FMCOMMS4 + ZC706: Low TX Output Power on NO-OS (-55 dBm) vs Kuiper Linux (-10 dBm)
The user experiences a significant drop in TX output power from -10 dBm to -55 dBm when using the NO-OS drivers with the AD-FMCOMMS4 board on a ZC706, compared to when using Kuiper Linux. Touching the FMC board or connector area temporarily restores the output power to -5 to +1 dBm. The support engineer suggests checking for power issues on the board or incorrect configuration and timing in the software or Linux.
Product Number: AD9364
Software Version: Vivado 2022.1, Xilinix 2022.1
I’m using the AD-FMCOMMS4 board with a ZC706. When I boot the system using Kuiper Linux, I get a TX output around 2.4 GHz and the output power level is approximately –10 dBm, which is expected.
However, when I run the NO-OS drivers, I still get the correct frequency (2.4 GHz), but the output power drops significantly to around –55 dBm. Interestingly, if I lightly touch the FMC board or the connector area, the TX output suddenly jumps to about –5 to +1 dBm.
Has anyone seen this behavior before? What could be causing this drastic difference in output power between NO-OS and Kuiper Linux, and why does touching the FMC board temporarily fix the issue?
Any insight or suggestions would be greatly appreciated. I have attached my main.c here.
 *   @file   ad9361/src/main.c
 *   @brief  Implementation of Main Function.
 *   @author DBogdan (dragos.bogdan@analog.com)
 * Copyright 2013(c) Analog Devices, Inc.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 *    this list of conditions and the following disclaimer in the documentation
 *    and/or other materials provided with the distribution.
 * 3. Neither the name of Analog Devices, Inc. nor the names of its
 *    contributors may be used to endorse or promote products derived from this
 *    software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES, INC. “AS IS” AND ANY EXPRESS OR
 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
 * EVENT SHALL ANALOG DEVICES, INC. BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
 * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
 * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
 * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <inttypes.h>
#include "app_config.h"
#include "ad9361_api.h"
#include "parameters.h"
#include "no_os_spi.h"
#include "no_os_gpio.h"
#include "no_os_delay.h"
#ifdef XILINX_PLATFORM
#include <xparameters.h>
#include <xil_cache.h>
#include "xilinx_spi.h"
#include "xilinx_gpio.h"
#include "no_os_irq.h"
#include "axi_sysid.h"
#ifdef ALTERA_PLATFORM
#include "altera_spi.h"
#include "altera_gpio.h"
#endif
#endif
#ifdef LINUX_PLATFORM
#include "linux_spi.h"
#include "linux_gpio.h"
#else
#include "xilinx_irq.h"
#endif //LINUX
#include "axi_adc_core.h"
#include "axi_dac_core.h"
#include "axi_dmac.h"
#include "no_os_error.h"
#ifdef IIO_SUPPORT
#include "iio_axi_adc.h"
#include "iio_axi_dac.h"
#include "iio_ad9361.h"
#include "no_os_uart.h"
#include "iio_app.h"
#include "xilinx_uart.h"
#include "xil_cache.h"
#endif //XILINX
#if defined LINUX_PLATFORM || defined GENERIC_PLATFORM
static uint8_t in_buff[MAX_SIZE_BASE_ADDR];
static uint8_t out_buff[MAX_SIZE_BASE_ADDR];
#endif
#endif // IIO_SUPPORT
#if defined(DMA_EXAMPLE) || defined(SYSID_BASEADDR)
#include <string.h>
#endif
#if defined(DMA_EXAMPLE) || defined(IIO_SUPPORT)
uint32_t dac_buffer[DAC_BUFFER_SAMPLES] __attribute__((aligned(1024)));
#endif
uint16_t adc_buffer[ADC_BUFFER_SAMPLES * ADC_CHANNELS] __attribute__((
			aligned(1024)));
#define AD9361_ADC_DAC_BYTES_PER_SAMPLE 2
struct xil_spi_init_param xil_spi_param = {
#ifdef PLATFORM_MB
	.type = SPI_PL,
#else
	.type = SPI_PS,
#endif
	.flags = 0
struct xil_gpio_init_param xil_gpio_param = {
#ifdef PLATFORM_MB
	.type = GPIO_PL,
#else
	.type = GPIO_PS,
#endif
	.device_id = GPIO_DEVICE_ID
#define GPIO_OPS	&xil_gpio_ops
#define SPI_OPS		&xil_spi_ops
#define GPIO_PARAM	&xil_gpio_param
#define SPI_PARAM	&xil_spi_param
#endif
#ifdef GENERIC_PLATFORM
#define GPIO_OPS	&generic_gpio_ops
#define SPI_OPS		&generic_spi_ops
#define GPIO_PARAM	NULL
#define SPI_PARAM	NULL
#endif
#endif
#define GPIO_OPS	&linux_gpio_ops
#define SPI_OPS		&linux_spi_ops
#endif
struct axi_adc_init rx_adc_init = {
	.name = "cf-ad9361-lpc",
	.base = RX_CORE_BASEADDR,
#ifdef FMCOMMS5
	.slave_base = AD9361_RX_1_BASEADDR,
	.num_channels = 8,
#else
	.num_channels = 4,
#endif
	.num_slave_channels =  4
struct axi_dac_init tx_dac_init = {
	"cf-ad9361-dds-core-lpc",
	TX_CORE_BASEADDR,
	4,
	NULL,
	3
struct axi_dmac_init rx_dmac_init = {
	"rx_dmac",
	CF_AD9361_RX_DMA_BASEADDR,
#ifdef DMA_IRQ_ENABLE
	IRQ_ENABLED
#else
	IRQ_DISABLED
#endif
struct axi_dmac *rx_dmac;
struct axi_dmac_init tx_dmac_init = {
	"tx_dmac",
	CF_AD9361_TX_DMA_BASEADDR,
	IRQ_ENABLED
#else
	IRQ_DISABLED
#endif
struct axi_dmac *tx_dmac;
AD9361_InitParam default_init_param = {
	/* Device selection */
	ID_AD9361,	// dev_sel
	/* Reference Clock */
	40000000UL,	//reference_clk_rate
	/* Base Configuration */
	1,		//two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
	1,		//one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num
	1,		//one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num
