr/local/share/osc/glade/osc.ico
-- Installing: /usr/local/share/osc/glade/osc.svg
-- Installing: /usr/local/share/osc/glade/osc128.png
-- Installing: /usr/local/share/osc/glade/osc16.png
-- Installing: /usr/local/share/osc/glade/osc256.png
-- Installing: /usr/local/share/osc/glade/osc32.png
-- Installing: /usr/local/share/osc/glade/osc64.png
-- Installing: /usr/local/share/osc/glade/osc_capture.png
-- Installing: /usr/local/share/osc/glade/osc_generator.png
-- Installing: /usr/local/share/osc/glade/sawtooth.png
-- Installing: /usr/local/share/osc/glade/sine.png
-- Installing: /usr/local/share/osc/glade/square.png
-- Installing: /usr/local/share/osc/glade/triangle.png
-- Installing: /usr/local/share/applications/adi-osc.desktop
-- Installing: /usr/local/share/icons/hicolor/16x16/apps/adi-osc.png
-- Installing: /usr/local/share/icons/hicolor/32x32/apps/adi-osc.png
-- Installing: /usr/local/share/icons/hicolor/64x64/apps/adi-osc.png
-- Installing: /usr/local/share/icons/hicolor/128x128/apps/adi-osc.png
-- Installing: /usr/local/share/icons/hicolor/256x256/apps/adi-osc.png
-- Installing: /usr/local/share/icons/hicolor/scalable/apps/adi-osc.svg
-- Installing: /usr/local/share/osc/styles.css
-- Up-to-date: /usr/local/share/osc/icons
-- Installing: /usr/local/share/osc/icons/triangle.png
-- Installing: /usr/local/share/osc/icons/osc64.png
-- Installing: /usr/local/share/osc/icons/osc32.png
-- Installing: /usr/local/share/osc/icons/osc.ico
-- Installing: /usr/local/share/osc/icons/laser_symbol.png
-- Installing: /usr/local/share/osc/icons/ch_color_icon.png
-- Installing: /usr/local/share/osc/icons/osc_generator.png
-- Installing: /usr/local/share/osc/icons/IIOlogo.png
-- Installing: /usr/local/share/osc/icons/square.png
-- Installing: /usr/local/share/osc/icons/ADIlogo.png
-- Installing: /usr/local/share/osc/icons/sawtooth.png
-- Installing: /usr/local/share/osc/icons/osc.svg
-- Installing: /usr/local/share/osc/icons/osc16.png
-- Installing: /usr/local/share/osc/icons/osc_capture.png
-- Installing: /usr/local/share/osc/icons/sine.png
-- Installing: /usr/local/share/osc/icons/osc128.png
-- Installing: /usr/local/share/osc/icons/osc256.png
-- Installing: /usr/local/lib/osc/profiles/AD-FREQCVT1_test.ini
-- Installing: /usr/local/lib/osc/profiles/AD-TRXBOOST1_test.ini
-- Installing: /usr/local/lib/osc/profiles/PZSDR2_2400TDD_test.ini
-- Installing: /usr/local/lib/osc/profiles/AD-FMCADC2_test.ini
-- Installing: /usr/local/lib/osc/profiles/AD-FMCDAQ2_test.ini
-- Installing: /usr/local/lib/osc/profiles/AD-FMCDAQ3_test.ini
-- Installing: /usr/local/lib/osc/profiles/ADRV9363_test.ini
-- Installing: /usr/local/lib/osc/profiles/ADRV9371-W_test.ini
-- Installing: /usr/local/lib/osc/profiles/ADRV9371_test.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms1_sweep_rx.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms1_sweep_tx.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms1_test.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms2_sweep.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms2_test.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms4_sweep.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms4_test.ini
-- Installing: /usr/local/lib/osc/profiles/FMComms5_test.ini
-- Installing: /usr/local/lib/osc/profiles/GSM.ini
-- Installing: /usr/local/lib/osc/profiles/LTE10.ini
-- Installing: /usr/local/lib/osc/profiles/LTE15.ini
-- Installing: /usr/local/lib/osc/profiles/LTE1p4.ini
-- Installing: /usr/local/lib/osc/profiles/LTE20.ini
-- Installing: /usr/local/lib/osc/profiles/LTE3.ini
-- Installing: /usr/local/lib/osc/profiles/LTE5.ini
-- Installing: /usr/local/lib/osc/profiles/PZSDR1_test.ini
-- Installing: /usr/local/lib/osc/profiles/PZSDR2_test.ini
-- Up-to-date: /usr/local/lib/osc/xmls
-- Installing: /usr/local/lib/osc/xmls/ad9361-phy.xml
