profile write error
Product Number: ADRV9009
Software Version: wizard 2.4 or 2.5, api 3.6.2.1
have been trying to write the output from the Profile Configuration Wizard to ADRV9009 using "cat profile.txt > /sys/bus/iio/devices/iio:device3" and get following error
adrv9009 spi0.1: ADIHAL_resetHw
adrv9009 spi0.1: Requesting device clock 65536000 failed got 64673684
cat: write error: Invalid argument
have tried wizard version 2.4 and 2.5 and with both intended custom profile and the default generated without changing any parameters, same error message. loading same profile into TES while connected to target seems to work fine.
have tried pruning sections from profile, doesn't change error.  attaching dmesg output - i do see an error "adrv9009 spi0.1: adrv9009_parse_profile: Malformed profile entry was <rxNcoShifterCfg>" not sure if that was due to my pruning or not will try again after a fresh reboot. thank you for any suggestions.
UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
NET: Registered PF_UNIX/PF_LOCAL protocol family
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
armv7-pmu f8891000.pmu: hw perfevents: no interrupt-affinity property, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=18 bucket_order=0
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
fuse: init (API version 7.34)
bounce: pool size: 64 pages
io scheduler mq-deadline registered
io scheduler kyber registered
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
Registered mathworks_ip class
SPI driver spidev has no spi_device_id for adi,swspi
spi-nor spi1.0: found s25fl128s1, expected n25q128a11
random: fast init done
random: crng init done
spi-nor spi1.0: s25fl128s1 (32768 Kbytes)
5 fixed-partitions partitions found on MTD device spi1.0
Creating 5 MTD partitions on "spi1.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000002000000 : "spare"
MACsec IEEE 802.1AE
tun: Universal TUN/TAP device driver, 1.6
Freeing initrd memory: 19852K
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 35 (32:5c:39:f5:eb:ad)
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver upd78f0730
usbserial: USB Serial support registered for upd78f0730
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 5.15.36-xilinx-v2022.2 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
SPI driver ads7846 has no spi_device_id for ti,tsc2046
SPI driver ads7846 has no spi_device_id for ti,ads7843
SPI driver ads7846 has no spi_device_id for ti,ads7845
SPI driver ads7846 has no spi_device_id for ti,ads7873
i2c_dev: i2c /dev entries driver
si570 1-005d: registered, current frequency 156250000 Hz
i2c i2c-0: Added multiplexed i2c bus 1
i2c 2-0039: Fixing up cyclic dependency with 70e00000.axi_hdmi
adv7511 2-0039: supply avdd not found, using dummy regulator
adv7511 2-0039: supply dvdd not found, using dummy regulator
adv7511 2-0039: supply pvdd not found, using dummy regulator
adv7511 2-0039: supply bgvdd not found, using dummy regulator
adv7511 2-0039: supply dvdd-3v not found, using dummy regulator
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: supply vcc not found, using dummy regulator
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
pca953x 4-0021: supply vcc not found, using dummy regulator
pca953x 4-0021: using no AI
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: registered as rtc0
rtc-pcf8563 5-0051: setting system clock to 2024-07-08T23:29:38 UTC (1720481378)
i2c i2c-0: Added multiplexed i2c bus 5
at24 6-0050: supply vcc not found, using dummy regulator
at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
usbcore: registered new interface driver uvcvideo
gspca_main: v2.14.0 registered
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
ledtrig-cpu: registered to indicate activity on CPUs
hid: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-5
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7988-1
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7984
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7983
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7982
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7980
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7949
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7946
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7942
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7699
usb 1-1: new high-speed USB device number 2 using ci_hdrc
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7693
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7691
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7690
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7689
