Calibrating AD9361, on a custom board with A10 FPGA
Product Number: AD9361
Software Version: Quartus 18.1, hdl_2019_r1
I am using a custom board with A10 FPGA and AD9361 transceiver
I am using no-OS drivers
While calibrating AD9361, it gets tuned at 25MHz, but not at 40MHz and 61.44 MHz  (In 2r2t mode)
Where as, it gets tuned at 25MHz and 40Mhz but not at 61.44 MHz (In 1r1t mode)
Can someone please help me to solve this issue?
Thanks and Regards
Prince
  • Are you using filter wizard tool to generate the configurations with the different sample rates?
    If not, please use the below tool to generate profiles with the required sampling rate:
    https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/filters
  • Hi Srimoyi,
    Correcting above point:
    In case of 1R1T:
    RX: Tuning at 25MHz, and 40MHz and not 61.44MHz
    TX: Not at all tuning
    In case of 2R2T:
    Error: Failed to restore state from ALERT(5) TO FDD(a)
    Note: Filters I am generating via above mentioned tool only
  • Please upgrade to the latest version of the no-os drivers and then try initializing.
    Also, can you send us the filter file that you are using for 61.44MHz  and the initialization parameters.
  • AD9361_InitParam default_init_param = {
    /* Device selection */
    ID_AD9361, // dev_sel
    /* Identification number */
    0, //id_no
    /* Reference Clock */
    40000000UL, //reference_clk_rate
    /* Base Configuration */
    1, //two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
    1, //one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num
    1, //one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num
    1, //frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
    0, //frequency_division_duplex_independent_mode_enable *** adi,frequency-division-duplex-independent-mode-enable
    0, //tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
    0, //tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
    0, //tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
    0, //rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
    0, //rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
    0, //tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
    0, //external_rx_lo_enable *** adi,external-rx-lo-enable
    0, //external_tx_lo_enable *** adi,external-tx-lo-enable
    5, //dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
    6, //dc_offset_attenuation_high_range *** adi,dc-offset-attenuation-high-range
    5, //dc_offset_attenuation_low_range *** adi,dc-offset-attenuation-low-range
    0x28, //dc_offset_count_high_range *** adi,dc-offset-count-high-range
    0x32, //dc_offset_count_low_range *** adi,dc-offset-count-low-range
    0, //split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
    MAX_SYNTH_FREF, //trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
    1, // qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable //////////////////////////////////////Original 0
    /* ENSM Control */
    0, //ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
    0, //ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
    /* LO Control */
    4500000000UL, //rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
    4500000000UL, //tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
    1,//tx_lo_powerdown_managed_enable *** adi,tx-lo-powerdown-managed-enable
    /* Rate & BW Control */
    {983040000, 245760000, 122880000, 61440000, 30720000, 30720000},// rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
    {983040000, 122880000, 122880000, 61440000, 30720000, 30720000},// tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
    32000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
    32000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
    /* RF Port Control */
    0, //rx_rf_port_input_select *** adi,rx-rf-port-input-select
    0, //tx_rf_port_input_select *** adi,tx-rf-port-input-select
    /* TX Attenuation Control */
    10000, //tx_attenuation_mdB *** adi,tx-attenuation-mdB
    0, //update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
    /* Reference Clock Control */
