PC does not recognize SDP-S device in device manager
I have purchased the SDP-S board and AD5242 daughter board for evaluation. Without the AD5242, the PC can't recognize SDP-S device in device manager.
I have "ADI SDP Drivers 2.3.0.164" listed under PC "Apps & features", but do not see "ADI Development Tools" under the device manager.
I see there are couple threads related to this issue, but none of the resolutions there work for me. I have tried uninstall and install the driver back without SDP-S connected; restart the PC; switch to a new cable etc.
I do see a response that the same problem is resolved with a new SDP board (https://ez.analog.com/sdp/f/discussions/537076/adf5610-adi-sdp-setup-driver-error).
Is this a known issue with the hardware? Would it resolve if I switch to another SDP-S device? If so, what is the process like for replacement or reimbursement? Thanks!
- Eunice
    Sorry to hear you are having difficulties with the SDP-S, this isn't an issue I have seen on the SDP-S board before.
    When the SDP-S is connected to the PC without the AD5242, is a green LED light called PWR that is near the USB connector on the SDP-S turned on?
    Is the orange LED called LED1, which is located near the button on the top side of the SDP-S turned on?
    Would you mind trying to install the most up to date SDP drivers(V2.4.0.286) which can be found at the following link:  http://swdownloads.analog.com/ACE/SDP/SDPDrivers.exe
    It should be possible to return the SDP-S and request a replacement, but before you do that, we might be able to resolve the issue through this forum. Is there anything you are doing differently when the SDP-S is connected and disconnected to the AD5242 eval board?
