HI Team,
I am working ZCU102 interface with ADRV9009,we are using AP mode function ,we are tuning single lo(same lo) in multiple times Appling, in each time different swing is coming. ,
Thanks in advance
ADRV9009
Recommended for New Designs
The ADRV9009 is a highly integrated, radio frequency (RF), agile transceiver offering dual transmitters and receivers, integrated synthesizers, and digital...
Datasheet
ADRV9009 on Analog.com
HI Team,
Thanks in advance
Are you giving any input to the ORX port ? What is the signal level are you feeding to the ORx Port ?
Below is the maximum input level which can be fed to the ORX port for different frequency ranges .
Can you share the plots where you are seeing the ADC swing ?
Are you using TALISE_ setRxTxEnable() function to control the ORx path ?
Why are you tuning same LO multiple times ? How much variation in swing do you see each time you configure LO for all the times ?
