Phase Coherence Issue During Manual TX/RX LO Frequency Switching
Product Number: ADRV9364-Z7020
Dear ADI Support Team,
We are testing the AD9364 on the ADRV 9364-Z7020 and manually changing both the TX and RX LO frequencies.
We observed that when we return to the same LO frequency, the measured phase at that particular LO is not repeatable across iterations. The phase values differ significantly even when the TX/RX LO frequencies are set back to the same values.
This indicates that the phase is not coherent after changing the TX/RX LO frequencies.
Could you please advise us on the recommended procedure or configuration to change LO Frequencies in  a Phase coherent manner ?
(Note: Phase Values are in degrees)
In the attached image, I have shown the approximate, rounded off phase values at each LO frequency. Iteration 1 is measured after power up, and Iteration 2 is measured after changing the TX/RX LO frequencies and returning to the same frequencies. The phase values are not repeatable, indicating that phase coherence is not maintained during LO frequency switching.
VN
  • HI
    The AD9364 uses independent fractional-N RF PLLs for the TX and RX local oscillators. When either LO frequency is changed, the corresponding PLL unlocks, retunes, and relocks. The absolute phase after relocking is not deterministic.
    Both the TX and RX PLLs can reacquire with different phase offsets. As a result, the measured TX-to-RX phase can change significantly, even though the LO frequencies, reference clock, sample rate, and RF path remain unchanged.
    The AD936x architecture does not provide RF-PLL phase memory or deterministic LO phase restart. We specifically note that the device does not support phase-coherent frequency hopping using its internal synthesizers. You may have to use the external PLL or synthesizer for LO and have to store and recall the calibration coefficients.
    For more details - Synchronizing multiple AD9361 devices [Analog Devices Wiki]
    SJ