	1,		//frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
	0,		//frequency_division_duplex_independent_mode_enable *** adi,frequency-division-duplex-independent-mode-enable
	0,		//tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
	0,		//tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
	0,		//tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
	0,		//rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
	0,		//rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
	0,		//tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
	0,		//external_rx_lo_enable *** adi,external-rx-lo-enable
	0,		//external_tx_lo_enable *** adi,external-tx-lo-enable
	5,		//dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
	6,		//dc_offset_attenuation_high_range *** adi,dc-offset-attenuation-high-range
	5,		//dc_offset_attenuation_low_range *** adi,dc-offset-attenuation-low-range
	0x28,	//dc_offset_count_high_range *** adi,dc-offset-count-high-range
	0x32,	//dc_offset_count_low_range *** adi,dc-offset-count-low-range
	0,		//split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
	MAX_SYNTH_FREF,	//trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
	0,		// qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable
	/* ENSM Control */
	0,		//ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
	0,		//ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
	/* LO Control */
	2400000000UL,	//rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
	2400000000UL,	//tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
	1,				//tx_lo_powerdown_managed_enable *** adi,tx-lo-powerdown-managed-enable
	/* Rate & BW Control */
	{983040000, 245760000, 122880000, 61440000, 30720000, 30720000},// rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
	{983040000, 122880000, 122880000, 61440000, 30720000, 30720000},// tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
	18000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
	18000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
	/* RF Port Control */
	0,		//rx_rf_port_input_select *** adi,rx-rf-port-input-select
	0,		//tx_rf_port_input_select *** adi,tx-rf-port-input-select
	/* TX Attenuation Control */
	10000,	//tx_attenuation_mdB *** adi,tx-attenuation-mdB
	0,		//update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
	/* Reference Clock Control */
	0,		//xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
	{8, 5920},	//dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
	CLKOUT_DISABLE,	//clk_output_mode_select *** adi,clk-output-mode-select
	/* Gain Control */
	2,		//gc_rx1_mode *** adi,gc-rx1-mode
	2,		//gc_rx2_mode *** adi,gc-rx2-mode
	58,		//gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
	4,		//gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
	47,		//gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
	8192,	//gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
	0,		//gc_dig_gain_enable *** adi,gc-dig-gain-enable
	800,	//gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
	704,	//gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
	24,		//gc_low_power_thresh *** adi,gc-low-power-thresh
	15,		//gc_max_dig_gain *** adi,gc-max-dig-gain
	0,		//gc_use_rx_fir_out_for_dec_pwr_meas_enable *** adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable
	/* Gain MGC Control */
	2,		//mgc_dec_gain_step *** adi,mgc-dec-gain-step
	2,		//mgc_inc_gain_step *** adi,mgc-inc-gain-step
	0,		//mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
	0,		//mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
	0,		//mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
	/* Gain AGC Control */
	10,		//agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
	2,		//agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
	0,		//agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
	10,		//agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
	4,		//agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
	3,		//agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
	1000,	// agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
	0,		//agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
	0,		//agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
	10,		//agc_inner_thresh_high *** adi,agc-inner-thresh-high
	1,		//agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
	12,		//agc_inner_thresh_low *** adi,agc-inner-thresh-low
	1,		//agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
	10,		//agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
	2,		//agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
	10,		//agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
	5,		//agc_outer_thresh_high *** adi,agc-outer-thresh-high
	2,		//agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
	18,		//agc_outer_thresh_low *** adi,agc-outer-thresh-low
	2,		//agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
	1,		//agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
	0,		//agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
	/* Fast AGC */
	64,		//fagc_dec_pow_measuremnt_duration ***  adi,fagc-dec-pow-measurement-duration
	260,	//fagc_state_wait_time_ns ***  adi,fagc-state-wait-time-ns
	/* Fast AGC - Low Power */
