fmcomms5 custom board, external LO adf5355 rf pll not lock
Product Number: ad9
We are using custom board very similar to Fmcomms5 (RevC). However, at initial calibration, ad9361 IC's could not lock RF PLL(RX and TX PLL). BBPLL lock successfully.
We monitored output of adf5355 PLL RFoutA and ad9361 external LO input at spectrum analyzer. Their power are around -19 dbm and frequency seems at expected bin. I think ad9361 expect the LO power between -3 and +3 dBm. We use 2021.1 hdl version. Below, I pasted adf5355 register values and I attached our config file.
adf5355 register:
R0 = 0x03004E0
R1 = 0x4560410
R2 = 0x51CA6250
R3 = 0x0000000
R4 = 0x3400CA80
R5 = 0x0800025
R6 = 0x3521A076
R7 = 0x12000067
R8 = 0x102D0428
R9 = 0x2221BCC0
R10= 0x0C0323A
R11= 0x061300B
R12= 0x010041C
We also tried with Fmcomms5 (revc) + ZC-706 eval card with AD original image with external LO device tree. We also could not get RF PLL (RX and TX PLL) lock. BBPLL is ok.
Any help will be appreciated,
Best Regards.
Burak.
[IIO Oscilloscope]
plugin.FMComms5.detached=0
plugin.Debug.detached=0
plugin.AD936X Advanced.detached=0
plugin.DMM.detached=0
window_x_pos=0
window_y_pos=25
tooltips_enable=1
startup_version_check=0
[IIO Oscilloscope - Capture Window1]
domain=time
sample_count=400
fft_size=16384
fft_avg=1
fft_pwr_offset=0.000000
graph_type=Lines
show_grid=1
enable_auto_scale=1
user_y_axis_max=1000.000000
user_y_axis_min=-1000.000000
x_axis_min=-19.950001
x_axis_max=418.950012
y_axis_min=-666.450012
y_axis_max=663.450012
line_thickness = 1
plot_title = ADI IIO Oscilloscope - Capture1
show_capture_options = 1
plot_width = 1392
plot_height = 958
plot_x_pos=324
plot_y_pos=25
cf-ad9361-A.expanded=1
cf-ad9361-A.active=1
cf-ad9361-A.trigger_enabled=0
cf-ad9361-A.voltage0.enabled=1
cf-ad9361-A.voltage0.color_red=35328
cf-ad9361-A.voltage0.color_green=57856
cf-ad9361-A.voltage0.color_blue=13312
cf-ad9361-A.voltage0.math_apply_inverse_funct=0
cf-ad9361-A.voltage0.math_apply_multiply_funct=0
cf-ad9361-A.voltage0.math_apply_add_funct=0
cf-ad9361-A.voltage0.math_multiply_value=0.000000
cf-ad9361-A.voltage0.math_add_value=0.000000
cf-ad9361-A.voltage1.enabled=1
cf-ad9361-A.voltage1.color_red=0
cf-ad9361-A.voltage1.color_green=0
cf-ad9361-A.voltage1.color_blue=0
cf-ad9361-A.voltage1.math_apply_inverse_funct=0
cf-ad9361-A.voltage1.math_apply_multiply_funct=0
cf-ad9361-A.voltage1.math_apply_add_funct=0
cf-ad9361-A.voltage1.math_multiply_value=0.000000
cf-ad9361-A.voltage1.math_add_value=0.000000
cf-ad9361-A.voltage2.enabled=1
cf-ad9361-A.voltage2.color_red=29184
cf-ad9361-A.voltage2.color_green=40704
cf-ad9361-A.voltage2.color_blue=52992
cf-ad9361-A.voltage2.math_apply_inverse_funct=0
cf-ad9361-A.voltage2.math_apply_multiply_funct=0
cf-ad9361-A.voltage2.math_apply_add_funct=0