    1, //xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable original value 0 for crystal
    {8,5920}, //dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
    ADC_CLK_DIV_16,
    /* Gain Control */
    2, //gc_rx1_mode *** adi,gc-rx1-mode ************************************************************************************************************
    2, //gc_rx2_mode *** adi,gc-rx2-mode ************************************************************************************************************
    58, //gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
    4, //gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
    47, //gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
    8192, //gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
    0, //gc_dig_gain_enable *** adi,gc-dig-gain-enable
    800, //gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
    704, //gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
    24, //gc_low_power_thresh *** adi,gc-low-power-thresh
    15, //gc_max_dig_gain *** adi,gc-max-dig-gain ORIGINAL
    /* Gain MGC Control */
    2, //mgc_dec_gain_step *** adi,mgc-dec-gain-step
    2, //mgc_inc_gain_step *** adi,mgc-inc-gain-step
    0, //mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
    0, //mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
    0, //mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
    /* Gain AGC Control */
    10, //agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
    2, //agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
    0, //agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
    10, //agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
    4, //agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
    3, //agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
    1000, // agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
    0, //agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
    0, //agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
    10, //agc_inner_thresh_high *** adi,agc-inner-thresh-high
    1, //agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
    12, //agc_inner_thresh_low *** adi,agc-inner-thresh-low
    1, //agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
    10, //agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
    2, //agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
    10, //agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
    5, //agc_outer_thresh_high *** adi,agc-outer-thresh-high
    2, //agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
    18, //agc_outer_thresh_low *** adi,agc-outer-thresh-low
    2, //agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
    1, //agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
    0, //agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
    /* Fast AGC */
    64, //fagc_dec_pow_measuremnt_duration *** adi,fagc-dec-pow-measurement-duration
    260, //fagc_state_wait_time_ns *** adi,fagc-state-wait-time-ns
    /* Fast AGC - Low Power */
    0, //fagc_allow_agc_gain_increase *** adi,fagc-allow-agc-gain-increase-enable
    5, //fagc_lp_thresh_increment_time *** adi,fagc-lp-thresh-increment-time
    1, //fagc_lp_thresh_increment_steps *** adi,fagc-lp-thresh-increment-steps
    /* Fast AGC - Lock Level (Lock Level is set via slow AGC inner high threshold) */
    1, //fagc_lock_level_lmt_gain_increase_en *** adi,fagc-lock-level-lmt-gain-increase-enable
    5, //fagc_lock_level_gain_increase_upper_limit *** adi,fagc-lock-level-gain-increase-upper-limit
    /* Fast AGC - Peak Detectors and Final Settling */
    1, //fagc_lpf_final_settling_steps *** adi,fagc-lpf-final-settling-steps
    1, //fagc_lmt_final_settling_steps *** adi,fagc-lmt-final-settling-steps
    3, //fagc_final_overrange_count *** adi,fagc-final-overrange-count
    /* Fast AGC - Final Power Test */
    0, //fagc_gain_increase_after_gain_lock_en *** adi,fagc-gain-increase-after-gain-lock-enable
    /* Fast AGC - Unlocking the Gain */
    0, //fagc_gain_index_type_after_exit_rx_mode *** adi,fagc-gain-index-type-after-exit-rx-mode