	0,		//fagc_allow_agc_gain_increase ***  adi,fagc-allow-agc-gain-increase-enable
	5,		//fagc_lp_thresh_increment_time ***  adi,fagc-lp-thresh-increment-time
	1,		//fagc_lp_thresh_increment_steps ***  adi,fagc-lp-thresh-increment-steps
	/* Fast AGC - Lock Level (Lock Level is set via slow AGC inner high threshold) */
	1,		//fagc_lock_level_lmt_gain_increase_en ***  adi,fagc-lock-level-lmt-gain-increase-enable
	5,		//fagc_lock_level_gain_increase_upper_limit ***  adi,fagc-lock-level-gain-increase-upper-limit
	/* Fast AGC - Peak Detectors and Final Settling */
	1,		//fagc_lpf_final_settling_steps ***  adi,fagc-lpf-final-settling-steps
	1,		//fagc_lmt_final_settling_steps ***  adi,fagc-lmt-final-settling-steps
	3,		//fagc_final_overrange_count ***  adi,fagc-final-overrange-count
	/* Fast AGC - Final Power Test */
	0,		//fagc_gain_increase_after_gain_lock_en ***  adi,fagc-gain-increase-after-gain-lock-enable
	/* Fast AGC - Unlocking the Gain */
	0,		//fagc_gain_index_type_after_exit_rx_mode ***  adi,fagc-gain-index-type-after-exit-rx-mode
	1,		//fagc_use_last_lock_level_for_set_gain_en ***  adi,fagc-use-last-lock-level-for-set-gain-enable
	1,		//fagc_rst_gla_stronger_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
	5,		//fagc_optimized_gain_offset ***  adi,fagc-optimized-gain-offset
	10,		//fagc_rst_gla_stronger_sig_thresh_above_ll ***  adi,fagc-rst-gla-stronger-sig-thresh-above-ll
	1,		//fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
	1,		//fagc_rst_gla_engergy_lost_goto_optim_gain_en ***  adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
	10,		//fagc_rst_gla_engergy_lost_sig_thresh_below_ll ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
	8,		//fagc_energy_lost_stronger_sig_gain_lock_exit_cnt ***  adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
	1,		//fagc_rst_gla_large_adc_overload_en ***  adi,fagc-rst-gla-large-adc-overload-enable
	1,		//fagc_rst_gla_large_lmt_overload_en ***  adi,fagc-rst-gla-large-lmt-overload-enable
	0,		//fagc_rst_gla_en_agc_pulled_high_en ***  adi,fagc-rst-gla-en-agc-pulled-high-enable
	0,		//fagc_rst_gla_if_en_agc_pulled_high_mode ***  adi,fagc-rst-gla-if-en-agc-pulled-high-mode
	64,		//fagc_power_measurement_duration_in_state5 ***  adi,fagc-power-measurement-duration-in-state5
	2,		//fagc_large_overload_inc_steps *** adi,fagc-adc-large-overload-inc-steps
	/* RSSI Control */
	1,		//rssi_delay *** adi,rssi-delay
	1000,	//rssi_duration *** adi,rssi-duration
	3,		//rssi_restart_mode *** adi,rssi-restart-mode
	0,		//rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
	1,		//rssi_wait *** adi,rssi-wait
	/* Aux ADC Control */
	256,	//aux_adc_decimation *** adi,aux-adc-decimation
	40000000UL,	//aux_adc_rate *** adi,aux-adc-rate
	/* AuxDAC Control */
	1,		//aux_dac_manual_mode_enable ***  adi,aux-dac-manual-mode-enable
	0,		//aux_dac1_default_value_mV ***  adi,aux-dac1-default-value-mV
	0,		//aux_dac1_active_in_rx_enable ***  adi,aux-dac1-active-in-rx-enable
	0,		//aux_dac1_active_in_tx_enable ***  adi,aux-dac1-active-in-tx-enable
	0,		//aux_dac1_active_in_alert_enable ***  adi,aux-dac1-active-in-alert-enable
	0,		//aux_dac1_rx_delay_us ***  adi,aux-dac1-rx-delay-us
	0,		//aux_dac1_tx_delay_us ***  adi,aux-dac1-tx-delay-us
	0,		//aux_dac2_default_value_mV ***  adi,aux-dac2-default-value-mV
	0,		//aux_dac2_active_in_rx_enable ***  adi,aux-dac2-active-in-rx-enable
	0,		//aux_dac2_active_in_tx_enable ***  adi,aux-dac2-active-in-tx-enable
	0,		//aux_dac2_active_in_alert_enable ***  adi,aux-dac2-active-in-alert-enable
	0,		//aux_dac2_rx_delay_us ***  adi,aux-dac2-rx-delay-us
	0,		//aux_dac2_tx_delay_us ***  adi,aux-dac2-tx-delay-us
	/* Temperature Sensor Control */
	256,	//temp_sense_decimation *** adi,temp-sense-decimation
	1000,	//temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
	0xCE,	//temp_sense_offset_signed *** adi,temp-sense-offset-signed
	1,		//temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
	/* Control Out Setup */
	0xFF,	//ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
	0,		//ctrl_outs_index *** adi,ctrl-outs-index
	/* External LNA Control */
	0,		//elna_settling_delay_ns *** adi,elna-settling-delay-ns
	0,		//elna_gain_mdB *** adi,elna-gain-mdB
	0,		//elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
	0,		//elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
	0,		//elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
	0,		//elna_gaintable_all_index_enable *** adi,elna-gaintable-all-index-enable
	/* Digital Interface Control */
	0,		//digital_interface_tune_skip_mode *** adi,digital-interface-tune-skip-mode
	0,		//digital_interface_tune_fir_disable *** adi,digital-interface-tune-fir-disable
	1,		//pp_tx_swap_enable *** adi,pp-tx-swap-enable
	1,		//pp_rx_swap_enable *** adi,pp-rx-swap-enable
	0,		//tx_channel_swap_enable *** adi,tx-channel-swap-enable
	0,		//rx_channel_swap_enable *** adi,rx-channel-swap-enable
	1,		//rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
	0,		//two_t_two_r_timing_enable *** adi,2t2r-timing-enable
	0,		//invert_data_bus_enable *** adi,invert-data-bus-enable
	0,		//invert_data_clk_enable *** adi,invert-data-clk-enable
	0,		//fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
