May 2023 StudentZone Quiz Solution
Question 1:
Using the values and formulas provided in the laboratory directions compute the following parameters:
  • Forward current through the IR LED. (use datasheet of the QED-123)
  • Cut-off frequency of the high-pass filter.
  • Cut-off frequency of the second stage low-pass filter.
  • Cut-off frequency of the third stage low-pass filter.
  • Gain of the third stage amplifier
Answer 1:
  • Forward current through the IR LED can be computed using the following forumla (the datasheet value for the forward volage of the QED-123 is 1.7V):
IF = 7mA
  • Cut-off frequency of the high-pass filter can be computed using the following formula:
Fc1 = 0.33Hz
  • Cut-off frequency of the second stage low-pass filter can be computed using the following formula:
Fc2 = 3.3Hz
  • Cut-off frequency of the third stage low-pass filter can be computed using the following formula:
Fc3 = 3.3Hz
AV = - 470
Question 2:
What parameters change if R5 is modified?
Answer 2:
If R5 is modified, this will affect the gain of the third stage amplifier.
Question 3:
What parameters change if R6 is modified?
Answer 3:
If R6 is modified, this will affect both the gain of the third stage amplifier and the cut-off frequency of the third stage low-pass filter.
  • Reg. Q1: You get IF=7mA with VF = 1,7V. When I study the datasheet, how can I be sure, the LED wil work at 7mA? The IF/VF diagram starts at IF=10mA, VF~1,2V . All Optical parameters refers to 20mA. It feels like R1 is a slightly to high for VP=5V.
