Failure to tune sampling clock at cold temperatures and higher sample rates
Product Number: AD9364
We have been using the AD9364 for a number of years in a design based on the FMCOMMS board. Recently, we noticed that some units fail to lock at cold temperatures. I've boiled the problem down to a fairly simple set of steps:
1. Initial part with the ADI  IIO driver.
2. Attempt to set the sampling frequency by using the command line interface:
echo 61440000 > /sys/devices/soc0/axi/e0006000.spi/spi_master/spi1/spi1.0/iio:device0/in_voltage_sampling_frequency
3. Check the error messages via dmesg, which reports the following:
ad9361 spi1.0: ad9361_dig_tune_delay: Tuning RX FAILED!
SAMPL CLK: 61440000 tuning: RX
0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
0:# # # # # # # # # # # # # # # #
1:# # # # # # # # # # # # # # # #
When this error occurs we do not get samples that we request over the IIO interface.
This made no difference that I can see. We are able to tune lower frequencies (below 57 MHz), but anything above that causes the error.
What else can I look at to figure out why we are having this issue? Some units do not appear to have the problem at all, but some consistently fail to tune the sampling clock.
-Dave
  • Hi  ,
    As the device is failing in the digital interface. we suspect on the interface lines behavior in the cold temp.
    Run bist_timing_analysis at cold and check passing windows with room temperature. Use the debugfs timing test to capture the actual delay map at room temperature and cold temperature, for both passing and failing units. Capture the digital tuning log from both good and bad units. ADI’s tuning algorithm sweeps delay settings and selects the midpoint of a passing region, so the selected value and available window width are very useful indicators. Check whether the working units choose delay values near the edge, for example 0, 1, 14, or 15. If yes, the tuning range is nearly exhausted. A unit that “passes” with an edge value is not healthy margin-wise.
    Please probe DATA_CLK and RX data/frame at cold.
    SJ
  • I've run the timing analysis at various temperatures and attached the full log. The most interesting results are from testing at -20 C. I will paste a subset of the results at the end of the message. I am unable to probe DATA_CLK and RX_FRAME because the traces are buried underneath the parts and on inner layers of the PCB.
    Seeing that the timing analysis fails, is there any adjustment I can do in the FPGA to compensate?
    -Dave
    Timing Analysis Results at -20 C
    root@localhost:/sys/kernel/debug/iio/iio:device0# echo 20479999 > /sys/bus/iio/devices/iio:device0/in_voltage_sampling_frequency
    root@localhost:/sys/kernel/debug/iio/iio:device0# echo 1 > bist_timing_analysis
    root@localhost:/sys/kernel/debug/iio/iio:device0# cat bist_timing_analysis
    CLK: 20479999 Hz 'o' = PASS
    DC0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    0:o o o o o . . . . . . . . . . .
    1:o o o o o o . . . . . . . . . .
    2:o o o o o o o . . . . . . . . .
    3:o o o o o o o o . . . . . . . .
    4:o o o o o o o o o . . . . . . .
    5:o o o o o o o o o o . . . . . .
    6:o o o o o o o o o o o . . . . .
    7:o o o o o o o o o o o o . . . .
    8:o o o o o o o o o o o o o . . .
    9:o o o o o o o o o o o o o o . .
    a:o o o o o o o o o o o o o o o .
    b:o o o o o o o o o o o o o o o o
    c:o o o o o o o o o o o o o o o o
    d:o o o o o o o o o o o o o o o o
    e:o o o o o o o o o o o o o o o o
    f:o o o o o o o o o o o o o o o o
    root@localhost:/sys/kernel/debug/iio/iio:device0# echo 61440000 > /sys/bus/iio/devices/iio:device0/in_voltage_sampling_frequency
    CLK: 61440000 Hz 'o' = PASS
    0:. . . . . . . . . . . . . . . .
    1:. . . . . . . . . . . . . . . .
    2:. . . . . . . . . . . . . . . .
    3:. . . . . . . . . . . . . . . .
    4:. . . . . . . . . . . . . . . .
    5:. . . . . . . . . . . . . . . .
    6:. . . . . . . . . . . . . . . .
    7:. . . . . . . . . . . . . . . .
    8:. . . . . . . . . . . . . . . .
    9:. . . . . . . . . . . . . . . .
    a:. . . . . . . . . . . . . . . .
    b:. . . . . . . . . . . . . . . .
    c:. . . . . . . . . . . . . . . .
    d:. . . . . . . . . . . . . . . .
    e:. . . . . . . . . . . . . . . .
    f:. . . . . . . . . . . . . . . .
    root@localhost:/sys/kernel/debug/iio/iio:device0# echo 60000000 > /sys/bus/iio/devices/iio:device0/in_voltage_sampling_frequency
    CLK: 60000000 Hz 'o' = PASS
    8:. . o . . . . . . . . . . . . .
    a:. . . . o . . . . . . . . . . .
    root@localhost:/sys/kernel/debug/iio/iio:device0# dmesg
    root@localhost:/sys/kernel/debug/iio/iio:device0# echo 59000000 > /sys/bus/iio/devices/iio:device0/in_voltage_sampling_frequency
    CLK: 59000000 Hz 'o' = PASS
    5:o . . . . . . . . . . . . . . .
    6:. o . . . . . . . . . . . . . .
    7:o o . . . . . . . . . . . . . .
    8:. o . . . . . . . . . . . . . .
    9:. . o . . . . . . . . . . . . .
    a:. . . o o . . . . . . . . . . .
    b:. . . o o o . . . . . . . . . .
    c:. . . . o o . . . . . . . . . .
    d:. . . . . o . . . . . . . . . .
    e:. . . . . . o . . . . . . . . .
    f:. . . . . . o o o . . . . . . .
  • HI  ,
    Looks like this board's signal integrity on LVDS signals is poor at lower temperatures. Please can you check the same behavior on working boards to get the better clarity.
    Also, can you provide the LVDS configuration details to check.
    SJ
  • Which LVDS configuration details do I need to provide? I'm new to the project and still trying to catch up with all the parameters. Are you talking about some configuration in the HDL / timing constraints? Or, are you talking about some specific register settings in the AD936x?
    Thanks.
  • HI
    Did you check BIST timing analysis on working board with same software.
    It may be the specific board signal integrity issue. Pls check how many such boards are reporting this issue.
    SJ
  • We are running short on testable units right now. I will test when I receive another working unit.