-- Installing: /usr/local/lib/osc/xmls/adi_regmap_adc_v9.xml
-- Installing: /usr/local/lib/osc/xmls/adf4351.xml
-- Installing: /usr/local/lib/osc/xmls/ad9528.xml
-- Installing: /usr/local/lib/osc/xmls/ad9144.xml
-- Installing: /usr/local/lib/osc/xmls/ad9122.xml
-- Installing: /usr/local/lib/osc/xmls/ad9250.xml
-- Installing: /usr/local/lib/osc/xmls/adi_regmap_adc.xml
-- Installing: /usr/local/lib/osc/xmls/adi_regmap_adc_v10.xml
-- Installing: /usr/local/lib/osc/xmls/adi_regmap_dac.xml
-- Installing: /usr/local/lib/osc/xmls/ad9680.xml
-- Installing: /usr/local/lib/osc/xmls/adi_regmap_dac_v9.xml
-- Installing: /usr/local/lib/osc/xmls/ad9643.xml
-- Installing: /usr/local/lib/osc/xmls/ad9523.xml
-- Installing: /usr/local/lib/osc/xmls/ad9517.xml
-- Up-to-date: /usr/local/lib/osc/filters
-- Installing: /usr/local/lib/osc/filters/AD936x_LP_256kHz_768kSPS.ftr
-- Installing: /usr/local/lib/osc/filters/LTE5_MHz.ftr
-- Installing: /usr/local/lib/osc/filters/LTE20_MHz.ftr
-- Installing: /usr/local/lib/osc/filters/UMTS.ftr
-- Installing: /usr/local/lib/osc/filters/LTE1p4_MHz.ftr
-- Up-to-date: /usr/local/lib/osc/filters/adrv9002
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_10_lvds_nco_api_68_8_1.stream
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_10_lvds_nco_api_68_8_1.json
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_20_lvds_api_68_8_1.json
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_40_lvds_api_68_8_1.json
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_20_lvds_api_68_8_1.stream
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_40_lvds_api_68_8_1.stream
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_5_cmos_api_68_8_1.stream
-- Installing: /usr/local/lib/osc/filters/adrv9002/lte_5_cmos_api_68_8_1.json
-- Installing: /usr/local/lib/osc/filters/LTE3_MHz.ftr
-- Installing: /usr/local/lib/osc/filters/ATSC_10M72Hz.ftr
-- Installing: /usr/local/lib/osc/filters/AD936x_LP_666kHz_2MSPS.ftr
-- Installing: /usr/local/lib/osc/filters/AD936x_LP_180kHz_521kSPS.ftr
-- Installing: /usr/local/lib/osc/filters/61_44_28MHz.ftr
-- Up-to-date: /usr/local/lib/osc/filters/ad9371_5
-- Installing: /usr/local/lib/osc/filters/ad9371_5/profile_TxBW50_ORxBW50_RxBW25.txt
-- Installing: /usr/local/lib/osc/filters/ad9371_5/profile_TxBW50_ORxBW50_RxBW50.txt
-- Installing: /usr/local/lib/osc/filters/ad9371_5/profile_TxBW100_ORxBW100_RxBW20.txt
-- Installing: /usr/local/lib/osc/filters/ad9371_5/profile_TxBW200_ORxBW200_RxBW100.txt
-- Installing: /usr/local/lib/osc/filters/ad9371_5/profile_TxBW100_ORxBW100_RxBW100.txt
-- Installing: /usr/local/lib/osc/filters/ad9371_5/profile_TxBW100_ORxBW100_RxBW50.txt
-- Installing: /usr/local/lib/osc/filters/LTE15_MHz.ftr
-- Installing: /usr/local/lib/osc/filters/AD936x_LP_333kHz_1MSPS.ftr
-- Up-to-date: /usr/local/lib/osc/filters/adrv9009
-- Installing: /usr/local/lib/osc/filters/adrv9009/Tx_BW200_IR245p76_Rx_BW200_OR245p76_ORx_BW200_OR245p76_DC245p76.txt
-- Installing: /usr/local/lib/osc/filters/adrv9009/Tx_BW400_IR491p52_Rx_BW100_OR122p88_ORx_BW400_OR491p52_DC245p76.txt
-- Installing: /usr/local/lib/osc/filters/adrv9009/Tx_BW200_IR245p76_Rx_BW100_OR122p88_ORx_BW200_OR245p76_DC245p76.txt
-- Installing: /usr/local/lib/osc/filters/adrv9009/Tx_BW100_IR122p88_Rx_BW100_OR122p88_ORx_BW100_OR122p88_DC245p76.txt
-- Up-to-date: /usr/local/lib/osc/filters/ad9081