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7688
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7687
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7686
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7685
SPI driver pulsar_adc has no spi_device_id for adi,pulsar,ad7682
SPI driver ad7124 has no spi_device_id for adi,ad7124-4
SPI driver ad7124 has no spi_device_id for adi,ad7124-8
SPI driver ad7192 has no spi_device_id for adi,ad7190
SPI driver ad7192 has no spi_device_id for adi,ad7193
SPI driver ad7192 has no spi_device_id for adi,ad7195
SPI driver ad9467 has no spi_device_id for adi,ad9643
SPI driver ad9467 has no spi_device_id for adi,ad9250
SPI driver ad9467 has no spi_device_id for adi,ad9250_2
SPI driver ad9467 has no spi_device_id for adi,ad9265
SPI driver ad9467 has no spi_device_id for adi,ad9683
SPI driver ad9467 has no spi_device_id for adi,ad9434
mmc0: new high speed SDHC card at address aaaa
SPI driver ad9467 has no spi_device_id for adi,ad9625
mmcblk0: mmc0:aaaa SC16G 14.8 GiB
SPI driver ad9467 has no spi_device_id for adi,ad9652
SPI driver ad9467 has no spi_device_id for adi,ad9649
 mmcblk0: p1 p2
SPI driver adar3000 has no spi_device_id for adi,adar3001
SPI driver adar3000 has no spi_device_id for adi,adar3002
ad9528 spi0.0: supply vcc not found, using dummy regulator
SPI driver ad9783 has no spi_device_id for adi,ad9780
SPI driver ad9783 has no spi_device_id for adi,ad9781
SPI driver adis16475 has no spi_device_id for adi,adis16470
SPI driver adis16475 has no spi_device_id for adi,adis16475-1
SPI driver adis16475 has no spi_device_id for adi,adis16475-2
SPI driver adis16475 has no spi_device_id for adi,adis16475-3
SPI driver adis16475 has no spi_device_id for adi,adis16477-1
SPI driver adis16475 has no spi_device_id for adi,adis16477-2
SPI driver adis16475 has no spi_device_id for adi,adis16477-3
SPI driver adis16475 has no spi_device_id for adi,adis16465-1
SPI driver adis16475 has no spi_device_id for adi,adis16465-2
usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
SPI driver adis16475 has no spi_device_id for adi,adis16465-3
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB2.0 HUB
SPI driver adis16475 has no spi_device_id for adi,adis16467-1
hub 1-1:1.0: USB hub found
SPI driver adis16475 has no spi_device_id for adi,adis16467-2
SPI driver adis16475 has no spi_device_id for adi,adis16467-3
hub 1-1:1.0: 4 ports detected
SPI driver adis16475 has no spi_device_id for adi,adis16500
SPI driver adis16475 has no spi_device_id for adi,adis16505-1
SPI driver adis16475 has no spi_device_id for adi,adis16505-2
SPI driver adis16475 has no spi_device_id for adi,adis16505-3
SPI driver adis16475 has no spi_device_id for adi,adis16507-1
SPI driver adis16475 has no spi_device_id for adi,adis16507-2
SPI driver adis16475 has no spi_device_id for adi,adis16507-3
axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.01.a) found
axi_sysid 45000000.axi-sysid-0: [adrv9009] on [zc706] git branch <hdl_2022_r2> git <7ea497b6c24172ee293d6e0a9a387a16973da5ce> dirty [2024-03-25 18:42:09] UTC
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
usbcore: registered new interface driver snd-usb-audio
NET: Registered PF_INET6 protocol family
Segment Routing with IPv6
In-situ OAM (IOAM) with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered PF_PACKET protocol family
NET: Registered PF_IEEE802154 protocol family
Key type dns_resolver registered
zynq_pm_remap_ocm: OCM pool is not available
zynq_pm_suspend_init: Unable to map OCM.
Registering SWP/SWPB emulation handler
of-fpga-region fpga-full: FPGA Region probed
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
Console: switching to colour frame buffer device 240x67
axi-hdmi 70e00000.axi_hdmi: [drm] fb0: axi_hdmi_drmdrm frame buffer device
axi_adxcvr 44a60000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTX2 at 0x44A60000. Number of lanes: 2.
usb 1-1.3: new low-speed USB device number 3 using ci_hdrc
axi_adxcvr 44a50000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.05.a) using CPLL on GTX2 at 0x44A50000. Number of lanes: 2.
axi_adxcvr 44a80000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTX2 at 0x44A80000. Number of lanes: 4.
axi-jesd204-rx 44aa0000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x44AA0000. Encoder 8b10b, width 4/4, lanes 2.
axi-jesd204-rx 44ab0000.axi-jesd204-rx-os: AXI-JESD204-RX (1.07.a) at 0x44AB0000. Encoder 8b10b, width 4/4, lanes 2.
axi-jesd204-tx 44a90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x44A90000. Encoder 8b10b, width 4/4, lanes 4.
debugfs: File 'Capture' in directory 'dapm' already present!
