SDP-H1 and EVAL-AD7768-4FMCZ stopped operating
I was using the SDP-H1 board with the EVAL-AD7768-4FMCZ daughter board when the LabView software appeared to hangup after the SAMPLE button was pushed (it had successfully worked several times previously). I used Windows TASK MANAGER to terminate the LabView software, pushed the reset button on the SDP-H1 board then removed the 12V power jack and unplugged the USB connection.
I re-connected the 12V supply then plugged in the USB connector. Device Manager confirmed the presence of the USB driver, but only the BF_POWER LED illuminated (previously several LEDs were on. Launching the LabView software produced a "Waiting for transfer from Controller" message to be displayed for sometime before an "Error 1172" message was displayed.
When the board was operating correctly, the FPGA_DONE LED was on. Because this LED is no longer on I assume the FPGA is not being programmed (?).
How do I get this board to work ?
regards,
Richard
  • I have made some voltage measurements on the SDP-H1 board to help diagnose the problem:
    3V3 FPGA measures 3.308V
    2V5 FPGA measures 2.499V
    1V23 FPGA CORE measures 1.229V
    VADJ FPGA at R179 measures 0.286V
    VADJ FPGA at R180 measures 0V
    1V8_DDR2_VDDO measures 0V
    0.9V DDR2 measures 0V
    3V3 FMC measures 0V
    +5V0 at R176 measures 5.03V
    These measurements made with the daughter board plugged in and powered by +9V, SDP-H1 board powered from +12v and USB connected to PC.
  • Thank you Niall. It is possible the boards became disconnected during operation as the mated boards do not sit flat on the bench as the  EVAL-AD7768-4FMCZ feet are way too short. My suggestion would be too include a couple screws with EVAL-AD7768-4FMCZ, as it appears to be designed to only plug into the SDP-H1.
    My follow up question is which board is most likely damaged - the SDP-H1 or the EVAL-AD7768FMCZ ?
    regards,
    Richard
