Hi ,
I have one question regarding stream image output.
I made several arbitrary settings in TES and output json profile(.json) and stream images (.bin) for each setting, and compared the contents of the stream images, and found that the contents of all stream files are the same.
Checking the adrv9002 wiki, I found that when loading a json profile into adrv9002, the stream image corresponding to the json profile must also be loaded at the same time.
ADRV9002 Integrated Dual RF Transceiver Linux device driver [Analog Devices Wiki]
Since I assumed that the output stream image would change in response to the TES settings, I thought it was not normal for the stream image to remain unchanged for each TES setting.
Is it normal that the stream image does not change for each setting?
Regards
keij
