ADRV9002 MATLAB shared libiio issues
Product Number: ADRV9002
Hello All,
I tried to communicate with ADRV9002 through Matlab using linux-based analog device transciever toolbox.
ADI provided some example for data transfer with ADRV9002 here.
There are many errors in the example:
%% Configure device
tx = adi.adi.ADRV9002.Tx; >>>> tx = adi.ADRV9002.Tx;
tx.uri = "ip:analog.local";
tx.CenterFrequency = 1e9; >>>>tx.CenterFrequencyChannel0 = 1e9;
tx.DataSource = 'DMA';
tx.EnableCyclicBuffers = true;
tx.EnabledChannels = 1;
%% Generate tone
amplitude = 2^15; frequency = 0.12e6;
swv1 = dsp.SineWave(amplitude, frequency);
swv1.ComplexOutput = true;
swv1.SamplesPerFrame = 2^14;
swv1.SampleRate = tx.SamplingRate;
y = swv1();
% Send
tx(y);
result:
Error using SineWave/SineWave.setParameters
The 'SampleRate' property must be finite valued.
Error in dsp.SineWave/setParameters
In mx tx object, the sample rate set to NaN, I check the documentation, it's a read only parameter so user can not set it.
On the RX side I tried data=rx() command and getting this error:
Error using calllib
Parameter can not be converted to a character vector
Error in matlabshared.libiio.context/iio_create_context_from_uri
Error in matlabshared.libiio.base/getContext
Error in matlabshared.libiio.base/setupImpl
Error in adi.common.RxTx/setupImpl (line 117)
setupImpl@matlabshared.libiio.base(obj);
Please help in this regard.
Kind Regards
Arash
