FMCOMMS5 – RX Phase Synchronization Issue with Internal LO and Clarification on External LO Configuration
Contains AI Generated Content
Product Number: AD9361
Software Version: Petalinux-v2023.2
Dear ADI Support Team,
We are currently validating the FMCOMMS5 FMC board on our custom Zynq UltraScale+ MPSoC development platform.
The FMCOMMS5 contains two AD9361 RF transceivers. We are using the IIO Oscilloscope application to configure and validate the RX channels.
1. Issue with RX Phase Synchronization Using Internal LO
Currently, both AD9361 devices are configured to use their respective internal LO configurations.
We are observing the following behaviour:
- Even after clicking the MCS (Multi-Chip Synchronization) button in IIO Oscilloscope, the RX channels are not phase-aligned.
- We need to manually adjust the phase rotation to achieve phase alignment between the RX channels.
- Whenever we change the LO frequency, the phase alignment is lost, and we need to perform phase adjustments again.
We would like to understand why the phase relationship between the RX channels is not maintained after MCS and why changing the LO frequency causes the phase alignment to be lost.
2. External LO Configuration for Phase Synchronization
Our understanding is that using a common external LO source for both AD9361 devices may help achieve better phase synchronization and maintain a consistent phase relationship between the RX channels.
We would like your guidance on the following:
1. Is using a common external LO source for both AD9361 devices the recommended approach to achieve phase synchronization across all four RX channels of the FMCOMMS5?
2. Are any hardware modifications required on the FMCOMMS5 board to distribute a common external LO to both AD9361 devices?
3. What software, driver, or device-tree modifications are required to enable external LO operation?
I used this https://github.com/analogdevicesinc/linux/blob/main/arch/arm64/boot/dts/xilinx/zynqmp-zcu102-rev10-ad9361-fmcomms5-ext-lo-adf5355.dts for the SW change.
We would appreciate your guidance on the recommended hardware and software configuration to achieve reliable phase synchronization across both AD9361 devices.
  • Hi
    For FMCOMMS5, we request to follow the wiki page for MCS and phase calibration.
    Synchronizing multiple AD9361 devices [Analog Devices Wiki]
    For Rx/Tx Phase synchronization, we recommend using external LO. But still we need to do manual calibration to store the information in LUT. whenever the LO changes accordingly restore the calibration to align the phase between channels.
    SJ
  • Hi SJ,
    Thanks for the response.
    I have a few more questions:
    1. Is there any reference code or example available for storing the phase calibration values in a LUT and retrieving them whenever the LO frequency changes?
    2. Do we need any hardware modifications on the FMCOMMS5 board to use an external LO?
    3. The Wiki link you shared explains MCS and phase calibration, but I couldn't find details about how to configure and use an external LO with FMCOMMS5. Is there any reference design or documentation available for this?
    4. Regarding phase calibration, we are currently taking RX1A as the reference and calculating the phase differences of RX2A, RX1B and RX2B with respect to RX1A. We then apply phase rotation to align the other three channels using pyadi scripts.
    Thanks.
