Make ERROR gr-iio
I am following this link to install gr-iio to use pluto sdr.
https://wiki.analog.com/resources/tools-software/linux-software/gnuradio
Getting following error:
zafar@zafar-VirtualBox:~/gr-iio$ sudo make
[ 2%] Building CXX object lib/CMakeFiles/gnuradio-iio.dir/device_source_impl.cc.o
/home/zafar/gr-iio/lib/device_source_impl.cc: In static member function ‘static gr::iio::device_source::sptr gr::iio::device_source::make(const string&, const string&, const std::vector<std::__cxx11::basic_string<char> >&, const string&, const std::vector<std::__cxx11::basic_string<char> >&, unsigned int, unsigned int)’:
/home/zafar/gr-iio/lib/device_source_impl.cc:45:9: error: could not convert ‘gnuradio::get_initial_sptr(T*) [with T = gr::iio::device_source_impl]()’ from ‘std::shared_ptr<gr::iio::device_source_impl>’ to ‘gr::iio::device_source::sptr {aka boost::shared_ptr<gr::iio::device_source>}’
return gnuradio::get_initial_sptr
(new device_source_impl(device_source_impl::get_context(uri), true,
device, channels, device_phy,
params, buffer_size, decimation));
/home/zafar/gr-iio/lib/device_source_impl.cc: In static member function ‘static gr::iio::device_source::sptr gr::iio::device_source::make_from(iio_context*, const string&, const std::vector<std::__cxx11::basic_string<char> >&, const string&, const std::vector<std::__cxx11::basic_string<char> >&, unsigned int, unsigned int)’:
/home/zafar/gr-iio/lib/device_source_impl.cc:58:9: error: could not convert ‘gnuradio::get_initial_sptr(T*) [with T = gr::iio::device_source_impl]()’ from ‘std::shared_ptr<gr::iio::device_source_impl>’ to ‘gr::iio::device_source::sptr {aka boost::shared_ptr<gr::iio::device_source>}’
(new device_source_impl(ctx, false, device, channels, device_phy,
lib/CMakeFiles/gnuradio-iio.dir/build.make:73: recipe for target 'lib/CMakeFiles/gnuradio-iio.dir/device_source_impl.cc.o' failed
make[2]: *** [lib/CMakeFiles/gnuradio-iio.dir/device_source_impl.cc.o] Error 1
CMakeFiles/Makefile2:135: recipe for target 'lib/CMakeFiles/gnuradio-iio.dir/all' failed
make[1]: *** [lib/CMakeFiles/gnuradio-iio.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
Will appreciate any help
Thanks
Added some relevant tags
[edited by: zafar at 7:22 PM (GMT 0) on 24 May 2020]
    on May 24, 2020 11:11 PM 6 months ago
    Seem to me like you are mixing the wrong GNU Radio version with the wrong branch.
    What gnuradio version do you have installed? What gr-iio branch are you using?
    -Travis
  • Thanks for the response
    GNU Radio version:
    zafar@zafar-VirtualBox:~/gr-iio$ gnuradio-config-info -v
    3.9.0.0-git
    Git branch:
    I cloned from this
    https://github.com/analogdevicesinc/libiio.git
    available here:
    Git branch:
    zafar@zafar-VirtualBox:~/gr-iio$ git branch
    * master
    on May 26, 2020 10:30 PM 6 months ago in reply to zafar
    If you are using master, it only supports 3.7. See GNU Radio 3.8 instructions in the wiki page you linked.
    -Travis
  • Thanks
    I replaced 3.9 with 3.7. Again got following error:
    zafar@zafar-VirtualBox:~/libad9361-iio/gr-iio$ sudo make
    /home/zafar/libad9361-iio/gr-iio/lib/device_source_impl.cc: In static member function ‘static gr::iio::device_source::sptr gr::iio::device_source::make(const string&, const string&, const std::vector<std::__cxx11::basic_string<char> >&, const string&, const std::vector<std::__cxx11::basic_string<char> >&, unsigned int, unsigned int)’:
    /home/zafar/libad9361-iio/gr-iio/lib/device_source_impl.cc:45:9: error: could not convert ‘gnuradio::get_initial_sptr(T*) [with T = gr::iio::device_source_impl]()’ from ‘std::shared_ptr<gr::iio::device_source_impl>’ to ‘gr::iio::device_source::sptr {aka boost::shared_ptr<gr::iio::device_source>}’
    /home/zafar/libad9361-iio/gr-iio/lib/device_source_impl.cc: In static member function ‘static gr::iio::device_source::sptr gr::iio::device_source::make_from(iio_context*, const string&, const std::vector<std::__cxx11::basic_string<char> >&, const string&, const std::vector<std::__cxx11::basic_string<char> >&, unsigned int, unsigned int)’:
    /home/zafar/libad9361-iio/gr-iio/lib/device_source_impl.cc:58:9: error: could not convert ‘gnuradio::get_initial_sptr(T*) [with T = gr::iio::device_source_impl]()’ from ‘std::shared_ptr<gr::iio::device_source_impl>’ to ‘gr::iio::device_source::sptr {aka boost::shared_ptr<gr::iio::device_source>}’
    on May 27, 2020 9:30 PM 6 months ago in reply to zafar
    What Linux distribution and version are you using?
    Can you provide the output of: `gnuradio-config-info -v`
    And the output of a clean cmake configuration: `cmake ..`
    And the output of make again.
    -Travis
