I need some help and suggestions regarding communication with MAX2223 and AD9364 using the MSP430F5529. I am trying to communicate with the MAX2223 IC through I²C and with the AD9364 through SPI, both using the MSP430F5529.
The user is experiencing issues with I²C communication with the MAX2223 and SPI communication with the AD9364 using the MSP430F5529LP. The final answer suggests checking the SPI timing at 1MHz or lower and verifying SPI read/write operations to the scratch pad and device registers. The user should also ensure proper I²C address configuration and pull-up resistors for the MAX2223.
Product Number: MAX2223 IC
Hi Team,
I need some help and suggestions regarding communication with MAX2223 and AD9364 using the MSP430F5529LP.
I am trying to communicate with the MAX2223 IC through I²C and with the AD9364 through SPI, both using the MSP430F5529LP.
For the MAX2223, I configured it for a 7-bit I²C address by grounding Pin 28, but I am still unable to establish I²C communication.
I also tested SPI communication with the AD9364, but that is not working either.
Both the MAX2223 board and the AD9364 board are custom-designed boards. I have already checked the basic power supply and signal connections.
Could anyone please suggest what else I should verify? In particular, I would appreciate guidance on:
  • MAX2223 I²C address configuration and pull-up resistors 4.7 K ohms Provided for SDA and SCL.
  • MSP430F5529 I²C configuration
  • AD9364 SPI timing and connection requirements
  • Clock, reset, chip-select, and signal-level checks
Any suggestions for debugging these communication issues would be very helpful.
Thank you in advance.
