AD9361 – “ad9361_dig_tune_delay: Tuning TX FAILED!” (ZynqMP / Vivado 2021.2, 2Rx-2Tx LVDS)
Product Number: AD9361
Software Version: petalinux & vivado 2021.2
I’m running an AD9361 on a ZynqMP-based design in 2Rx-2Tx (MIMO), LVDS/DDR mode and I’m hitting the following issue:
I ran the 1rx1tx mode. It didn't give any errors. When I switched to 2rx2tx mode, I set it to MIMO 1. And then these errors started occurring.
RX tuning succeeds, but TX tuning fails with:
2Rx-2Tx requirement & DTSI notes
  • I specifically need true 2Rx-2Tx operation (both RX channels and both TX channels active).
  • I reviewed multiple example DTSIs online; for 2×2 MIMO the only additional property I consistently saw was:
    adi,2rx-2tx-mode-enable;
  • In my DTSI, auto-tune is enabled:
    adi,digital-interface-tune-skip-mode = <0>;
    (i.e., I’m using the driver’s built-in tuning flow; no manual delay overrides in this mode.)
  • I’m not using the 1×1-only properties (e.g., adi,1rx-1tx-mode-use-rx-num, adi,1rx-1tx-mode-use-tx-num).
Edit Notes
[edited by: ErsinCengiz at 7:49 AM (GMT -5) on 14 Nov 2025]
  • Hi
    Pls try with following
    • Option 1: Manual Delay Override
      • If auto-tune fails, set:
        adi,digital-interface-tune-skip-mode = <2>;
        and provide manual delay values:
        adi,rx-data-delay = <3>;
        adi,tx-data-delay = <4>;
        adi,rx-data-clock-delay = <0>;
        (Values depend on your board; start with defaults from ADI reference designs.)
    • Option 2: Verify HDL
      • Ensure you are using the latest ADI HDL for ZynqMP with 2×2 MIMO enabled.
    • Option 3: Reduce Lane Rate
      • Lower the sample rate temporarily to relax timing and confirm if tuning passes.
    These might help.
    SJ
  • Thank you very much for replying so quickly. This is an urgent issue for me that needs to be solved.
    I set adi,digital-interface-tune-skip-mode = <0>; because I saw it like that in the example DTSI files.
    When I set this mode to 2, tuning is not performed, so I don’t get an error.
    However, in all the example files it is recommended to keep this mode at 0.
    With 2 it simply skips tuning, so that error is bypassed.
    I’ll show you two different scenarios as examples.
    Option 1
    Scenario 1
    When the example settings in pl-custom.dtsi are like this:
    adi,digital-interface-tune-skip-mode = <2>; adi,pp-tx-swap-enable; adi,pp-rx-swap-enable; adi,rx-frame-pulse-mode-enable; adi,lvds-mode-enable; adi,lvds-bias-mV = <150>; adi,lvds-rx-onchip-termination-enable; adi,rx-data-delay = <4>; adi,tx-data-delay = <3>; adi,tx-fb-clock-delay = <7>;
    the Linux output I observe is:
    [ 10.121956] ad9361 spi2.0: ad9361_probe : enter (ad9361)
    [ 10.128140] ad9361 spi2.0: No GPIOs defined for ext band ctrl
    [ 10.261841] ad9361 spi2.0: ad9361_probe : AD936x Rev 0 successfully initialized
    [ 10.293187] cf_axi_adc 80000000.cf-ad9361-lpc: ADI AIM (10.03.0) at 0x80000000 mapped to 0x00000000063b3424 probed ADC AD9361 as MASTER [ 10.317940] cf_axi_dds 80004000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x80004000 mapped to 0x000000009381d20f, probed DDS AD9361
    Scenario 2
    adi,digital-interface-tune-skip-mode = <0>; adi,pp-tx-swap-enable; adi,pp-rx-swap-enable; adi,rx-frame-pulse-mode-enable; adi,lvds-mode-enable; adi,lvds-bias-mV = <150>; adi,lvds-rx-onchip-termination-enable; adi,rx-data-delay = <4>; adi,tx-fb-clock-delay = <7>;
    [ 10.728023] ad9361 spi2.0: ad9361_probe : enter (ad9361)
    [ 10.734192] ad9361 spi2.0: No GPIOs defined for ext band ctrl
    [ 10.856223] ad9361 spi2.0: ad9361_probe : AD936x Rev 0 successfully initialized
    [ 11.289816] SAMPL CLK: 61440000 tuning: RX
    [ 11.293928] 0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    [ 11.298419] 0:# o o O o o # # # # # # # # # #
    [ 11.302905] 1:# # # # # # # # # # # # # # # #
    [ 11.307392] co (5), c1 (0)
    [ 11.716950] SAMPL CLK: 61440000 tuning: TX
    [ 11.721053] 0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    [ 11.725538] 0:# # # # # # # # # # # # # # # #
    [ 11.730025] 1:# # # # # # # # # # # # # # # #
    [ 11.734513] co (0), c1 (0)
    [ 11.737222] ad9361 spi2.0: ad9361_dig_tune_delay: Tuning TX FAILED!