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH1_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH6and7_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH2_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/ad9081_pfir_SingleInphase.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/ad9081_pfir_OFF.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH8and9_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH6_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH0and1_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH0_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH7_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH3_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/ad9081_pfir_FullComplex.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/ad9081_pfir_Matrix.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH10and11_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH4_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH4and5_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH14and15_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH12and13_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/ad9081_pfir_DualReal.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH2and3_3.21GHz.cfg
-- Installing: /usr/local/lib/osc/filters/ad9081/QuadMxFE_DualReal_CH5_3.2GHz.cfg
-- Installing: /usr/local/lib/osc/filters/GSM.ftr
-- Installing: /usr/local/lib/osc/filters/LTE10_MHz.ftr
-- Up-to-date: /usr/local/lib/osc/waveforms
-- Installing: /usr/local/lib/osc/waveforms/msk_20M.txt
-- Installing: /usr/local/lib/osc/waveforms/qpsknofilt_30M.txt
-- Installing: /usr/local/lib/osc/waveforms/sinewave_0.3_2ch.mat
-- Installing: /usr/local/lib/osc/waveforms/sinewave_0.6_2ch.mat
-- Up-to-date: /usr/local/lib/osc/waveforms/qpsk
-- Installing: /usr/local/lib/osc/waveforms/qpsk/qpsk_tx_raw_2msps.mat
-- Installing: /usr/local/lib/osc/waveforms/qpsk/qpsk_tx_data_8x.txt
-- Installing: /usr/local/lib/osc/waveforms/qpskwithfilt_30.72M.txt
-- Installing: /usr/local/lib/osc/waveforms/Tx_10MHz_61.44Msps_PeakScaling3.0dBFS_ETM1.1_PAR7.5dB_Offset0MHz_4Carrier.txt
-- Installing: /usr/local/lib/osc/waveforms/sinewave_0.3.mat
-- Installing: /usr/local/lib/osc/waveforms/sinewave_0.6.mat
-- Installing: /usr/local/lib/osc/waveforms/sinewave_0.9.mat
-- Installing: /usr/local/lib/osc/waveforms/sinewave_0.9_2ch.mat
-- Installing: /usr/local/lib/osc/waveforms/qam16_20M.txt
-- Installing: /usr/local/lib/osc/waveforms/10.txt
-- Installing: /usr/local/lib/osc/waveforms/11.txt
-- Installing: /usr/local/lib/osc/waveforms/1M_10M_nyq.txt
-- Installing: /usr/local/lib/osc/waveforms/Tx_20MHz_245.76Msps_PeakScaling3.0dBFS_ETM1.1_PAR7.5dB_Offset0MHz_4Carrier.txt
-- Installing: /usr/local/lib/osc/waveforms/Tx_20MHz_61.44Msps_PeakScaling3.0dBFS_ETM1.1_PAR7.5dB_Offset0MHz.txt
-- Installing: /usr/local/lib/osc/waveforms/LTE5.mat
-- Installing: /usr/local/lib/osc/waveforms/LTE_E_TM3.1_64QAM_10MHz.mat
-- Installing: /usr/local/lib/osc/waveforms/chirp.mat
-- Installing: /usr/local/lib/osc/waveforms/LTE20.mat
-- Installing: /usr/local/lib/osc/waveforms/LTE10.mat
-- Installing: /usr/local/lib/osc/waveforms/Tx_20MHz_245.76Msps_PeakScaling3.0dBFS_ETM1.1_PAR7.5dB_Offset0MHz_2Carrier.txt
-- Installing: /usr/local/lib/osc/waveforms/LTE15.mat
-- Installing: /usr/local/lib/osc/waveforms/Tx_20MHz_245.76Msps_PeakScaling3.0dBFS_ETM1.1_PAR7.5dB_Offset0MHz.txt
-- Installing: /usr/local/lib/osc/waveforms/modem_qpsk_20MHz.mat
-- Up-to-date: /usr/local/lib/osc/block_diagrams
-- Installing: /usr/local/lib/osc/block_diagrams/AD9144_11675-002.svg
-- Installing: /usr/local/lib/osc/block_diagrams/AD9523_09278-020.svg
-- Installing: /usr/local/lib/osc/block_diagrams/Zynq.svg
-- Installing: /usr/local/lib/osc/block_diagrams/AD9680_11752-001.svg
-- Installing: /usr/local/lib/osc/block_diagrams/AD-FMCDAQ2-EBZ.jpg
-- Installing: /usr/local/lib/osc/block_diagrams/ADRV9371-N_PCBZ.jpg
-- Installing: /usr/local/lib/osc/block_diagrams/AD9625_11814-001.svg
-- Installing: /usr/local/lib/osc/block_diagrams/AD9361.svg
-- Installing: /usr/local/lib/osc/block_diagrams/AD_FMCOMMS5_EBZ.jpg
-- Installing: /usr/local/lib/osc/block_diagrams/AD_FMCOMM2S2_RevC.jpg