cf-ad9361-A.voltage2.math_multiply_value=0.000000
cf-ad9361-A.voltage2.math_add_value=0.000000
cf-ad9361-A.voltage3.enabled=1
cf-ad9361-A.voltage3.color_red=0
cf-ad9361-A.voltage3.color_green=0
cf-ad9361-A.voltage3.color_blue=0
cf-ad9361-A.voltage3.math_apply_inverse_funct=0
cf-ad9361-A.voltage3.math_apply_multiply_funct=0
cf-ad9361-A.voltage3.math_apply_add_funct=0
cf-ad9361-A.voltage3.math_multiply_value=0.000000
cf-ad9361-A.voltage3.math_add_value=0.000000
cf-ad9361-A.voltage4.enabled=1
cf-ad9361-A.voltage4.color_red=54016
cf-ad9361-A.voltage4.color_green=55040
cf-ad9361-A.voltage4.color_blue=53248
cf-ad9361-A.voltage4.math_apply_inverse_funct=0
cf-ad9361-A.voltage4.math_apply_multiply_funct=0
cf-ad9361-A.voltage4.math_apply_add_funct=0
cf-ad9361-A.voltage4.math_multiply_value=0.000000
cf-ad9361-A.voltage4.math_add_value=0.000000
cf-ad9361-A.voltage5.enabled=1
cf-ad9361-A.voltage5.color_red=0
cf-ad9361-A.voltage5.color_green=0
cf-ad9361-A.voltage5.color_blue=0
cf-ad9361-A.voltage5.math_apply_inverse_funct=0
cf-ad9361-A.voltage5.math_apply_multiply_funct=0
cf-ad9361-A.voltage5.math_apply_add_funct=0
cf-ad9361-A.voltage5.math_multiply_value=0.000000
cf-ad9361-A.voltage5.math_add_value=0.000000
cf-ad9361-A.voltage6.enabled=1
cf-ad9361-A.voltage6.color_red=44288
cf-ad9361-A.voltage6.color_green=32512
cf-ad9361-A.voltage6.color_blue=43008
cf-ad9361-A.voltage6.math_apply_inverse_funct=0
cf-ad9361-A.voltage6.math_apply_multiply_funct=0
cf-ad9361-A.voltage6.math_apply_add_funct=0
cf-ad9361-A.voltage6.math_multiply_value=0.000000
cf-ad9361-A.voltage6.math_add_value=0.000000
cf-ad9361-A.voltage7.enabled=1
cf-ad9361-A.voltage7.color_red=0
cf-ad9361-A.voltage7.color_green=0
cf-ad9361-A.voltage7.color_blue=0
cf-ad9361-A.voltage7.math_apply_inverse_funct=0
cf-ad9361-A.voltage7.math_apply_multiply_funct=0
cf-ad9361-A.voltage7.math_apply_add_funct=0
cf-ad9361-A.voltage7.math_multiply_value=0.000000
cf-ad9361-A.voltage7.math_add_value=0.000000
marker_type = Markers Off
marker.0 = 0
marker.1 = 0
marker.2 = 0
marker.3 = 0
marker.4 = 0
capture_started=0
[FMComms5]
ad9361-phy.out_altvoltage1_TX_LO_external = 1
ad9361-phy.out_altvoltage1_TX_LO_frequency = 1565420000
ad9361-phy.out_voltage_filter_fir_en = 0
ad9361-phy.out_voltage1_hardwaregain = 0.000000 dB
ad9361-phy.out_voltage_rf_bandwidth = 26000000
ad9361-phy.out_voltage_sampling_frequency = 38874000
ad9361-phy.in_voltage_bb_dc_offset_tracking_en = 1
ad9361-phy.in_voltage_filter_fir_en = 0
ad9361-phy.in_voltage0_gain_control_mode = manual
ad9361-phy.in_voltage0_hardwaregain = 10.000000 dB
ad9361-phy.in_voltage_quadrature_tracking_en = 1
ad9361-phy.in_voltage_rf_bandwidth = 26000000
ad9361-phy.in_voltage_rf_dc_offset_tracking_en = 1
ad9361-phy.in_voltage0_rf_port_select = C_BALANCED
ad9361-phy.in_voltage1_gain_control_mode = manual
