I’m working with the AD9361 in a 2Rx/2Tx configuration with a 50 MHz reference clock. My goal is to achieve a DATA_CLK of 25 MHz (or at least 50 MHz), but despite adjusting the RX/TX path clocks and FIR settings, I am only seeing 30 MHz or 60 MHz on the data interface.
Here are the details of my configuration:
Reference Clock: 50 MHz
uint32_t rx_path_clock_frequencies[6] = {800000000, 50000000, 25000000, 25000000, 25000000, 25000000};
uint32_t tx_path_clock_frequencies[6] = {800000000, 50000000, 25000000, 25000000, 25000000, 25000000};
Observations:
- After enabling the RX/TX FIR, DATA_CLK remains at 30 MHz.
- Increasing BBPLL to higher frequencies (e.g., 800 MHz) gives ~30 MHz, but the datasheet mentions BBPLL minimum is 715 MHz.
- Using smaller BBPLL (715 MHz) doesn’t give the desired DATA_CLK of 25 MHz.
- I have tried various
rx_path_clock_frequenciesandtx_path_clock_frequenciescombinations, but the DATA_CLK is not reaching 25 MHz.
Additional Notes:
- AD9361 reports PLLs and LO locked.
Question:
- Is there a valid combination of reference clock, path clocks, and FIR settings that can produce 25 MHz DATA_CLK with 50 MHz reference clock?
- Are there internal constraints (BBPLL or dividers) that prevent reaching 25 MHz exactly?
Any guidance or example configuration to achieve this DATA_CLK would be greatly appreciated.
Thank you!