	0,		//invert_rx_frame_enable *** adi,invert-rx-frame-enable
	0,		//fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
	0,		//swap_ports_enable *** adi,swap-ports-enable
	0,		//single_data_rate_enable *** adi,single-data-rate-enable
	1,		//lvds_mode_enable *** adi,lvds-mode-enable
	0,		//half_duplex_mode_enable *** adi,half-duplex-mode-enable
	0,		//single_port_mode_enable *** adi,single-port-mode-enable
	0,		//full_port_enable *** adi,full-port-enable
	0,		//full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
	0,		//delay_rx_data *** adi,delay-rx-data
	0,		//rx_data_clock_delay *** adi,rx-data-clock-delay
	4,		//rx_data_delay *** adi,rx-data-delay
	7,		//tx_fb_clock_delay *** adi,tx-fb-clock-delay
	0,		//tx_data_delay *** adi,tx-data-delay
	300,	//lvds_bias_mV *** adi,lvds-bias-mV
#else
	150,	//lvds_bias_mV *** adi,lvds-bias-mV
#endif
	1,		//lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
	0,		//rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
	0xFF,	//lvds_invert1_control *** adi,lvds-invert1-control
	0x0F,	//lvds_invert2_control *** adi,lvds-invert2-control
	/* GPO Control */
	0,		//gpo_manual_mode_enable *** adi,gpo-manual-mode-enable
	0,		//gpo_manual_mode_enable_mask *** adi,gpo-manual-mode-enable-mask
	0,		//gpo0_inactive_state_high_enable *** adi,gpo0-inactive-state-high-enable
	0,		//gpo1_inactive_state_high_enable *** adi,gpo1-inactive-state-high-enable
	0,		//gpo2_inactive_state_high_enable *** adi,gpo2-inactive-state-high-enable
	0,		//gpo3_inactive_state_high_enable *** adi,gpo3-inactive-state-high-enable
	0,		//gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable
	0,		//gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable
	0,		//gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable
	0,		//gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable
	0,		//gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable
	0,		//gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable
	0,		//gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable
	0,		//gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable
	0,		//gpo0_rx_delay_us *** adi,gpo0-rx-delay-us
	0,		//gpo0_tx_delay_us *** adi,gpo0-tx-delay-us
	0,		//gpo1_rx_delay_us *** adi,gpo1-rx-delay-us
	0,		//gpo1_tx_delay_us *** adi,gpo1-tx-delay-us
	0,		//gpo2_rx_delay_us *** adi,gpo2-rx-delay-us
	0,		//gpo2_tx_delay_us *** adi,gpo2-tx-delay-us
	0,		//gpo3_rx_delay_us *** adi,gpo3-rx-delay-us
	0,		//gpo3_tx_delay_us *** adi,gpo3-tx-delay-us
	/* Tx Monitor Control */
	37000,	//low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
	0,		//low_gain_dB *** adi,txmon-low-gain
	24,		//high_gain_dB *** adi,txmon-high-gain
	0,		//tx_mon_track_en *** adi,txmon-dc-tracking-enable
	0,		//one_shot_mode_en *** adi,txmon-one-shot-mode-enable
	511,	//tx_mon_delay *** adi,txmon-delay
	8192,	//tx_mon_duration *** adi,txmon-duration
	2,		//tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
	2,		//tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
	48,		//tx1_mon_lo_cm *** adi,txmon-1-lo-cm
	48,		//tx2_mon_lo_cm *** adi,txmon-2-lo-cm
	/* GPIO definitions */
		.number = -1,
		.platform_ops = GPIO_OPS,
		.extra = GPIO_PARAM
	},		//gpio_resetb *** reset-gpios
	/* MCS Sync */
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_sync *** sync-gpios
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_cal_sw1 *** cal-sw1-gpios
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_cal_sw2 *** cal-sw2-gpios
		.device_id = SPI_DEVICE_ID,
		.mode = NO_OS_SPI_MODE_1,
		.chip_select = SPI_CS,
		.platform_ops = SPI_OPS,
		.extra = SPI_PARAM
	/* External LO clocks */
	NULL,	//(*ad9361_rfpll_ext_recalc_rate)()
	NULL,	//(*ad9361_rfpll_ext_round_rate)()
	NULL,	//(*ad9361_rfpll_ext_set_rate)()
#ifndef AXI_ADC_NOT_PRESENT
	&rx_adc_init,	// *rx_adc_init
	&tx_dac_init,   // *tx_dac_init
#endif
AD9361_RXFIRConfig rx_fir_config = {	// BPF PASSBAND 3/20 fs to 1/4 fs
	3, // rx
	0, // rx_gain
	1, // rx_dec
		-4, -6, -37, 35, 186, 86, -284, -315,
			107, 219, -4, 271, 558, -307, -1182, -356,
			658, 157, 207, 1648, 790, -2525, -2553, 748,
			865, -476, 3737, 6560, -3583, -14731, -5278, 14819,
			14819, -5278, -14731, -3583, 6560, 3737, -476, 865,
			748, -2553, -2525, 790, 1648, 207, 157, 658,
			-356, -1182, -307, 558, 271, -4, 219, 107,
			-315, -284, 86, 186, 35, -37, -6, -4,
			0, 0, 0, 0, 0, 0, 0, 0,
		}, // rx_coef[128]
	64, // rx_coef_size
	{0, 0, 0, 0, 0, 0}, //rx_path_clks[6]
	0 // rx_bandwidth
AD9361_TXFIRConfig tx_fir_config = {	// BPF PASSBAND 3/20 fs to 1/4 fs
	3, // tx
	-6, // tx_gain
	1, // tx_int
		}, // tx_coef[128]
	64, // tx_coef_size
	{0, 0, 0, 0, 0, 0}, // tx_path_clks[6]
	0 // tx_bandwidth
struct ad9361_rf_phy *ad9361_phy;
#ifdef FMCOMMS5
struct ad9361_rf_phy *ad9361_phy_b;
#endif
 * @brief main
int main(void)
	int32_t status;
	Xil_ICacheEnable();
	Xil_DCacheEnable();
	default_init_param.spi_param.extra = &xil_spi_param;
	default_init_param.spi_param.platform_ops = &xil_spi_ops;
#endif
	default_init_param.spi_param.platform_ops = &altera_spi_ops;
	if (altera_bridge_init()) {
		printf("Altera Bridge Init Error!\n");
		return -1;
#endif
	// NOTE: The user has to choose the GPIO numbers according to desired
	// carrier board.