ad9361-phy.in_voltage1_hardwaregain = 10.000000 dB
ad9361-phy.out_altvoltage0_RX_LO_external = 1
ad9361-phy.out_altvoltage0_RX_LO_frequency = 1565420000
ad9361-phy.out_voltage0_hardwaregain = 0.000000 dB
ad9361-phy.out_voltage0_rf_port_select = A
ad9361-phy.in_out_voltage_filter_fir_en = 0
ad9361-phy.ensm_mode = fdd
ad9361-phy.trx_rate_governor = nominal
cf-ad9361-dds-core-lpc.out_altvoltage3_TX1_Q_F2_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage3_TX1_Q_F2_phase = 0
cf-ad9361-dds-core-lpc.out_altvoltage3_TX1_Q_F2_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage3_TX1_Q_F2_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage1_TX1_I_F2_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage1_TX1_I_F2_phase = 90000
cf-ad9361-dds-core-lpc.out_altvoltage1_TX1_I_F2_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage1_TX1_I_F2_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage0_TX1_I_F1_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage0_TX1_I_F1_phase = 90000
cf-ad9361-dds-core-lpc.out_altvoltage0_TX1_I_F1_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage0_TX1_I_F1_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage7_TX2_Q_F2_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage7_TX2_Q_F2_phase = 0
cf-ad9361-dds-core-lpc.out_altvoltage7_TX2_Q_F2_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage7_TX2_Q_F2_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage6_TX2_Q_F1_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage6_TX2_Q_F1_phase = 0
cf-ad9361-dds-core-lpc.out_altvoltage6_TX2_Q_F1_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage6_TX2_Q_F1_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage5_TX2_I_F2_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage5_TX2_I_F2_phase = 90000
cf-ad9361-dds-core-lpc.out_altvoltage5_TX2_I_F2_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage5_TX2_I_F2_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage2_TX1_Q_F1_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage2_TX1_Q_F1_phase = 0
cf-ad9361-dds-core-lpc.out_altvoltage2_TX1_Q_F1_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage2_TX1_Q_F1_scale = 0.000000
cf-ad9361-dds-core-lpc.out_altvoltage4_TX2_I_F1_frequency = 999859
cf-ad9361-dds-core-lpc.out_altvoltage4_TX2_I_F1_phase = 90000
cf-ad9361-dds-core-lpc.out_altvoltage4_TX2_I_F1_raw = 0
cf-ad9361-dds-core-lpc.out_altvoltage4_TX2_I_F1_scale = 0.000000
ad9361-phy-B.out_altvoltage1_TX_LO_external = 1
ad9361-phy-B.out_altvoltage1_TX_LO_frequency = 1565420000
ad9361-phy-B.out_voltage_filter_fir_en = 0
ad9361-phy-B.out_voltage1_hardwaregain = 0.000000 dB
ad9361-phy-B.out_voltage_rf_bandwidth = 26000000
ad9361-phy-B.out_voltage_sampling_frequency = 38874000
ad9361-phy-B.in_voltage_bb_dc_offset_tracking_en = 1