adrv9009 spi0.1: adrv9009_probe : enter
usb 1-1.3: New USB device found, idVendor=1a2c, idProduct=2124, bcdDevice= 1.10
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.3: Product: USB Keyboard
usb 1-1.3: Manufacturer: SEM
input: SEM USB Keyboard as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1A2C:2124.0001/input/input0
hid-generic 0003:1A2C:2124.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-ci_hdrc.0-1.3/input0
input: SEM USB Keyboard Consumer Control as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:1A2C:2124.0002/input/input1
input: SEM USB Keyboard System Control as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:1A2C:2124.0002/input/input2
hid-generic 0003:1A2C:2124.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-ci_hdrc.0-1.3/input1
usb 1-1.4: new full-speed USB device number 4 using ci_hdrc
usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.4: Product: USB Receiver
usb 1-1.4: Manufacturer: Logitech
logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-ci_hdrc.0-1.4/input2
input: Logitech M705 as /devices/soc0/axi/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0005/0003:046D:406D.0006/input/input3
logitech-hidpp-device 0003:046D:406D.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech M705] on usb-ci_hdrc.0-1.4/input2:1
axi_adxcvr 44a60000.axi-adxcvr-rx: adxcvr_clk_enable: CPLL RX buffer underflow error, status: 0x61
axi_adxcvr 44a60000.axi-adxcvr-rx: adxcvr_clk_enable: CPLL RX buffer overflow error, status: 0x61
axi_adxcvr 44a50000.axi-adxcvr-rx-os: adxcvr_clk_enable: CPLL RX buffer underflow error, status: 0x61
axi_adxcvr 44a50000.axi-adxcvr-rx-os: adxcvr_clk_enable: CPLL RX buffer overflow error, status: 0x61
adrv9009 spi0.1: adrv9009_info: adrv9009 Rev 192, Firmware 6.2.1 API version: 3.6.2.1 successfully initialized
cf_axi_dds 44a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x44A04000 mapped to 0x18acbe05, probed DDS AD9371
cf_axi_adc 44a00000.axi-adrv9009-rx-hpc: ADI AIM (10.03.) at 0x44A00000 mapped to 0x2d22fd34 probed ADC ADRV9009 as MASTER
input: gpio_keys as /devices/soc0/gpio_keys/input/input4
of_cfs_init
of_cfs_init: OK
ALSA device list:
  #0: HDMI monitor
Freeing unused kernel image (initmem) memory: 1024K
Run /init as init process
  with arguments:
    /init
  with environment:
    HOME=/
    TERM=linux
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
macb e000b000.ethernet eth0: PHY [e000b000.ethernet-ffffffff:07] driver [Marvell 88E1116R] (irq=POLL)
macb e000b000.ethernet eth0: configuring for phy/rgmii-id link mode
macb e000b000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
adrv9009 spi0.1: Requesting device clock 51200000 failed got 51200000
8<--- cut here ---
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 1a3d80e6
[00000000] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP ARM
Modules linked in: uio_pdrv_genirq
CPU: 0 PID: 882 Comm: cat Not tainted 5.15.36-xilinx-v2022.2 #1
Hardware name: Xilinx Zynq Platform
PC is at adrv9009_parse_profile+0x6d4/0x1494
LR is at adrv9009_parse_profile+0x4b0/0x1494
pc : [<c0864e7c>]    lr : [<c0864c58>]    psr: 60070013
sp : c2a2bc28  ip : 10a6bf71  fp : 00000000
r10: 000009f5  r9 : 00000000  r8 : 00000000
r7 : 00000001  r6 : c13ea008  r5 : ef594040  r4 : ef594070
r3 : fffffffa  r2 : 00000000  r1 : c1415ca3  r0 : 00000002
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
Control: 18c5387d  Table: 2f68004a  DAC: 00000051
Register r0 information: non-paged memory
Register r1 information: non-slab/vmalloc memory
Register r2 information: NULL pointer
Register r3 information: non-paged memory
Register r4 information: slab kmalloc-16k start ef594000 pointer offset 112 size 16384
Register r5 information: slab kmalloc-16k start ef594000 pointer offset 64 size 16384
Register r6 information: non-slab/vmalloc memory
Register r7 information: non-paged memory
Register r8 information: NULL pointer