    1, //fagc_use_last_lock_level_for_set_gain_en *** adi,fagc-use-last-lock-level-for-set-gain-enable
    1, //fagc_rst_gla_stronger_sig_thresh_exceeded_en *** adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
    5, //fagc_optimized_gain_offset *** adi,fagc-optimized-gain-offset
    10, //fagc_rst_gla_stronger_sig_thresh_above_ll *** adi,fagc-rst-gla-stronger-sig-thresh-above-ll
    1, //fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en *** adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
    1, //fagc_rst_gla_engergy_lost_goto_optim_gain_en *** adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
    10, //fagc_rst_gla_engergy_lost_sig_thresh_below_ll *** adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
    8, //fagc_energy_lost_stronger_sig_gain_lock_exit_cnt *** adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
    1, //fagc_rst_gla_large_adc_overload_en *** adi,fagc-rst-gla-large-adc-overload-enable
    1, //fagc_rst_gla_large_lmt_overload_en *** adi,fagc-rst-gla-large-lmt-overload-enable
    0, //fagc_rst_gla_en_agc_pulled_high_en *** adi,fagc-rst-gla-en-agc-pulled-high-enable
    0, //fagc_rst_gla_if_en_agc_pulled_high_mode *** adi,fagc-rst-gla-if-en-agc-pulled-high-mode
    64, //fagc_power_measurement_duration_in_state5 *** adi,fagc-power-measurement-duration-in-state5
    /* RSSI Control */
    1, //rssi_delay *** adi,rssi-delay
    1000, //rssi_duration *** adi,rssi-duration
    3, //rssi_restart_mode *** adi,rssi-restart-mode
    0, //rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
    1, //rssi_wait *** adi,rssi-wait
    /* Aux ADC Control */
    256, //aux_adc_decimation *** adi,aux-adc-decimation
    40000000UL, //aux_adc_rate *** adi,aux-adc-rate
    /* AuxDAC Control */
    1, //aux_dac_manual_mode_enable *** adi,aux-dac-manual-mode-enable
    0, //aux_dac1_default_value_mV *** adi,aux-dac1-default-value-mV
    0, //aux_dac1_active_in_rx_enable *** adi,aux-dac1-active-in-rx-enable
    0, //aux_dac1_active_in_tx_enable *** adi,aux-dac1-active-in-tx-enable
    0, //aux_dac1_active_in_alert_enable *** adi,aux-dac1-active-in-alert-enable
    0, //aux_dac1_rx_delay_us *** adi,aux-dac1-rx-delay-us
    0, //aux_dac1_tx_delay_us *** adi,aux-dac1-tx-delay-us
    0, //aux_dac2_default_value_mV *** adi,aux-dac2-default-value-mV
    0, //aux_dac2_active_in_rx_enable *** adi,aux-dac2-active-in-rx-enable
    0, //aux_dac2_active_in_tx_enable *** adi,aux-dac2-active-in-tx-enable
    0, //aux_dac2_active_in_alert_enable *** adi,aux-dac2-active-in-alert-enable
    0, //aux_dac2_rx_delay_us *** adi,aux-dac2-rx-delay-us
    0, //aux_dac2_tx_delay_us *** adi,aux-dac2-tx-delay-us
    /* Temperature Sensor Control */
    256, //temp_sense_decimation *** adi,temp-sense-decimation
    1000, //temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
    0xCE, //temp_sense_offset_signed *** adi,temp-sense-offset-signed
    1, //temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
    /* Control Out Setup */
    0xFF, //ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
    0, //ctrl_outs_index *** adi,ctrl-outs-index
    /* External LNA Control */
    0, //elna_settling_delay_ns *** adi,elna-settling-delay-ns
    0, //elna_gain_mdB *** adi,elna-gain-mdB
    0, //elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
    0, //elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
    0, //elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
    0, //elna_gaintable_all_index_enable *** adi,elna-gaintable-all-index-enable
    /* Digital Interface Control */
    0, //digital_interface_tune_skip_mode *** adi,digital-interface-tune-skip-mode, Original Value 0
    0, //digital_interface_tune_fir_disable *** adi,digital-interface-tune-fir-disable ////////////////////// Original Value 0
    1, //pp_tx_swap_enable *** adi,pp-tx-swap-enable
    1, //pp_rx_swap_enable *** adi,pp-rx-swap-enable
    0, //tx_channel_swap_enable *** adi,tx-channel-swap-enable
    0, //rx_channel_swap_enable *** adi,rx-channel-swap-enable
    1, //rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
    0, //two_t_two_r_timing_enable *** adi,2t2r-timing-enable /////////////////////////////////////////////// Original Value 0