	default_init_param.gpio_resetb.number = GPIO_RESET_PIN;
#ifdef FMCOMMS5
	default_init_param.gpio_sync.number = GPIO_SYNC_PIN;
	default_init_param.gpio_cal_sw1.number = GPIO_CAL_SW1_PIN;
	default_init_param.gpio_cal_sw2.number = GPIO_CAL_SW2_PIN;
	default_init_param.rx1rx2_phase_inversion_en = 1;
#else
	default_init_param.gpio_sync.number = -1;
	default_init_param.gpio_cal_sw1.number = -1;
	default_init_param.gpio_cal_sw2.number = -1;
#endif
	if (AD9364_DEVICE) {
		default_init_param.dev_sel = ID_AD9364;
		tx_dac_init.num_channels = 2;
		tx_dac_init.rate = 1;
		rx_adc_init.num_channels = 2;
		rx_adc_init.num_slave_channels = 0;
	} else {
		if (!default_init_param.two_rx_two_tx_mode_enable) {
	if (AD9363A_DEVICE)
		default_init_param.dev_sel = ID_AD9363A;
#if defined FMCOMMS5 || defined ADI_RF_SOM || defined ADI_RF_SOM_CMOS
	default_init_param.xo_disable_use_ext_refclk_enable = 1;
#endif
#ifdef ADI_RF_SOM_CMOS
	if (AD9361_DEVICE)
		default_init_param.swap_ports_enable = 1;
	default_init_param.lvds_mode_enable = 0;
	default_init_param.lvds_rx_onchip_termination_enable = 0;
	default_init_param.full_port_enable = 1;
	default_init_param.digital_interface_tune_fir_disable = 1;
#endif
	ad9361_init(&ad9361_phy, &default_init_param);
	ad9361_set_tx_fir_config(ad9361_phy, tx_fir_config);
	ad9361_set_rx_fir_config(ad9361_phy, rx_fir_config);
#ifdef FMCOMMS5
	gpio_init(default_init_param.gpio_sync);
#endif
	default_init_param.spi_param.chip_select = SPI_CS_2;
	default_init_param.gpio_resetb.number = GPIO_RESET_PIN_2;
	gpio_init(default_init_param.gpio_resetb);
#endif
	default_init_param.rx_synthesizer_frequency_hz = 2300000000UL;
	default_init_param.tx_synthesizer_frequency_hz = 2300000000UL;
	rx_adc_init.base = AD9361_RX_1_BASEADDR;
	tx_dac_init.base = AD9361_TX_1_BASEADDR;
	ad9361_init(&ad9361_phy_b, &default_init_param);
	ad9361_set_tx_fir_config(ad9361_phy_b, tx_fir_config);
	ad9361_set_rx_fir_config(ad9361_phy_b, rx_fir_config);
#endif
	status = axi_dmac_init(&tx_dmac, &tx_dmac_init);
	if (status < 0) {
		printf("axi_dmac_init tx init error: %"PRIi32"\n", status);
		return status;
	status = axi_dmac_init(&rx_dmac, &rx_dmac_init);
	if (status < 0) {
		printf("axi_dmac_init rx init error: %"PRIi32"\n", status);
		return status;
#if defined XILINX_PLATFORM || defined LINUX_PLATFORM || defined ALTERA_PLATFORM
#ifdef DMA_EXAMPLE
#ifdef FMCOMMS5
	axi_dac_init(&ad9361_phy_b->tx_dac, &tx_dac_init);
	axi_dac_set_datasel(ad9361_phy_b->tx_dac, -1, AXI_DAC_DATA_SEL_DMA);
	rx_adc_init.base = AD9361_RX_0_BASEADDR;
	rx_adc_init.num_slave_channels = 4;
	tx_dac_init.base = AD9361_TX_0_BASEADDR;
#endif
	axi_dac_init(&ad9361_phy->tx_dac, &tx_dac_init);
	extern const uint32_t sine_lut_iq[1024];
	axi_dac_set_datasel(ad9361_phy->tx_dac, -1, AXI_DAC_DATA_SEL_DMA);
	axi_dac_load_custom_data(ad9361_phy->tx_dac, sine_lut_iq,
				 NO_OS_ARRAY_SIZE(sine_lut_iq),
				 (uintptr_t)dac_buffer);
	Xil_DCacheFlush();
#endif
#else
#ifdef FMCOMMS5
	axi_dac_set_datasel(ad9361_phy_b->tx_dac, -1, AXI_DAC_DATA_SEL_DDS);
#endif
	axi_dac_set_datasel(ad9361_phy->tx_dac, -1, AXI_DAC_DATA_SEL_DDS);
#endif
#endif
#endif
#ifdef FMCOMMS5
	ad9361_do_mcs(ad9361_phy, ad9361_phy_b);
#endif
#if (defined XILINX_PLATFORM || defined ALTERA_PLATFORM)
	uint32_t samples = 16384;
#if (defined DMA_IRQ_ENABLE)
	 * Xilinx platform dependent initialization for IRQ.
