I would like to know if there are any specific considerations regarding grounding and digital noise when designing a custom PCB hosting an AD936x transciever. Should I put an analog ground separated from the digital ground ?
I have other components, such as a µC, that can introduce noise into the ground plane. My understanding is that it might be better to connect everything related to the RF synthesizer to an AGND plane. Similarly, for the balanced side of the RX balun, should it be connected to AGND?
Is there a more detailed layout guideline available than the layout section provided in the datasheet?
Thank you for your time.
