I'm looking for the maximum and minimum power draws for the ADRV9361-Z7035. Ideally the max power draw would be measured with peak Tx output with the arm cores running and the minimum output be measured from a sleep or idle state of some sort.
HI colinsmith
Power consumption also depends on ADC and DAC-Sample rate configurations. Please provide the complete details to check for the specific ones.
SJ
Sample rate for both would be at 60Msa/s
HI colinsmith
Are you looking for AD9361 power consumption alone. Please can you try checking from the voltage rails and let us know.
REgards,
SJ