ad9361-phy-B.in_voltage_filter_fir_en = 0
ad9361-phy-B.in_voltage0_gain_control_mode = manual
ad9361-phy-B.in_voltage0_hardwaregain = 10.000000 dB
ad9361-phy-B.in_voltage_quadrature_tracking_en = 1
ad9361-phy-B.in_voltage_rf_bandwidth = 26000000
ad9361-phy-B.in_voltage_rf_dc_offset_tracking_en = 1
ad9361-phy-B.in_voltage0_rf_port_select = C_BALANCED
ad9361-phy-B.in_voltage1_gain_control_mode = manual
ad9361-phy-B.in_voltage1_hardwaregain = 10.000000 dB
ad9361-phy-B.out_altvoltage0_RX_LO_external = 1
ad9361-phy-B.out_altvoltage0_RX_LO_frequency = 1565420000
ad9361-phy-B.out_voltage0_hardwaregain = 0.000000 dB
ad9361-phy-B.out_voltage0_rf_port_select = A
ad9361-phy-B.in_out_voltage_filter_fir_en = 0
ad9361-phy-B.ensm_mode = fdd
ad9361-phy-B.trx_rate_governor = nominal
cf-ad9361-dds-core-B.out_altvoltage3_TX1_Q_F2_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage3_TX1_Q_F2_phase = 0
cf-ad9361-dds-core-B.out_altvoltage3_TX1_Q_F2_raw = 0
cf-ad9361-dds-core-B.out_altvoltage3_TX1_Q_F2_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage1_TX1_I_F2_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage1_TX1_I_F2_phase = 90000
cf-ad9361-dds-core-B.out_altvoltage1_TX1_I_F2_raw = 0
cf-ad9361-dds-core-B.out_altvoltage1_TX1_I_F2_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage0_TX1_I_F1_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage0_TX1_I_F1_phase = 90000
cf-ad9361-dds-core-B.out_altvoltage0_TX1_I_F1_raw = 0
cf-ad9361-dds-core-B.out_altvoltage0_TX1_I_F1_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage7_TX2_Q_F2_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage7_TX2_Q_F2_phase = 0
cf-ad9361-dds-core-B.out_altvoltage7_TX2_Q_F2_raw = 0
cf-ad9361-dds-core-B.out_altvoltage7_TX2_Q_F2_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage6_TX2_Q_F1_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage6_TX2_Q_F1_phase = 0
cf-ad9361-dds-core-B.out_altvoltage6_TX2_Q_F1_raw = 0
cf-ad9361-dds-core-B.out_altvoltage6_TX2_Q_F1_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage5_TX2_I_F2_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage5_TX2_I_F2_phase = 90000
cf-ad9361-dds-core-B.out_altvoltage5_TX2_I_F2_raw = 0
cf-ad9361-dds-core-B.out_altvoltage5_TX2_I_F2_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage2_TX1_Q_F1_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage2_TX1_Q_F1_phase = 0
cf-ad9361-dds-core-B.out_altvoltage2_TX1_Q_F1_raw = 0
cf-ad9361-dds-core-B.out_altvoltage2_TX1_Q_F1_scale = 0.000000
cf-ad9361-dds-core-B.out_altvoltage4_TX2_I_F1_frequency = 999859
cf-ad9361-dds-core-B.out_altvoltage4_TX2_I_F1_phase = 90000
cf-ad9361-dds-core-B.out_altvoltage4_TX2_I_F1_raw = 0
cf-ad9361-dds-core-B.out_altvoltage4_TX2_I_F1_scale = 0.000000
load_fir_filter_file =
dds_mode_tx1 = 0
