AD9364 CMOS input overshoot vs abs-max (-0.3 V / VDD_INTERFACE+0.3 V): transient allowance?
The user asks if a few-ns overshoot beyond the AD9364's CMOS logic input abs-max (-0.3 V / VDD_INTERFACE+0.3 V) is acceptable when the clamp current remains within ±10 mA. The final answer confirms that some overshoot and undershoot are expected but should be minimized through proper drive strength and slew rate settings. For the CMOS interface, using DRIVE 4 SLEW SLOW or series resistors on the FPGA side is recommended to reduce overshoot.
Category: Datasheet/Specs
Product Number: AD9364
TL;DR: board SI sims show ns-long overshoot on AD9364 CMOS logic inputs beyond the Table 11 abs-max (-0.3 V / VDD_INTERFACE+0.3 V), while the clamp current stays well below the +-10 mA rating. ADALM-PLUTO Rev D shows the same with the same method. Is this acceptable?
Setup: AD9364BBCZ, VDD_INTERFACE 1.8 V, CMOS interface, driven by Zynq-7010 LVCMOS18 (same topology as ADALM-PLUTO Rev D).
Sim (IBIS, PowerSI + SPDSIM, max corner):
  • Zynq DRIVE 12 (default): 14 of 23 inputs exceed; worst 2.62 V / -0.83 V; clamp current 1.9 / -3.6 mA.
  • Zynq DRIVE 4 SLEW SLOW: 3 of 23 exceed; worst -0.52 V.
  • ADALM-PLUTO Rev D, same method: all inputs exceed; worst 2.50 V / -0.74 V.
Questions:
  1. Is a few-ns overshoot beyond -0.3 V / VDD_INTERFACE+0.3 V acceptable when the input current stays within +-10 mA? Is there any duration rule?
  2. For the CMOS interface, do you recommend DRIVE 4 SLEW SLOW (or series resistors) on the FPGA side, or is the Pluto default considered safe?
Related: thread 594451 (static levels only). Thanks!
  • HI
    I will try to answer this briefly. For interface lines carrying high-speed digital data, some amount of overshoot and undershoot during signal transitions is expected. The magnitude of these transients depends on the PCB interconnect characteristics, parasitic capacitance, device-pin capacitance, driver strength, signal edge rate, and interface speed. Such transient behavior is primarily a signal-integrity consideration, and excessive overshoot or undershoot should be minimized through appropriate drive-strength and slew-rate settings, PCB layout, and termination where necessary.
    SJ
