ADRV9002 Pyadi-iio Cyclic Buffer
I am using the following script to run a transmit test on the ADRV9002.
sdr = adi.adrv9002(uri="ip:192.168.1.233")
sdr.tx_hardwaregain_chan0 = -40
sdr.tx_ensm_mode_chan0 = "rf_enabled"
Fs = 15360000
t = np.arange(0,0.1,1/Fs)
Fc = 5000000
fm = 20000
frm = np.cos(2 * np.pi * Fc * t + np.sin(2 * np.pi * fm * t)) * 2 ** 15
m = np.sin(2 * np.pi * fm * t) * 2 ** 15
frm.astype(complex)
sdr.tx_cyclic_buffer = True
for i in range(10000):
    sdr.tx(frm)
Despite defining the set up for "tx channel 0", I am only getting the expected TX RF output on TX2_OUT SMA and not the expected TX1_OUT SMA.
Also, the only way I am able to get the transmit path to repeatedly transmit so I can view the results on a PXA is by looping the sdr.tx(frm) over and over again in a for loop. Is this the correct way to "constantly" transmit so that the output can be monitored continuously. Does the sdr.tx_cyclic_buffer = True do this somehow so that the sdr.tx does not have to be constantly looped?
Thanks!
-NT
    on Feb 8, 2021 8:21 PM 2 months ago
    Are you loading a profile? If you use IIO-Scope does this hold true with the DDS or the DAC Buffer outputs?
    Just set the tx_cyclic_buffer to True and do not loop. Just a single buffer needs to be passed. Note that if python exits or the sdr object is cleared the drivers will switch back to DDS mode.
    -Travis
  • Thanks for the response,
    Even after setting the tx_cyclic_buffer to True and passing the buffer once as shown below, the transmitter still does not constantly transmit the buffer, I see the TX data on the PXA only for a brief moment when the sdr.tx(frm) is called but it only shows a continuous transmission when looping the sdr.tx(frm) command. I also am not exiting Python or destroying the sdr object.
    Fs = 15360000
    Fc = 5000000
    fm = 20000
    frm = frm.astype(complex)
    time.sleep(1)
    sdr.tx(frm)
    while True:
        pass
    -NT
    on Feb 8, 2021 11:11 PM 2 months ago in reply to nmt4781
    hmmm that might be a bug then. I assume you are using the split DMA (sdr.tx_dma_mode == 'split')?
    -Travis
    on Feb 8, 2021 11:24 PM 2 months ago in reply to travisfcollins
    Looks like it's remapping all the DMA functions to tx2.
    Can you try this branch: https://github.com/analogdevicesinc/pyadi-iio/tree/adrv9002-split-dma
    Still running through the tests on my side.
    -Travis
  • Thanks,
    When trying to run through the suggested test branch provided, I get a new error now when trying to connect via the sdr = adi.adrv9002(uri="192.168.1.233") listed below.
    File "C:\Users\ntiberio\AppData\Local\Continuum\anaconda3\lib\site-packages\adi\adrv9002.py", line 88, in __init__
    remap(self._rx2, "rx_", "rx2_", type(self))
    File "C:\Users\ntiberio\AppData\Local\Continuum\anaconda3\lib\site-packages\adi\obs.py", line 55, in remap
    for func in dir(object_source)
    File "C:\Users\ntiberio\AppData\Local\Continuum\anaconda3\lib\site-packages\adi\obs.py", line 56, in <listcomp>
    if (getattr(object_source, func))
    TypeError: descriptor '__weakref__' for 'attribute' objects doesn't apply to 'obs' object
