This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
how to use matlab system block which combined to iio oscilloscope proper ?
Hi everyone.
we have  zynq-zc706-adv7511-ad9361-fmcomms2-3 and it includes the SD-card image which provided by analog devices(including the analog devices linux environment and iio oscilloscope/libiio)
we want to simulate in the simulink (stream data not hdl coder) the next matlab system block
the problem with that block that we want to include in the simulation the ad-freqcvt1-ebz down-up converter. we understand that we may need to change the cfg file which for the moment is written like this :
data_in_device = cf-ad9361-dds-core-lpc
data_out_device = cf-ad9361-lpc
ctrl_device = ad9361-phy
channel = RX_LO_FREQ,IN,out_altvoltage0_RX_LO_frequency,
channel = RX_SAMPLING_FREQ,IN,in_voltage_sampling_frequency,
channel = RX_RF_BANDWIDTH,IN,in_voltage_rf_bandwidth,
channel = RX1_GAIN_MODE,IN,in_voltage0_gain_control_mode,
channel = RX1_GAIN,IN,in_voltage0_hardwaregain,
channel = RX1_RSSI,OUT,in_voltage0_rssi,
channel = RX2_GAIN_MODE,IN,in_voltage1_gain_control_mode,
channel = RX2_GAIN,IN,in_voltage1_hardwaregain,
channel = RX2_RSSI,OUT,in_voltage1_rssi,
channel = TX_LO_FREQ,IN,out_altvoltage1_TX_LO_frequency,
channel = TX_SAMPLING_FREQ,IN,out_voltage_sampling_frequency,
channel = TX_RF_BANDWIDTH,IN,out_voltage_rf_bandwidth,
what are the changes that need to be done in order to achieve the required block ? (and how to write them in cfg file )
thank for all the answers.
[locked by: travisfcollins at 9:45 PM (GMT -5) on 13 Jan 2021]