	struct xil_irq_init_param xil_irq_init_par = {
		.type = IRQ_PS,
	 * IRQ initial configuration.
	struct no_os_irq_init_param irq_init_param = {
		.irq_ctrl_id = INTC_DEVICE_ID,
		.platform_ops = &xil_irq_ops,
		.extra = &xil_irq_init_par,
	 * IRQ instance.
	struct no_os_irq_ctrl_desc *irq_desc;
	status = no_os_irq_ctrl_init(&irq_desc, &irq_init_param);
	if (status < 0)
		return status;
	status = no_os_irq_global_enable(irq_desc);
	if (status < 0)
		return status;
	struct no_os_callback_desc rx_dmac_callback = {
		.ctx = rx_dmac,
		.callback = axi_dmac_dev_to_mem_isr,
	status = no_os_irq_register_callback(irq_desc,
					     AD9361_ADC_DMA_IRQ_INTR, &rx_dmac_callback);
	if (status < 0)
		return status;
	status = no_os_irq_trigger_level_set(irq_desc,
					     AD9361_ADC_DMA_IRQ_INTR, NO_OS_IRQ_LEVEL_HIGH);
	if (status < 0)
		return status;
	status = no_os_irq_enable(irq_desc, AD9361_ADC_DMA_IRQ_INTR);
	if (status < 0)
		return status;
	samples = 2048;
#endif
	// NOTE: To prevent unwanted data loss, it's recommended to invalidate
	// cache after each axi_dmac_transfer_start() call, keeping in mind that the
	// size of the capture and the start address must be aligned to the size
	// of the cache line.
#ifdef DMA_EXAMPLE
	struct no_os_callback_desc tx_dmac_callback = {
		.ctx = tx_dmac,
		.callback = axi_dmac_mem_to_dev_isr,
					     AD9361_DAC_DMA_IRQ_INTR, &tx_dmac_callback);
	if (status < 0)
		return status;
	status = no_os_irq_enable(irq_desc, AD9361_DAC_DMA_IRQ_INTR);
	if (status < 0)
		return status;
#endif
	struct axi_dma_transfer transfer = {
		// Number of bytes to write/read
		.size = sizeof(sine_lut_iq),
		// Transfer done flag
		.transfer_done = 0,
		// Signal transfer mode
		.cyclic = CYCLIC,
		// Address of data source
		.src_addr = (uintptr_t)dac_buffer,
		// Address of data destination
		.dest_addr = 0
	/* Transfer the data. */
	axi_dmac_transfer_start(tx_dmac, &transfer);
	/* Flush cache data. */
	Xil_DCacheInvalidateRange((uintptr_t)dac_buffer, sizeof(sine_lut_iq));
	no_os_mdelay(1000);
#endif
#ifdef FMCOMMS5
	struct axi_dma_transfer read_transfer = {
		.size = samples * AD9361_ADC_DAC_BYTES_PER_SAMPLE * ad9361_phy->rx_adc->num_channels,
		.transfer_done = 0,
		.cyclic = NO,
		.src_addr = 0,
		.dest_addr = (uintptr_t)ADC_DDR_BASEADDR
	/* Read the data from the ADC DMA. */
	axi_dmac_transfer_start(rx_dmac, &read_transfer);
	/* Wait until transfer finishes */
	status = axi_dmac_transfer_wait_completion(rx_dmac, 500);
	if (status < 0)
		return status;
#else
		.size = sizeof(adc_buffer),
		.transfer_done = 0,
		.cyclic = NO,
		.src_addr = 0,
		.dest_addr = (uintptr_t)adc_buffer
	if (status < 0)
		return status;
#endif
#ifdef FMCOMMS5
	Xil_DCacheInvalidateRange((uintptr_t)ADC_DDR_BASEADDR,
				  ad9361_phy->rx_adc->num_channels);
	printf("DMA_EXAMPLE: address=%#x samples=%lu channels=%u bits=%u\n",
	       read_transfer.size / AD9361_ADC_DAC_BYTES_PER_SAMPLE,
	       rx_adc_init.num_channels,
	       8 * sizeof(adc_buffer[0]));
#else
	Xil_DCacheInvalidateRange((uintptr_t)adc_buffer, sizeof(adc_buffer));
	printf("DMA_EXAMPLE: address=%#lx samples=%lu channels=%u bits=%lu\n",
	       (uintptr_t)adc_buffer, NO_OS_ARRAY_SIZE(adc_buffer), rx_adc_init.num_channels,
#endif
#endif
#endif
#endif
#ifdef IIO_SUPPORT
#ifdef SYSID_BASEADDR
	struct axi_sysid *sysid_core;
	char *name = NULL;
	struct axi_sysid_init_param sysid_init = {
		.base = SYSID_BASEADDR,
#endif
	 * iio application configurations.
