I am working with an AD9361 board (w/ a Xilinx Zynq) that does not provide access to the the fastlock profile selection pins. This means we can only access the registers via SPI :(. I need to hop over a wide bandwidth as fast as possible. Has anyone run an experiment that shows the time to
1. Load a profile from memory over SPI (I have many more than 8 profiles), so after the first 8 are used up, every profile needs to be loaded separately.
a. The max SPI clock rate is (I think ~50 MHz). Theoretically loading 16 bytes should only take < 3us.
2. Send the select profile command over SPI
3. Wait for the PLL to lock.
A ballpark value would be helpful before I go and try it out. Would using the iic interface be appreciably slower than calling the API directly from C++?
Thanks!
