This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Demos Installation via https://github.com/analogdevicesinc/gr-iio/tree/grcon2019 Not Working
We are interested to use  PhaseEstimator and/or Phase Est. blocks of the GRCon2019 demos along with ADRVs. Unfortunately, installing through the above link gets everything installed except PhaseEstimator and Phase Est. blocks. Investigating, my classmates and I have found no relating python or cpp files to these blocks. Isn't it weird?
Are you aware of that? Is there a way to fix it?
Relating blocks at pages 58 and 60: GRCon2029-Presentation
Really appreciate your attention! Thanks a lot. ~Eva
Installed files:
~/gr-iio-grcon2019/build$ sudo make install
[sudo] password for ....:
[ 39%] Built target gnuradio-iio
[ 42%] Built target _iio_pluto_sink_swig_swig_tag
[ 47%] Built target iio_pluto_sink_swig_swig_2d0df
[ 52%] Built target pygen_swig_0709b
[ 55%] Built target _iio_pluto_source_swig_swig_tag
[ 58%] Built target _iio_swig_swig_tag
[ 63%] Built target iio_swig_swig_2d0df
[ 69%] Built target _iio_swig
[ 74%] Built target iio_pluto_source_swig_swig_2d0df
[ 80%] Built target _iio_pluto_sink_swig
[ 87%] Built target _iio_pluto_source_swig
[ 92%] Built target pygen_swig_208e8
[ 96%] Built target pygen_swig_c92ab
[100%] Built target pygen_python_iio_86a7c
Install the project...
-- Install configuration: "Release"
-- Installing: /usr/local/lib/pkgconfig/gnuradio-iio.pc
-- Installing: /usr/local/lib/cmake/iio/iioConfig.cmake
-- Installing: /usr/local/include/gnuradio/iio/api.h
-- Installing: /usr/local/include/gnuradio/iio/device_source.h
-- Installing: /usr/local/include/gnuradio/iio/device_sink.h
-- Installing: /usr/local/include/gnuradio/iio/fmcomms2_source.h
-- Installing: /usr/local/include/gnuradio/iio/fmcomms2_sink.h
-- Installing: /usr/local/include/gnuradio/iio/fmcomms5_source.h
-- Installing: /usr/local/include/gnuradio/iio/fmcomms5_sink.h
-- Installing: /usr/local/include/gnuradio/iio/adrv9009_zu11eg_source.h
-- Installing: /usr/local/include/gnuradio/iio/pluto_source.h
-- Installing: /usr/local/include/gnuradio/iio/pluto_sink.h
-- Installing: /usr/local/include/gnuradio/iio/converter_ss.h
-- Installing: /usr/local/include/gnuradio/iio/math.h
-- Installing: /usr/local/include/gnuradio/iio/power_ff.h
-- Installing: /usr/local/include/gnuradio/iio/attr_sink.h
-- Installing: /usr/local/include/gnuradio/iio/attr_source.h
-- Installing: /usr/local/include/gnuradio/iio/attr_updater.h
-- Installing: /usr/local/include/gnuradio/iio/modulo_ff.h
-- Installing: /usr/local/include/gnuradio/iio/modulo_const_ff.h
-- Installing: /usr/local/include/gnuradio/iio/vector_select.h
-- Installing: /usr/local/include/gnuradio/iio/fftshift.h
-- Installing: /usr/local/lib/libgnuradio-iio.so.0.3
-- Up-to-date: /usr/local/lib/libgnuradio-iio.so.0
-- Set runtime path of "/usr/local/lib/libgnuradio-iio.so.0.3" to ""
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/_iio_swig.so
-- Set runtime path of "/usr/local/lib/python2.7/dist-packages/iio/_iio_swig.so" to ""
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_swig.py
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_swig.pyc
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_swig.pyo
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/_iio_pluto_source_swig.so
-- Set runtime path of "/usr/local/lib/python2.7/dist-packages/iio/_iio_pluto_source_swig.so" to ""
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_pluto_source_swig.py
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_pluto_source_swig.pyc
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_pluto_source_swig.pyo
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/_iio_pluto_sink_swig.so
-- Set runtime path of "/usr/local/lib/python2.7/dist-packages/iio/_iio_pluto_sink_swig.so" to ""
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_pluto_sink_swig.py
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_pluto_sink_swig.pyc
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/iio_pluto_sink_swig.pyo
-- Installing: /usr/local/include/iio/swig/iio_swig.i
-- Installing: /usr/local/include/iio/swig/iio_pluto_source_swig.i
-- Installing: /usr/local/include/iio/swig/iio_pluto_sink_swig.i
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/__init__.py
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/__init__.pyc
-- Installing: /usr/local/lib/python2.7/dist-packages/iio/__init__.pyo
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_device_source.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_device_sink.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_fmcomms2_source.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_fmcomms2_sink.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_fmcomms5_source.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_fmcomms5_sink.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_adrv9009_zu11eg_source.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_pluto_source.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_pluto_sink.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_math.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_math_gen.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_power_ff.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_modulo_ff.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_modulo_const_ff.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_attr_sink.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_attr_source.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_attr_updater.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_vector_select.xml
-- Installing: /usr/local/share/gnuradio/grc/blocks/iio_fftshift.xml
[locked by: travisfcollins at 11:04 PM (GMT -5) on 1 Dec 2021]