-- Installing: /usr/local/lib/osc/block_diagrams/fmcomms2.svg
-- Installing: /usr/local/lib/osc/block_diagrams/AD9371.svg
-- Installing: /usr/local/lib/osc/block_diagrams/CN0540.jpg
-- Installing: /usr/local/lib/osc/generic_dac.so
-- Set runtime path of "/usr/local/lib/osc/generic_dac.so" to ""
-- Installing: /usr/local/lib/osc/fmcomms1.so
-- Set runtime path of "/usr/local/lib/osc/fmcomms1.so" to ""
-- Installing: /usr/local/lib/osc/fmcomms2.so
-- Set runtime path of "/usr/local/lib/osc/fmcomms2.so" to ""
-- Installing: /usr/local/lib/osc/fmcomms2_adv.so
-- Set runtime path of "/usr/local/lib/osc/fmcomms2_adv.so" to ""
-- Installing: /usr/local/lib/osc/fmcomms5.so
-- Set runtime path of "/usr/local/lib/osc/fmcomms5.so" to ""
-- Installing: /usr/local/lib/osc/fmcomms6.so
-- Set runtime path of "/usr/local/lib/osc/fmcomms6.so" to ""
-- Installing: /usr/local/lib/osc/fmcomms11.so
-- Set runtime path of "/usr/local/lib/osc/fmcomms11.so" to ""
-- Installing: /usr/local/lib/osc/ad9371.so
-- Set runtime path of "/usr/local/lib/osc/ad9371.so" to ""
-- Installing: /usr/local/lib/osc/ad9371_adv.so
-- Set runtime path of "/usr/local/lib/osc/ad9371_adv.so" to ""
-- Installing: /usr/local/lib/osc/adrv9009.so
-- Set runtime path of "/usr/local/lib/osc/adrv9009.so" to ""
-- Installing: /usr/local/lib/osc/adrv9009_adv.so
-- Set runtime path of "/usr/local/lib/osc/adrv9009_adv.so" to ""
-- Installing: /usr/local/lib/osc/ad6676.so
-- Set runtime path of "/usr/local/lib/osc/ad6676.so" to ""
-- Installing: /usr/local/lib/osc/fmcadc3.so
-- Set runtime path of "/usr/local/lib/osc/fmcadc3.so" to ""
-- Installing: /usr/local/lib/osc/daq2.so
-- Set runtime path of "/usr/local/lib/osc/daq2.so" to ""
-- Installing: /usr/local/lib/osc/ad9739a.so
-- Set runtime path of "/usr/local/lib/osc/ad9739a.so" to ""
-- Installing: /usr/local/lib/osc/AD5628_1.so
-- Set runtime path of "/usr/local/lib/osc/AD5628_1.so" to ""
-- Installing: /usr/local/lib/osc/cn0357.so
-- Set runtime path of "/usr/local/lib/osc/cn0357.so" to ""
-- Installing: /usr/local/lib/osc/cn0508.so
-- Set runtime path of "/usr/local/lib/osc/cn0508.so" to ""
-- Installing: /usr/local/lib/osc/cn0511.so
-- Set runtime path of "/usr/local/lib/osc/cn0511.so" to ""
-- Installing: /usr/local/lib/osc/cn0540.so
-- Set runtime path of "/usr/local/lib/osc/cn0540.so" to ""
-- Installing: /usr/local/lib/osc/pr_config.so
-- Set runtime path of "/usr/local/lib/osc/pr_config.so" to ""
-- Installing: /usr/local/lib/osc/motor_control.so
-- Set runtime path of "/usr/local/lib/osc/motor_control.so" to ""
-- Installing: /usr/local/lib/osc/lidar.so
-- Set runtime path of "/usr/local/lib/osc/lidar.so" to ""
-- Installing: /usr/local/lib/osc/dmm.so
-- Set runtime path of "/usr/local/lib/osc/dmm.so" to ""
-- Installing: /usr/local/lib/osc/debug.so
-- Set runtime path of "/usr/local/lib/osc/debug.so" to ""
-- Installing: /usr/local/lib/osc/spectrum_analyzer.so
-- Set runtime path of "/usr/local/lib/osc/spectrum_analyzer.so" to ""
-- Installing: /usr/local/lib/osc/scpi.so
-- Set runtime path of "/usr/local/lib/osc/scpi.so" to ""
-- Installing: /usr/local/lib/osc/ad9081.so
-- Set runtime path of "/usr/local/lib/osc/ad9081.so" to ""
-- Installing: /usr/local/lib/osc/ad9084.so
-- Set runtime path of "/usr/local/lib/osc/ad9084.so" to ""
-- Installing: /usr/local/lib/osc/adrv9002.so
-- Set runtime path of "/usr/local/lib/osc/adrv9002.so" to ""
-- Installing: /usr/local/lib/osc/cf_axi_tdd.so
-- Set runtime path of "/usr/local/lib/osc/cf_axi_tdd.so" to ""
-- Installing: /usr/local/lib/osc/xmw.so
-- Set runtime path of "/usr/local/lib/osc/xmw.so" to ""
Everything seems good for me, but I can not lauchn the application.
libgtkdatabox-0.9.3-0 and Ubuntu 18.04 LTS
What happens when you launch it?
-Travis
