AD4134
Recommended for New Designs
The AD4134 is a quad channel, low noise, simultaneous sampling, precision analog-to-digital converter (ADC) that delivers on functionality, performance...
Datasheet
AD4134 on Analog.com
AD7760
Production
The AD7760 is a high performance, 24-bit Σ-Δ analog-to-digital converter (ADC). It combines wide input bandwidth and high speed with the benefits of...
Datasheet
AD7760 on Analog.com
We have an actual situation based on using your AD7760 product, but during testing, we found that the waveform it collected always has overshoot and ringing phenomena at the edges that cannot be filtered out. Afterwards, we purchased your products EVAL-AD4134FMCZ and EVAL-SDP-CH1Z for testing, and were quite satisfied with the performance of the AD4134 chip. We would like to use the AD4134 chip to replace the AD7760 for development and design. However, as we are not very familiar with AD4134, and after referring to some information on your official website and forum, we found that there is still a lack of information about AD4134 communication and FPGA code. May I ask if you can provide us with some information.
JEstayo - Moved from Precision ADCs to System Demonstration Platform (SDP) Support. Post date updated from Wednesday, March 20, 2024 12:45 AM UTC to Wednesday, March 20, 2024 1:59 AM UTC to reflect the move.
Hi yifang ,
Please check out the files in the software section under Part Ecosystem and advise on specific requirements you need. Thanks!
https://www.analog.com/en/products/ad4134.html
Janine
Hi Janine,
May I ask if you can provide information about the FPGA communication connection of AD4134 and the code for AD4134 in the FPGA of EVAL-SDP-CH1Z.
yifang
I have moved the thread in the SDP Support community. Someone here should be able to assist you.
Janine