    [ 11.744133] cf_axi_adc: probe of 80000000.cf-ad9361-lpc failed with error -5
    [ 11.764322] cf_axi_dds 80004000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x80
    Option 2
    Tests were conducted with MIMO 1 active.
    Option 3
    The settings for this section are as follows.
    adi,rx-path-clock-frequencies = <983040000 245760000 122880000 61440000 30720000 30720000>;
    adi,tx-path-clock-frequencies = <983040000 245760000 122880000 61440000 30720000 30720000>;
    Even though I adjusted it this way, the result didn't change. It's still giving the same error.
    As additional information, I was able to run rx1tx1. When I switch to 2rx2tx, I encounter this issue. HDL version 2022.
    The output on rx1tx1 is working successfully in this manner. When I try to do 2rx2tx, it doesn't work.
    [ 11.072859] ad9361 spi2.0: ad9361_probe : enter (ad9361)
    [ 11.229324] ad9361 spi2.0: ad9361_probe : AD936x Rev 0 successfully initialized
    [ 11.664627] SAMPL CLK: 61440000 tuning: RX
    [ 11.668737] 0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    [ 11.673227] 0:# o o o o o o O o o o o o o # #
    [ 11.677714] 1:# # # # # # # # # # # # # # # #
    [ 11.682201] co (13), c1 (0)
    [ 12.091584] SAMPL CLK: 61440000 tuning: TX
    [ 12.095681] 0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f:
    [ 12.100166] 0:# # # # # # # # # # # # # # # #
    [ 12.104652] 1:# # o o o o o o O o o o o o o #
    [ 12.109140] co (0), c1 (13)
    [ 12.115715] cf_axi_adc 80000000.cf-ad9361-lpc: ADI AIM (10.03.0) at 0x80000000 mapped to 0x000000005d03865b probed ADC AD9364 as MASTER
    [ 12.141118] cf_axi_dds 80004000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x80004000 mapped to 0x00000000eef1fd79, probed DDS AD9361
    I don't know what else to do. I lowered the sample rate from 61440000 to 30720000, but it still gave the same error. All of the above tests were tried at a sample rate of 30720000.
    I need your help with this. It's an urgent matter for me. Thank you for your help.
  • HI
    Common causes for the above problem.
    • Clocking mismatch:
      • Your sample clock (61.44 MHz or 30.72 MHz) must match HDL design constraints.
      • Check adi,rx-path-clock-frequencies and adi,tx-path-clock-frequencies in DTSI.
    • LVDS delays:
      • adi,rx-data-delay, adi,tx-data-delay, and adi,tx-fb-clock-delay may need adjustment.
      • Defaults often assume FMC reference designs, not custom boards.
    • Board skew:
      • PCB trace length differences can break auto-tuning.
    Pls try following by keeping digital interface tuning mode = 0
    • Adjust delays manually:
    Try sweeping these values (e.g., 0–15) to find a stable combination.
    • Ensure LVDS bias and termination:
    • Lower sample rate temporarily (e.g., 15.36 MHz) to widen timing margin.
    Watch kernel log during tuning:
    • RX tuning matrix should show at least one valid window (O).
    • TX tuning matrix failing means feedback clock alignment is off.
    If no valid window:
    • Increment tx-fb-clock-delay and retry.
    • If still failing, try rx-data-delay and tx-data-delay.
    if you are bypassing digital interface tune, there is risk of Data corruption at high rates.
    SJ
  • I found the root cause of the problem. It was due to an incorrect pin connection on the HDL side of the Tx path. Thank you for your help.
  • HI
    Thanks for the update. Good to hear your problem is solved.
    we will close the thread.
    Regards.
    SJ