	struct xil_uart_init_param platform_uart_init_par = {
#ifdef XPAR_XUARTLITE_NUM_INSTANCES
		.type = UART_PL,
#else
		.type = UART_PS,
		.irq_id = UART_IRQ_ID
#endif
	struct no_os_uart_init_param iio_uart_ip = {
		.device_id = UART_DEVICE_ID,
		.irq_id = UART_IRQ_ID,
		.baud_rate = UART_BAUDRATE,
		.size = NO_OS_UART_CS_8,
		.parity = NO_OS_UART_PAR_NO,
		.stop = NO_OS_UART_STOP_1_BIT,
		.extra = &platform_uart_init_par,
		.platform_ops = &xil_uart_ops
	status = axi_sysid_init(&sysid_core, &sysid_init);
	if (status)
		return status;;
	name = axi_sysid_get_fpga_board(sysid_core);
	if (!strcmp("zed", name))
		iio_uart_ip.baud_rate = 115200;
	status = axi_sysid_remove(sysid_core);
	if (status)
		return status;
#endif
	struct iio_app_desc *app;
	struct iio_app_init_param app_init_param = { 0 };
	 * iio axi adc configurations.
	struct iio_axi_adc_init_param iio_axi_adc_init_par;
#ifdef FMCOMMS5
	struct iio_axi_adc_init_param iio_axi_adc_b_init_par;
#endif
	 * iio axi dac configurations.
	struct iio_axi_dac_init_param iio_axi_dac_init_par;
#ifdef FMCOMMS5
	struct iio_axi_dac_init_param iio_axi_dac_b_init_par;
#endif
	 * iio ad9361 configurations.
	struct iio_ad9361_init_param iio_ad9361_init_param;
#ifdef FMCOMMS5
	struct iio_ad9361_init_param iio_ad9361_b_init_param;
#endif
	 * iio instance descriptor.
	struct iio_axi_adc_desc *iio_axi_adc_desc;
#ifdef FMCOMMS5
	struct iio_axi_adc_desc *iio_axi_adc_b_desc;
#endif
	struct iio_axi_dac_desc *iio_axi_dac_desc;
#ifdef FMCOMMS5
	struct iio_axi_dac_desc *iio_axi_dac_b_desc;
#endif
	 * iio ad9361 instance descriptor.
	struct iio_ad9361_desc *iio_ad9361_desc;
#ifdef FMCOMMS5
	struct iio_ad9361_desc *iio_ad9361_b_desc;
#endif
	 * iio devices corresponding to every device.
	struct iio_device *adc_dev_desc, *dac_dev_desc, *ad9361_dev_desc;
#ifdef FMCOMMS5
	struct iio_device *adc_b_dev_desc, *dac_b_dev_desc, *ad9361_b_dev_desc;
#endif
	if (status < 0)
		return status;
	iio_axi_adc_init_par = (struct iio_axi_adc_init_param) {
		.rx_adc = ad9361_phy->rx_adc,
		.rx_dmac = rx_dmac,
#ifndef PLATFORM_MB
		.dcache_invalidate_range = (void (*)(uint32_t,
						     uint32_t))Xil_DCacheInvalidateRange
#endif
	status = iio_axi_adc_init(&iio_axi_adc_desc, &iio_axi_adc_init_par);
	if (status < 0)
		return status;
	iio_axi_adc_get_dev_descriptor(iio_axi_adc_desc, &adc_dev_desc);
	struct iio_data_buffer read_buff = {
		.buff = (void *)ADC_DDR_BASEADDR,
		.size = 0xFFFFFFFF,
#ifdef FMCOMMS5
	iio_axi_adc_b_init_par = (struct iio_axi_adc_init_param) {
		.rx_adc = ad9361_phy_b->rx_adc,
	status = iio_axi_adc_init(&iio_axi_adc_b_desc, &iio_axi_adc_b_init_par);
	if (status < 0)
		return status;
	iio_axi_adc_get_dev_descriptor(iio_axi_adc_b_desc, &adc_b_dev_desc);
#endif
	iio_axi_dac_init_par = (struct iio_axi_dac_init_param) {
		.tx_dac = ad9361_phy->tx_dac,
		.tx_dmac = tx_dmac,
#ifndef PLATFORM_MB
		.dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange,
#endif
	status = iio_axi_dac_init(&iio_axi_dac_desc, &iio_axi_dac_init_par);
	if (status < 0)
		return status;
	iio_axi_dac_get_dev_descriptor(iio_axi_dac_desc, &dac_dev_desc);
	struct iio_data_buffer write_buff = {
		.buff = (void *)DAC_DDR_BASEADDR,
		.size = 0xFFFFFFFF,
#ifdef FMCOMMS5
	iio_axi_dac_b_init_par = (struct iio_axi_dac_init_param) {
		.tx_dac = ad9361_phy_b->tx_dac,
	status = iio_axi_dac_init(&iio_axi_dac_b_desc, &iio_axi_dac_b_init_par);
	if (status < 0)
		return status;
	iio_axi_dac_get_dev_descriptor(iio_axi_dac_b_desc, &dac_b_dev_desc);
#endif
	iio_ad9361_init_param = (struct iio_ad9361_init_param) {
		.ad9361_phy = ad9361_phy,
	status = iio_ad9361_init(&iio_ad9361_desc, &iio_ad9361_init_param);
	if (status < 0)
		return status;
	iio_ad9361_get_dev_descriptor(iio_ad9361_desc, &ad9361_dev_desc);
#ifdef FMCOMMS5
	iio_ad9361_b_init_param = (struct iio_ad9361_init_param) {
		.ad9361_phy = ad9361_phy_b,
	status = iio_ad9361_init(&iio_ad9361_b_desc, &iio_ad9361_b_init_param);
	if (status < 0)
		return status;
	iio_ad9361_get_dev_descriptor(iio_ad9361_b_desc, &ad9361_b_dev_desc);
#endif
	struct iio_app_device devices[] = {
		IIO_APP_DEVICE("cf-ad9361-lpc", iio_axi_adc_desc, adc_dev_desc, &read_buff, NULL, NULL),
		IIO_APP_DEVICE("cf-ad9361-dds-core-lpc", iio_axi_dac_desc, dac_dev_desc, NULL, &write_buff, NULL),
