About pyadi-iio how to judge whether there is a signal in the frequency
Product Number: plutosdr
I'm stuck on how to use pyadi-iio rx data to judge that there is a signal at that frequency and not noise.
For example, the sample_rate is 1MHz, rx_rf_bandwidth is 1MHz, rx_buffer_size is 4096.
There is a qpsk signal at 2472MHz, through the pyadi-iio rx function, I will get 1000000 data per second. Can I accurately judge whether there is a qpsk signal there by taking 4096 data?  Whether there are other methods to accurately judge.
Another question is, when I sweep around the 2472MHz frequency, I find that the qpsk signal at the 2472MHz frequency seems to spread to the surrounding frequencies, is this caused by the pyadi iio receive buffer? But in the python code I changed the receive buffer to 1 (sdr._rxadc.set_kernel_buffers_count(1) # Force no elastic buffers) as suggested by Travis.
Kind regards,
anasss
Top Replies
  • There is a qpsk signal at 2472MHz, through the pyadi-iio rx function, I will get 1000000 data per second. Can I accurately judge whether there is a qpsk signal there by taking 4096 data?  Whether…
  • There is a qpsk signal at 2472MHz, through the pyadi-iio rx function, I will get 1000000 data per second. Can I accurately judge whether there is a qpsk signal there by taking 4096 data?  Whether there are other methods to accurately judge.
    This is a theoretical question on detection theory. I would suggest looking at textbooks from Steven Kay. This is really outside the bounds of our support here.
    If this spreading goes away if you wait longer between buffer pulls you are getting a buffer that has data between LO transition. Setting kernel buffers to 1 does not guarantee that it doesn't happen but lowers the probability.
    -Travis