dds_mode_tx2 = 0
dds_mode_tx3 = 0
dds_mode_tx4 = 0
dac_buf_filename = (null)
tx_channel_0 = 0
tx_channel_1 = 0
tx_channel_2 = 0
tx_channel_3 = 0
tx_channel_4 = 0
tx_channel_5 = 0
tx_channel_6 = 0
tx_channel_7 = 0
global_settings_show = 1
tx_show = 1
rx_show = 1
fpga_show = 1
[AD936X Advanced]
debug.ad9361-phy.adi,txmon-2-lo-cm = 48
debug.ad9361-phy.adi,txmon-1-lo-cm = 48
debug.ad9361-phy.adi,txmon-2-front-end-gain = 2
debug.ad9361-phy.adi,txmon-1-front-end-gain = 2
debug.ad9361-phy.adi,txmon-duration = 8192
debug.ad9361-phy.adi,txmon-delay = 511
debug.ad9361-phy.adi,txmon-one-shot-mode-enable = 0
debug.ad9361-phy.adi,txmon-dc-tracking-enable = 0
debug.ad9361-phy.adi,txmon-high-gain = 24
debug.ad9361-phy.adi,txmon-low-gain = 0
debug.ad9361-phy.adi,txmon-low-high-thresh = 37000
debug.ad9361-phy.adi,gpo3-tx-delay-us = 0
debug.ad9361-phy.adi,gpo3-rx-delay-us = 0
debug.ad9361-phy.adi,gpo2-tx-delay-us = 0
debug.ad9361-phy.adi,gpo2-rx-delay-us = 0
debug.ad9361-phy.adi,gpo1-tx-delay-us = 0
debug.ad9361-phy.adi,gpo1-rx-delay-us = 0
debug.ad9361-phy.adi,gpo0-tx-delay-us = 0
debug.ad9361-phy.adi,gpo0-rx-delay-us = 0
debug.ad9361-phy.adi,gpo3-slave-tx-enable = 0
debug.ad9361-phy.adi,gpo3-slave-rx-enable = 0
debug.ad9361-phy.adi,gpo2-slave-tx-enable = 0
debug.ad9361-phy.adi,gpo2-slave-rx-enable = 0
debug.ad9361-phy.adi,gpo1-slave-tx-enable = 0
debug.ad9361-phy.adi,gpo1-slave-rx-enable = 0
debug.ad9361-phy.adi,gpo0-slave-tx-enable = 0
debug.ad9361-phy.adi,gpo0-slave-rx-enable = 0
debug.ad9361-phy.adi,gpo3-inactive-state-high-enable = 0
debug.ad9361-phy.adi,gpo2-inactive-state-high-enable = 0
debug.ad9361-phy.adi,gpo1-inactive-state-high-enable = 0
debug.ad9361-phy.adi,gpo0-inactive-state-high-enable = 0
debug.ad9361-phy.adi,gpo-manual-mode-enable-mask = 0
debug.ad9361-phy.adi,gpo-manual-mode-enable = 0
debug.ad9361-phy.adi,aux-dac2-tx-delay-us = 0
debug.ad9361-phy.adi,aux-dac2-rx-delay-us = 0
debug.ad9361-phy.adi,aux-dac2-active-in-alert-enable = 0
debug.ad9361-phy.adi,aux-dac2-active-in-tx-enable = 0
debug.ad9361-phy.adi,aux-dac2-active-in-rx-enable = 0
debug.ad9361-phy.adi,aux-dac2-default-value-mV = 0
debug.ad9361-phy.adi,aux-dac1-tx-delay-us = 0
debug.ad9361-phy.adi,aux-dac1-rx-delay-us = 0
debug.ad9361-phy.adi,aux-dac1-active-in-alert-enable = 0
debug.ad9361-phy.adi,aux-dac1-active-in-tx-enable = 0
debug.ad9361-phy.adi,aux-dac1-active-in-rx-enable = 0
debug.ad9361-phy.adi,aux-dac1-default-value-mV = 0
debug.ad9361-phy.adi,aux-dac-manual-mode-enable = 1
debug.ad9361-phy.adi,aux-adc-decimation = 256
debug.ad9361-phy.adi,aux-adc-rate = 40000000
debug.ad9361-phy.adi,temp-sense-decimation = 256
debug.ad9361-phy.adi,temp-sense-periodic-measurement-enable = 1
debug.ad9361-phy.adi,temp-sense-offset-signed = 206
debug.ad9361-phy.adi,temp-sense-measurement-interval-ms = 1000
