Issues getting plutoSDR to work in GNUradio
Hello I am using python 3, GNUradio 3.8 and I am trying to get my Pluto SDR to work on GNU I constantly get the same errors
First I get this
Then this
and this is my block design
My Pluto SDR is plugged in my computer via usb
    on Feb 2, 2021 6:54 PM 2 months ago
    You need to make sure the IIO blocks are on your PYTHONPATH. An easy way to check is to try and import the module from the terminal:
    python3 -c "import iio"
    If this fails you need to find the location where the blocks were installed and add that parent folder to your python path:
    export PYTHONPATH=$PYTHONPATH:<parent folder of iio folder>
    This location is usually in the manifest.txt file generated when you installed the blocks. If its not, re-run `sudo make install` and it will appear in the output.
    -Travis
