ADRV9002 Dynamic frequency hopping
Product Number: ADRV9002
Software Version: Vivado 2022.2
Hi Team,
I am using ADRV9002 KV260 custom hardware Setup with reference to ADRV9002 ZCU102 with hdl_2022_r2 and no-OS-2022_R2. I have implemented frequency hopping in ADRV9002 in no-os using adi_adrv9001_fh_HopTable_Static_Configure( ) api. I am able to configure up-to 128 frequencies in two tables.
I have few doubts in frequency hopping.
1. Our requirement is to update one table while other table is hopping and to update 1st index frequency in the table while 0th index frequency in table is hopping & vice-versa. Is there any procedure for updating the frequency hopping at run time in no-os. I saw method called dynamic table loading, but for that also we need to use adi_adrv9001_fh_HopTable_Static_Configure() api & there is no procedure for it. So, please provide any procedure for updating the frequency in frequency hopping table. If dynamic loading is the only option, please provide the procedure for that.
2. We have got 2.47msec time for loading 64 frequencies in a table with spi clk of 45.45MHz & device clock of 100MHz. We have a requirement to reduce this time. So please give any suggestion to reduce this time & provide the time to load 64 frequencies in a table.
3.Is there any way to check time to hop certain number frequencies? If exists, please suggest the steps.
Thank you in advance
D. Yamuna
  • Hi team,
          Is there any update?
    Thank you.
  • Hi Yamuna,
    1. I can't answer questions specific to No-OS here. Questions about No-OS should be posed in the Microcontroller no-OS Drivers forum.
    2. The implementation of the dynamic table loading API is specific to our evaluation platform. It will not work on custom hardware, which is why we steer customers to use the static table loading API instead. However, if you have access to low-level functionality of your SPI bus, you may be able to replicate the functionality of the dynamic table loading API on your system. The difference is that the static API accesses SPI through the HAL and sends out a series of SPI transactions to load the table, whereas the dynamic API bypasses the HAL by writing the information of the SPI transaction directly to FPGA memory and sends it out in a single SPI transaction. The amount of data sent is unchanged, but but by combining the data into a single transaction, you remove any delays that occur between the individual SPI transactions.
    3. I don't fully understand your question. Can you rephrase it, or perhaps use a visual aid to show what you're trying to measure?
    Kind Regards,
    Michał
  • Hi  ,
       Thank you for the reply.
    1. This issue is resolved. I used the same api which is used in static configuration.
    2. My doubt is how to reduce the hopping table loading time.
    3. How to know the hopping time for certain no.of frequencies? Eg: In 1 sec, how many no.of frequencies can be hopped?
    Thanks & Regards,
    D. Yamuna
  • Hi Yamuna,
    2. Each SPI transaction results in an overhead delay. I don't have the exact numbers here, but hypothetically, if the overhead for one SPI transaction is X ns, and the time to send the address and upload one byte is Y ns, then uploading N bytes in single transactions would take N * (X + Y). However, if you packed all of that information into a single transaction, then the time taken would be N * X + Y.
    3. The ADRV9002 is capable of meeting Link-16 timing requirements. However, this is dependent on the configuration. For fastest hopping, you will need to use LO Mux mode.
    Kind Regards,
    Michał
  • Hi
    I didn't understand the answer fully. Could you please explain in detail?
    Thanks & Regards,
    D. Yamuna
  • Hi Yamuna,
    I was able to achieve link-16 on the evaluation board. I recommend you use an external clock, I set mine to 300MHz at 0dB, Hop mode to LO MUX. I was able to achieve a dwell time of 9us with a switching time of 3us.
  • Hi Yamuna,
    Which answer do you not understand?
    Kind Regards,
    Michał
  • Hi  ,
      Thank you for the reply. We are also using lo mux real time process mode only.  I didn't answer the below answers. Could you explain in detail?
    Thanks & regards,
    D. Yamuna.
  • Hi  ,
           Thank you for the reply. We are using external clock for our board. But we didn't try link-16 on the board. Could you please how link-16 is related to frequency hopping loading time? How did you achieve that dwell time & switching time? Is there any reference for it? If it is there, please tell me the process to achieve that dwell time.
    Thanks & regards,
    D. Yamuna
  • Hi Yamuna,
    I was able to achive a 10 us dwell with the following TDD Setup.
    Set PLL Bandwidth to 1200 KHz, calibrtion to fast and power to high
    Hope this helps.