debug.ad9361-phy.adi,elna-gaintable-all-index-enable = 0
debug.ad9361-phy.adi,elna-rx2-gpo1-control-enable = 0
debug.ad9361-phy.adi,elna-rx1-gpo0-control-enable = 0
debug.ad9361-phy.adi,elna-bypass-loss-mdB = 0
debug.ad9361-phy.adi,elna-gain-mdB = 0
debug.ad9361-phy.adi,elna-settling-delay-ns = 0
debug.ad9361-phy.adi,ctrl-outs-enable-mask = 255
debug.ad9361-phy.adi,ctrl-outs-index = 0
debug.ad9361-phy.adi,rssi-duration = 1000
debug.ad9361-phy.adi,rssi-wait = 1
debug.ad9361-phy.adi,rssi-delay = 1
debug.ad9361-phy.adi,rssi-restart-mode = 3
debug.ad9361-phy.adi,fagc-power-measurement-duration-in-state5 = 64
debug.ad9361-phy.adi,fagc-rst-gla-if-en-agc-pulled-high-mode = 0
debug.ad9361-phy.adi,fagc-rst-gla-en-agc-pulled-high-enable = 0
debug.ad9361-phy.adi,fagc-rst-gla-large-lmt-overload-enable = 1
debug.ad9361-phy.adi,fagc-rst-gla-large-adc-overload-enable = 1
debug.ad9361-phy.adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = 8
debug.ad9361-phy.adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = 10
debug.ad9361-phy.adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable = 1
debug.ad9361-phy.adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable = 1
debug.ad9361-phy.adi,fagc-rst-gla-stronger-sig-thresh-above-ll = 10
debug.ad9361-phy.adi,fagc-optimized-gain-offset = 5
debug.ad9361-phy.adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable = 1
debug.ad9361-phy.adi,fagc-use-last-lock-level-for-set-gain-enable = 1
debug.ad9361-phy.adi,fagc-gain-index-type-after-exit-rx-mode = 0
debug.ad9361-phy.adi,fagc-gain-increase-after-gain-lock-enable = 0
debug.ad9361-phy.adi,fagc-final-overrange-count = 3
debug.ad9361-phy.adi,fagc-lmt-final-settling-steps = 1
debug.ad9361-phy.adi,fagc-lpf-final-settling-steps = 1
debug.ad9361-phy.adi,fagc-lock-level-gain-increase-upper-limit = 5
debug.ad9361-phy.adi,fagc-lock-level-lmt-gain-increase-enable = 1
debug.ad9361-phy.adi,fagc-lp-thresh-increment-steps = 1
debug.ad9361-phy.adi,fagc-lp-thresh-increment-time = 5
debug.ad9361-phy.adi,fagc-allow-agc-gain-increase-enable = 0
debug.ad9361-phy.adi,fagc-state-wait-time-ns = 260
debug.ad9361-phy.adi,fagc-dec-pow-measurement-duration = 64
debug.ad9361-phy.adi,agc-immed-gain-change-if-large-lmt-overload-enable = 0
debug.ad9361-phy.adi,agc-immed-gain-change-if-large-adc-overload-enable = 0
debug.ad9361-phy.adi,agc-gain-update-interval-us = 1000
debug.ad9361-phy.adi,agc-sync-for-gain-counter-enable = 0
debug.ad9361-phy.adi,agc-dig-gain-step-size = 4
debug.ad9361-phy.adi,agc-dig-saturation-exceed-counter = 3
debug.ad9361-phy.adi,agc-lmt-overload-large-inc-steps = 2
debug.ad9361-phy.adi,agc-lmt-overload-small-exceed-counter = 10
debug.ad9361-phy.adi,agc-lmt-overload-large-exceed-counter = 10
debug.ad9361-phy.adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable = 0
