Stream data into / out of MATLAB
Hi Team ADI
I am using ZC706 + adrv9008-1
I want to Stream data into / out of MATLAB
With your tools so I started with the following link:
https://wiki.analog.com/resources/tools-software/transceiver-toolbox
I then performed the following steps:
I use windows.
And I installed the
MATLAB R2020a
Xilinx Vivado 2018.2
AnalogDevicesTransceiverToolbox_v20.1.1.mltbx
So I am using this link https://wiki.analog.com/resources/tools-software/linux-software/zynq_images
Additionally copied the image  to the base directory from the subdirectory
And the boot + device tree of ZC706 + adrv9008-1
In matlab:
I run this example
ADRV9009_DMA_Example
%% Rx set up
rx = adi.ADRV9009.Rx('uri','ip:169.254.248.160');
rx.EnabledChannels = 1;
rx.kernelBuffersCount = 1;
for k=1:20
valid = false;
while ~valid
[y, valid] = rx();
end
end
rx.release();
And I am getting this error:
Error using matlabshared.libiio.base/cstatus
Channel: voltage0 not found
Error in adi.common.Attribute/setAttributeBool (line 77)
            cstatus(obj,status,['Channel: ' id ' not found']);
Error in adi.ADRV9009.Rx/setupInit (line 201)
            obj.setAttributeBool('voltage0','powerdown',false,true);
Error in adi.common.RxTx/configureChanBuffers (line 214)
            setupInit(obj);
Error in matlabshared.libiio.base/setupImpl
Error in adi.common.RxTx/setupImpl (line 116)
            setupImpl@matlabshared.libiio.base(obj);
Error in ADRV9009_DMA_Example (line 27)
        [y, valid] = rx();
Please advise
Thanks
Ron
