I am trying to connect an AD5593R DAC to a Raspberry Pi running Kuiper Linux, but am unable to see the connected device via either iio_info or the IIO Oscilloscope.
The setup we're using is identical to the one in https://wiki.analog.com/resources/eval/user-guides/circuits-from-the-lab/eval-ad5593r-pmdz, with the Pi connected to a PMD-RPI-INTZ interposer board. It seems as if the board is being seen by the Pi, but unable to communicate with it, as the device shows up with i2cdetect -y -1. Similar issue to https://ez.analog.com/studentzone/f/q-a/580191/iio_info-does-not-detect-my-device, but using Mark's suggestions (changing GPIO pins 13 and 17 to pull-up), has not solved the issue.
analog@analog:~ $ iio_info iio_info version: 0.25 (git tag:c36770cc) Libiio version: 0.25 (git tag: c36770c) backends: local xml ip usb serial IIO context created with local backend. Backend version: 0.25 (git tag: c36770c) Backend description string: Linux analog 5.15.92-v7+ #1 SMP Tue Apr 2 06:14:55 UTC 2024 armv7l IIO context has 4 attributes: hw_carrier: Raspberry Pi 3 Model B Rev 1.2 dtoverlay: vc4-kms-v3d,rpi-ad5593r,w1-gpio local,kernel: 5.15.92-v7+ uri: local: IIO context has 2 devices: hwmon0: cpu_thermal 1 channels found: temp1: (input) 1 channel-specific attributes found: attr 0: input value: 56920 No trigger on this device hwmon1: rpi_volt 1 channels found: in0: (input) 1 channel-specific attributes found: attr 0: lcrit_alarm value: 0 No trigger on this device
analog@analog:~ $ i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- --
analog@analog:~ $ raspi-gpio get BANK0 (GPIO 0 to 27): GPIO 0: level=1 fsel=0 func=INPUT GPIO 1: level=1 fsel=0 func=INPUT GPIO 2: level=1 fsel=4 alt=0 func=SDA1 GPIO 3: level=1 fsel=4 alt=0 func=SCL1 GPIO 4: level=0 fsel=0 func=INPUT GPIO 5: level=1 fsel=0 func=INPUT GPIO 6: level=1 fsel=0 func=INPUT GPIO 7: level=1 fsel=0 func=INPUT GPIO 8: level=1 fsel=0 func=INPUT GPIO 9: level=0 fsel=0 func=INPUT GPIO 10: level=0 fsel=0 func=INPUT GPIO 11: level=0 fsel=0 func=INPUT GPIO 12: level=0 fsel=0 func=INPUT GPIO 13: level=1 fsel=0 func=INPUT GPIO 14: level=0 fsel=0 func=INPUT GPIO 15: level=1 fsel=0 func=INPUT GPIO 16: level=0 fsel=0 func=INPUT GPIO 17: level=1 fsel=0 func=INPUT GPIO 18: level=0 fsel=0 func=INPUT GPIO 19: level=0 fsel=0 func=INPUT GPIO 20: level=0 fsel=0 func=INPUT GPIO 21: level=0 fsel=0 func=INPUT GPIO 22: level=0 fsel=0 func=INPUT GPIO 23: level=0 fsel=0 func=INPUT GPIO 24: level=0 fsel=0 func=INPUT GPIO 25: level=0 fsel=0 func=INPUT GPIO 26: level=0 fsel=0 func=INPUT GPIO 27: level=0 fsel=0 func=INPUT BANK1 (GPIO 28 to 45): GPIO 28: level=0 fsel=0 func=INPUT GPIO 29: level=1 fsel=0 func=INPUT GPIO 30: level=0 fsel=0 func=INPUT GPIO 31: level=0 fsel=0 func=INPUT GPIO 32: level=1 fsel=7 alt=3 func=TXD0 GPIO 33: level=1 fsel=7 alt=3 func=RXD0 GPIO 34: level=0 fsel=7 alt=3 func=SD1_CLK GPIO 35: level=1 fsel=7 alt=3 func=SD1_CMD GPIO 36: level=1 fsel=7 alt=3 func=SD1_DAT0 GPIO 37: level=1 fsel=7 alt=3 func=SD1_DAT1 GPIO 38: level=1 fsel=7 alt=3 func=SD1_DAT2 GPIO 39: level=1 fsel=7 alt=3 func=SD1_DAT3 GPIO 40: level=1 fsel=4 alt=0 func=PWM0 GPIO 41: level=1 fsel=4 alt=0 func=PWM1 GPIO 42: level=0 fsel=4 alt=0 func=GPCLK1 GPIO 43: level=0 fsel=4 alt=0 func=GPCLK2 GPIO 44: level=1 fsel=0 func=INPUT GPIO 45: level=1 fsel=0 func=INPUT BANK2 (GPIO 46 to 53): GPIO 46: level=1 fsel=0 func=INPUT GPIO 47: level=1 fsel=1 func=OUTPUT GPIO 48: level=0 fsel=4 alt=0 func=SD0_CLK GPIO 49: level=1 fsel=4 alt=0 func=SD0_CMD GPIO 50: level=1 fsel=4 alt=0 func=SD0_DAT0 GPIO 51: level=1 fsel=4 alt=0 func=SD0_DAT1 GPIO 52: level=1 fsel=4 alt=0 func=SD0_DAT2 GPIO 53: level=1 fsel=4 alt=0 func=SD0_DAT3