If you are trying to build the master branch of IIO-Oscilloscope, which is gtk3 based, you will need gtkdatabox v1.0. This is because gtkdatabox-0.9 was compiled against gtk2 and will not work with gtk3 based applications.
According to the output you shared above , you already installed gtkdatabox1.0 :
When launching the app from a terminal window, you should see the something like: "GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported Trace/breakpoint trap (core dumped) "
To fix this, you will need to delete libgtkdatabox-0.9. If you've installed it via a package manager , you should be able to remove it using:
apt remove libgtkdatabox-dev
-- Cristina
After removing the gtkdatabox-0.9, I remove also the folder iio-oscilloscope/ and re-clone the main branch of IIO-Oscilloscope, then rebuild it again, here is the output:
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~/iio-oscilloscope/build$ sudo make install
-- Set non-toolchain portion of runtime path of "/usr/local/lib/libosc.so.0.8" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/bin/osc" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/generic_dac.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcomms1.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcomms2.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcomms2_adv.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcomms5.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcomms6.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcomms11.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/ad9371.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/ad9371_adv.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/adrv9009.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/adrv9009_adv.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/ad6676.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/fmcadc3.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/daq2.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/ad9739a.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/AD5628_1.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/cn0357.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/cn0508.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/cn0511.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/cn0540.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/pr_config.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/motor_control.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/lidar.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/dmm.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/debug.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/spectrum_analyzer.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/scpi.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/ad9081.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/ad9084.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/adrv9002.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/cf_axi_tdd.so" to ""
-- Set non-toolchain portion of runtime path of "/usr/local/lib/osc/xmw.so" to ""
But again, I can not launch the application
How are you launching the application ?
What happens when you type osc in a terminal window?
--Cristina
After I enter the password and nothing happens.
I also used command line from terminal: ./osc
(base) pc@pc-HP-EliteDesk-800-G4-WKS-TWR:~/iio-oscilloscope/build$ ./osc
(osc:17982): Gtk-CRITICAL **: 12:15:04.246: gtk_about_dialog_set_version: assertion 'GTK_IS_ABOUT_DIALOG (about)' failed
(osc:17982): Gtk-CRITICAL **: 12:15:04.246: gtk_label_get_label: assertion 'GTK_IS_LABEL (label)' failed
(osc:17982): Gtk-CRITICAL **: 12:15:04.246: gtk_label_set_label: assertion 'GTK_IS_LABEL (label)' failed
A crash report file has been created at: /home/pc/.osc_crash_report
Segmentation fault (core dumped)