		IIO_APP_DEVICE("ad9361-phy", ad9361_phy, ad9361_dev_desc, NULL, NULL, NULL),
#ifdef FMCOMMS5
		IIO_APP_DEVICE("cf-ad9361-B", iio_axi_adc_b_desc, adc_b_dev_desc, &read_buff, NULL, NULL),
		IIO_APP_DEVICE("cf-ad9361-dds-core-B", iio_axi_dac_b_desc, dac_b_dev_desc, NULL, &write_buff, NULL),
		IIO_APP_DEVICE("ad9361-phy-B", ad9361_phy_b, ad9361_b_dev_desc, NULL, NULL, NULL)
#endif
	app_init_param.devices = devices;
	app_init_param.nb_devices = NO_OS_ARRAY_SIZE(devices);
	app_init_param.uart_init_params = iio_uart_ip;
	status = iio_app_init(&app, app_init_param);
	if (status)
		return status;
	iio_app_run(app);
	printf("Done.\n");
#ifdef TDD_SWITCH_STATE_EXAMPLE
	uint32_t ensm_mode;
	struct no_os_gpio_init_param  gpio_init = {
		.extra = GPIO_PARAM
	struct no_os_gpio_desc 	*gpio_enable_pin;
	struct no_os_gpio_desc 	*gpio_txnrx_pin;
	if (!ad9361_phy->pdata->fdd) {
		if (ad9361_phy->pdata->ensm_pin_ctrl) {
			gpio_init.number = GPIO_ENABLE_PIN;
			status = no_os_gpio_get(&gpio_enable_pin, &gpio_init);
			if (status != 0) {
				printf("no_os_gpio_get() error: %"PRIi32"\n", status);
				return status;
			no_os_gpio_direction_output(gpio_enable_pin, 1);
			gpio_init.number = GPIO_TXNRX_PIN;
			status = no_os_gpio_get(&gpio_txnrx_pin, &gpio_init);
			if (status != 0) {
				return status;
			no_os_gpio_direction_output(gpio_txnrx_pin, 0);
			no_os_udelay(10);
			ad9361_get_en_state_machine_mode(ad9361_phy, &ensm_mode);
			printf("TXNRX control - Alert: %s\n",
			       ensm_mode == ENSM_MODE_ALERT ? "OK" : "Error");
			no_os_mdelay(1000);
			if (ad9361_phy->pdata->ensm_pin_pulse_mode) {
				while (1) {
					no_os_gpio_set_value(gpio_txnrx_pin, 0);
					no_os_udelay(10);
					no_os_gpio_set_value(gpio_enable_pin, 1);
					no_os_udelay(10);
					no_os_gpio_set_value(gpio_enable_pin, 0);
					printf("TXNRX Pulse control - RX: %s\n",
					       ensm_mode == ENSM_MODE_RX ? "OK" : "Error");
					no_os_mdelay(1000);
					no_os_udelay(10);
					printf("TXNRX Pulse control - Alert: %s\n",
					no_os_mdelay(1000);
					no_os_gpio_set_value(gpio_txnrx_pin, 1);
					no_os_udelay(10);
					no_os_udelay(10);
					printf("TXNRX Pulse control - TX: %s\n",
					       ensm_mode == ENSM_MODE_TX ? "OK" : "Error");
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_mdelay(1000);
			} else {
				while (1) {
					no_os_udelay(10);
					no_os_udelay(10);
					printf("TXNRX control - RX: %s\n",
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_udelay(10);
					printf("TXNRX control - TX: %s\n",
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_mdelay(1000);
		} else {
			while (1) {
				ad9361_set_en_state_machine_mode(ad9361_phy, ENSM_MODE_RX);
				printf("SPI control - RX: %s\n",
				no_os_mdelay(1000);
				ad9361_set_en_state_machine_mode(ad9361_phy, ENSM_MODE_ALERT);
				printf("SPI control - Alert: %s\n",
				no_os_mdelay(1000);
				ad9361_set_en_state_machine_mode(ad9361_phy, ENSM_MODE_TX);
				printf("SPI control - TX: %s\n",
				no_os_mdelay(1000);
				no_os_mdelay(1000);
#endif
	ad9361_remove(ad9361_phy);
#ifdef FMCOMMS5
	ad9361_remove(ad9361_phy_b);
#endif
	Xil_DCacheDisable();
	Xil_ICacheDisable();
#endif
	if (altera_bridge_uninit()) {
		printf("Altera Bridge Uninit Error!\n");
		return -1;
#endif
	return 0;
Thread Notes
  • Moving to linux forum to check
    HI  ,
    This is strange behavior and we didnt observe such issues earlier. It could be some power issue on the board or powering balun issue. Please check on them.
    Other alternate issue. It might be due to incorrect configuration and timing in software or linux.
    Sai
  • Hi
     I would recommend not to move threads after some team member directs those to the right forum.
    Seems to me that you are becoming an antenna when you touch the Tx connector.
    Fmcomms4 has a mux, port 1(a) or port 2(b). I don't remember the name on the board from the top of my head.
    No-Os might be on the other port compared to Linux. Check the initialization structure in the main function.
    If the cables/antennas are connected to the right ports, use a different cable/antenna, maybe the SMA is broken and it has a good contact only when you touch it.
    These are my thoughts. Ps I'm not from the no-OS team.
    Andrei