Register r9 information: NULL pointer
Register r10 information: non-paged memory
Register r11 information: NULL pointer
Register r12 information: non-paged memory
Process cat (pid: 882, stack limit = 0xb03a6d8f)
Stack: (0xc2a2bc28 to 0xc2a2c000)
bc20:                   00000000 00040cc0 c17040f0 00000000 00000000 c1ca8340
bc40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
bc60: c266cc00 00000000 c13a5840 c140d040 00000000 00000000 600b0013 c2a2bd28
bc80: c17c3340 00000000 ef594097 00000000 00000000 fffffffa 00000001 00000048
bca0: c17ca3a4 c2a7d000 00000000 c01f86dc 34e1d65f 59e72fa2 000009f5 00000000
bcc0: c17ca3a4 59e72fa2 ffefe000 000009f5 c1caa340 000009f5 c1ca8340 c2aae290
bce0: 00000001 00000000 00000000 c086cf04 c086ce84 00000000 00000000 c2a2bd50
bd00: c2aae290 c02be9ec 00000000 00000000 000009f5 c2a2be00 000009f5 c2a7d000
bd20: c2aae280 c02bdd6c 00000000 00000000 00000000 c2a00f00 c2a2be28 00000000
bd40: c2a2be00 00000000 00004004 c022a24c c2a00f00 00000000 00000000 00000000
bd60: 00000000 00000000 00000000 40040000 00000000 00000000 668cb31f 59e72fa2
bd80: 222b3e52 c2afa200 c2a2be00 00000000 c2a00f00 c2a2be28 00000001 0000000f
bda0: ef517c80 c022b3d4 00000000 60070013 c2a00f00 c2a5ca80 00000000 c2afa200
bdc0: 000009f5 00000000 000009f5 00000001 00000001 c02619e4 000009f5 c024cf8c
bde0: c2a5ca80 00000010 c2afa200 00000001 c2b08000 00000000 c2a00f00 c2a2bf38
be00: 00000102 00000000 00000000 c2b0800c 00000000 00000000 000009f5 00000000
be20: 00000004 c2a00f00 00000000 00000000 00000000 00000000 00000000 00000000
be40: 00000000 59e72fa2 00000000 c02617b0 c2a2bed0 01000000 00000000 c2a5ca80
be60: 00000000 00000000 000009f5 c02603d0 00000004 c2a5ca80 ef517c80 c026079c
be80: 00000000 00000002 c2bf8011 00000000 c026039c 00000000 000009f5 00000000
bea0: 00000000 59e72fa2 00000056 c2a2bf30 c2a5ca80 00000000 00000000 7fffffff
bec0: 00000000 c2a00f00 00000001 c02609d0 000009f5 01000000 00000004 c2a00f00
bee0: 00000000 00000000 c2a2bf38 00000000 00000000 00000000 c2a5ca80 59e72fa2
bf00: 00000000 c2a5ca80 01000000 00000000 c2a5ca80 c022b04c 01000000 00000000
bf20: 00000000 59e72fa2 c2a2bf3c c2a00f00 00000000 00000000 00000000 00000000
bf40: 00000001 59e72fa2 c2a61c80 00000000 00000000 00000000 000000ef c01002a4
bf60: c2a2a000 000000ef bef8ebbc c022d090 00000000 00000000 00020000 00000000
bf80: 00000000 59e72fa2 00000000 01000000 00000000 00000000 000000ef c01002a4
bfa0: c2a2a000 c0100060 01000000 00000000 00000001 00000003 00000000 01000000
bfc0: 01000000 00000000 00000000 000000ef 00000000 01000000 00000003 bef8ebbc
bfe0: 004d0a78 bef8eba4 00448859 b6e95ae8 60070030 00000001 00000000 00000000
[<c0864e7c>] (adrv9009_parse_profile) from [<c086cf04>] (adrv9009_profile_bin_write+0x80/0xec)
[<c086cf04>] (adrv9009_profile_bin_write) from [<c02be9ec>] (sysfs_kf_bin_write+0x7c/0x94)
[<c02be9ec>] (sysfs_kf_bin_write) from [<c02bdd6c>] (kernfs_fop_write_iter+0x10c/0x1cc)
[<c02bdd6c>] (kernfs_fop_write_iter) from [<c022a24c>] (do_iter_readv_writev+0x124/0x1bc)
[<c022a24c>] (do_iter_readv_writev) from [<c022b3d4>] (do_iter_write+0x8c/0x1f4)
[<c022b3d4>] (do_iter_write) from [<c02619e4>] (iter_file_splice_write+0x234/0x380)
[<c02619e4>] (iter_file_splice_write) from [<c02603d0>] (direct_splice_actor+0x34/0x48)
[<c02603d0>] (direct_splice_actor) from [<c026079c>] (splice_direct_to_actor+0xf0/0x284)
[<c026079c>] (splice_direct_to_actor) from [<c02609d0>] (do_splice_direct+0xa0/0xe4)
[<c02609d0>] (do_splice_direct) from [<c022b04c>] (do_sendfile+0x24c/0x548)
[<c022b04c>] (do_sendfile) from [<c022d090>] (sys_sendfile64+0x124/0x13c)
[<c022d090>] (sys_sendfile64) from [<c0100060>] (ret_fast_syscall+0x0/0x48)
Exception stack(0xc2a2bfa8 to 0xc2a2bff0)
bfa0:                   01000000 00000000 00000001 00000003 00000000 01000000
Code: eafffe72 e59d201c e59d306c e59d9020 (e5c23000)
---[ end trace f4b59554fb6ea587 ]---
