AD9364 1.3 V supplies: per-domain max current and worst-case load step (LDO / PDN sizing)
The user inquires about sizing 1.3 V LDOs and their decoupling for the AD9364, specifically the current values for VDDD1P3_DIG, VDDA1P3_BB, and VDDA1P3_TX_LO_BUFFER. The final answer confirms that the current consumption for these rails is similar for 1T1R and 2T2R configurations, with a maximum current step of 150-300 mA during transitions like ENSM Alert to Rx/Tx, TDD Rx to Tx, and Tx attenuation change. The worst-case figures are available in the performance tables of the AD9364 datasheet.
Product Number: AD9364
TL;DR: sizing two 1.3 V LDOs and their decoupling for AD9364; the data sheet gives only the typical sum of all 1.3 V supplies (Rev. C, Tables 5-10).
Split (as in UG-673 p116): LDO 1 = VDDA1P3_RX_RF, VDDA1P3_RX_TX, VDDA1P3_TX_LO_BUFFER, VDDA1P3_BB, VDDD1P3_DIG and the Tx balun DC feed; LDO 2 = VDDA1P3_TX/RX_VCO_LDO, VDDA1P3_TX/RX_LO, VDDA1P3_TX/RX_SYNTH.
1) Thread 80542 lists approximate per-net currents for AD9361. Do they apply to AD9364 (1T1R), and what are the values for VDDD1P3_DIG, VDDA1P3_BB and VDDA1P3_TX_LO_BUFFER?
2) Is there a worst-case (max over process/voltage/temperature) figure, or a recommended factor over the typical tables?
3) What is the largest current step on the 1.3 V supplies and its rise time (e.g. ENSM Alert to Rx/Tx, TDD Rx to Tx, Tx attenuation change)? UG-673 Fig. 89-91 show the voltage transient, not the current.
Thanks!
  • HI
    These rails will be common for both the channels or both devices, so their consumption will be almost same for both 1T1R or 2T2R configurations.
    It is already available in performance tables with maximum and minimum in respective operation conditions (it is available at the start of the table).
    The following rails (VDDA1P3_BB and TX BALUN DC FEED) current consumption changes are mostly based on no. of channels enabled or disabled and also if it is operated in TDD operation (e.g. ENSM Alert to Rx/Tx, TDD Rx to Tx, Tx attenuation change). it would approximately around 150-300mA as maximum. Please check your power rails accordingly.
    SJ