debug.ad9361-phy.adi,agc-adc-large-overload-inc-steps = 2
debug.ad9361-phy.adi,agc-adc-large-overload-exceed-counter = 10
debug.ad9361-phy.adi,agc-adc-small-overload-exceed-counter = 10
debug.ad9361-phy.adi,agc-outer-thresh-low-inc-steps = 2
debug.ad9361-phy.adi,agc-outer-thresh-low = 18
debug.ad9361-phy.adi,agc-inner-thresh-low-inc-steps = 1
debug.ad9361-phy.adi,agc-inner-thresh-low = 12
debug.ad9361-phy.adi,agc-inner-thresh-high-dec-steps = 1
debug.ad9361-phy.adi,agc-inner-thresh-high = 10
debug.ad9361-phy.adi,agc-outer-thresh-high-dec-steps = 2
debug.ad9361-phy.adi,agc-outer-thresh-high = 5
debug.ad9361-phy.adi,agc-attack-delay-extra-margin-us = 1
debug.ad9361-phy.adi,mgc-split-table-ctrl-inp-gain-mode = 0
debug.ad9361-phy.adi,mgc-dec-gain-step = 2
debug.ad9361-phy.adi,mgc-inc-gain-step = 2
debug.ad9361-phy.adi,mgc-rx2-ctrl-inp-enable = 0
debug.ad9361-phy.adi,mgc-rx1-ctrl-inp-enable = 0
debug.ad9361-phy.adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable = 0
debug.ad9361-phy.adi,gc-max-dig-gain = 15
debug.ad9361-phy.adi,gc-dig-gain-enable = 0
debug.ad9361-phy.adi,gc-low-power-thresh = 24
debug.ad9361-phy.adi,gc-dec-pow-measurement-duration = 8192
debug.ad9361-phy.adi,gc-lmt-overload-low-thresh = 704
debug.ad9361-phy.adi,gc-lmt-overload-high-thresh = 800
debug.ad9361-phy.adi,gc-adc-large-overload-thresh = 58
debug.ad9361-phy.adi,gc-adc-small-overload-thresh = 47
debug.ad9361-phy.adi,gc-adc-ovr-sample-size = 4
debug.ad9361-phy.adi,gc-rx2-mode = 2
debug.ad9361-phy.adi,gc-rx1-mode = 2
debug.ad9361-phy.adi,update-tx-gain-in-alert-enable = 0
debug.ad9361-phy.adi,qec-tracking-slow-mode-enable = 0
debug.ad9361-phy.adi,dc-offset-count-low-range = 50
debug.ad9361-phy.adi,dc-offset-count-high-range = 40
debug.ad9361-phy.adi,dc-offset-attenuation-low-range = 5
debug.ad9361-phy.adi,dc-offset-attenuation-high-range = 6
debug.ad9361-phy.adi,dc-offset-tracking-update-event-mask = 5
debug.ad9361-phy.adi,clk-output-mode-select = 0
debug.ad9361-phy.adi,external-rx-lo-enable = 1
debug.ad9361-phy.adi,external-tx-lo-enable = 1
debug.ad9361-phy.adi,xo-disable-use-ext-refclk-enable = 1
debug.ad9361-phy.adi,tx-rf-port-input-select = 0
debug.ad9361-phy.adi,rx-rf-port-input-select = 0
debug.ad9361-phy.adi,split-gain-table-mode-enable = 0
debug.ad9361-phy.adi,tx-fastlock-pincontrol-enable = 0
debug.ad9361-phy.adi,rx-fastlock-pincontrol-enable = 0
debug.ad9361-phy.adi,rx-fastlock-delay-ns = 0
debug.ad9361-phy.adi,tx-fastlock-delay-ns = 0
debug.ad9361-phy.adi,tdd-skip-vco-cal-enable = 0
debug.ad9361-phy.adi,tdd-use-dual-synth-mode-enable = 0
debug.ad9361-phy.adi,ensm-enable-txnrx-control-enable = 0
debug.ad9361-phy.adi,ensm-enable-pin-pulse-mode-enable = 0
debug.ad9361-phy.adi,frequency-division-duplex-mode-enable = 1
