I ran successfully my RADIO AD9361 using matlab older version.
In my computer I installed virtual machine and it changed by setup
Currently:
Now I have changed to R2020b version of Matlab and try to run my radio
with the WLAN transmission and receiving matlab code. I get the error as follows:
Failed to find device: cf-ad9361-dds-core-lpc
I also checked my Linux machine and found that under the following directory,
/sys/dev/ no more iio directory.
Even though I installed libiio again.
If I use the following on my terminal:
grep -e ^open foo | grep libiio
I get the following response:
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libiio.so.0", O_RDONLY|O_CLOEXEC) = 3
However, according to the instruction it should be as follows:
open("./tls/x86_64/libiio.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) open("./tls/libiio.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) open("./x86_64/libiio.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) open("./libiio.so.0", O_RDONLY|O_CLOEXEC) = 3
Can someone explain to me what is going on with my Linux machine?
After using virtual machine, the setup has changed.
What must I do to run the AD9361 radio successfully?
Thanks
