I am using the example from the following link:
https://github.com/analogdevicesinc/pyadi-iio/blob/master/examples/adrv9002_example.py
I am getting the following error:
Any suggestions?
ADRV9002
Recommended for New Designs
The ADRV9002 is a highly integrated RF transceiver that has dual-channel transmitters, dual-channel receivers, integrated synthesizers, and digital signal...
Datasheet
ADRV9002 on Analog.com
Any suggestions?
Dorant - Moved from RF and Microwave to TES GUI & Software Support ADRV9001 – ADRV9007. Post date updated from Sunday, November 24, 2024 12:14 PM UTC to Monday, November 25, 2024 4:35 PM UTC to reflect the move.
Dorant - Moved from RF and Microwave to TES GUI & Software Support ADRV9001 – ADRV9007. Post date updated from Monday, November 25, 2024 4:35 PM UTC to Monday, November 25, 2024 4:35 PM UTC to reflect the move.
Hi Anowar,
Could you please tell us more about your application/use case? It seems that you are using wideband profile (>1MSPS) - is that right?
Best,
-Stefan
I would like to generate and transmit user-defined waveform (e.g. LFM waveform) using ADRV9002.
I would like to generate a LFM chirp signal using ADRV9002 using Python.
Any suggestions or existing resources?
We are currently auditing our engineerzone forums for questions that have not been fully answered. If any more information is needed, please reply to this post or create a new post.
Please note that there are two software solutions for ADRV9002 as per: adrv9001_software_and_hardware_selection_guide.pdf. For questions on iio please make a post on the forum: ez.analog.com/linux-software-drivers
The ADRV9002 TES can also be used for Python code generation as described: (+) Produce and Edit Python Sample Code - Documents - TES GUI & Software Support ADRV9001 – ADRV9007 - EngineerZone
Conrad