    0, //invert_data_bus_enable *** adi,invert-data-bus-enable
    0, //invert_data_clk_enable *** adi,invert-data-clk-enable
    0, //fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
    0, //invert_rx_frame_enable *** adi,invert-rx-frame-enable
    0, //fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
    0, //swap_ports_enable *** adi,swap-ports-enable
    0, //single_data_rate_enable *** adi,single-data-rate-enable
    1, //lvds_mode_enable *** adi,lvds-mode-enable
    0, //half_duplex_mode_enable *** adi,half-duplex-mode-enable
    0, //single_port_mode_enable *** adi,single-port-mode-enable
    0, //full_port_enable *** adi,full-port-enable
    0, //full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
    0, //delay_rx_data *** adi,delay-rx-data, Original Value 0
    0, //rx_data_clock_delay *** adi,rx-data-clock-delay, Original Value 0
    4, //rx_data_delay *** adi,rx-data-delay, Original Value 4
    7, //tx_fb_clock_delay *** adi,tx-fb-clock-delay, Original Value 7
    1, //tx_data_delay *** adi,tx-data-delay, Original Value 0
    #ifdef ALTERA_PLATFORM
    450, //lvds_bias_mV *** adi,lvds-bias-mV //ORIGINAL 300 as per CV Datasheet, 450 as per A10 datasheet and 75mV Step-size
    #else
    150, //lvds_bias_mV *** adi,lvds-bias-mV
    //#endif
    1, //lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
    0, //rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
    0xFF, //lvds_invert1_control *** adi,lvds-invert1-control
    0x0F, //lvds_invert2_control *** adi,lvds-invert2-control //ORIGINAL VALUE: 0x0F --> Invert: 0x4F
    /* GPO Control */
    0, //gpo0_inactive_state_high_enable *** adi,gpo0-inactive-state-high-enable
    0, //gpo1_inactive_state_high_enable *** adi,gpo1-inactive-state-high-enable
    0, //gpo2_inactive_state_high_enable *** adi,gpo2-inactive-state-high-enable
    0, //gpo3_inactive_state_high_enable *** adi,gpo3-inactive-state-high-enable
    0, //gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable
    0, //gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable
    0, //gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable
    0, //gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable
    0, //gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable
    0, //gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable
    0, //gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable
    0, //gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable
    0, //gpo0_rx_delay_us *** adi,gpo0-rx-delay-us
    0, //gpo0_tx_delay_us *** adi,gpo0-tx-delay-us
    0, //gpo1_rx_delay_us *** adi,gpo1-rx-delay-us
    0, //gpo1_tx_delay_us *** adi,gpo1-tx-delay-us
    0, //gpo2_rx_delay_us *** adi,gpo2-rx-delay-us
    0, //gpo2_tx_delay_us *** adi,gpo2-tx-delay-us
    0, //gpo3_rx_delay_us *** adi,gpo3-rx-delay-us
    0, //gpo3_tx_delay_us *** adi,gpo3-tx-delay-us
    /* Tx Monitor Control */
    37000, //low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
    0, //low_gain_dB *** adi,txmon-low-gain
    24, //high_gain_dB *** adi,txmon-high-gain
    0, //tx_mon_track_en *** adi,txmon-dc-tracking-enable
    0, //one_shot_mode_en *** adi,txmon-one-shot-mode-enable
    511, //tx_mon_delay *** adi,txmon-delay
    8192, //tx_mon_duration *** adi,txmon-duration
    2, //tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
    2, //tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
    48, //tx1_mon_lo_cm *** adi,txmon-1-lo-cm
    48, //tx2_mon_lo_cm *** adi,txmon-2-lo-cm
    /* GPIO definitions */
    -1, //gpio_resetb *** reset-gpios
    /* MCS Sync */
    -1, //gpio_sync *** sync-gpios
    -1, //gpio_cal_sw1 *** cal-sw1-gpios
    -1, //gpio_cal_sw2 *** cal-sw2-gpios
    /* External LO clocks */
    NULL, //(*ad9361_rfpll_ext_recalc_rate)()
    NULL, //(*ad9361_rfpll_ext_round_rate)()
    NULL //(*ad9361_rfpll_ext_set_rate)()
    AD9361_RXFIRConfig rx_fir_config = {
    3, // rx
    -6, // rx_gain
    2, // rx_dec
    {38,168,272,195,-96,-254,-34,308,204,-292,-424,168,638,103,-779,-515,755,1029,-479,-1556,-125,1961,1103,-2060,-2483,1594,4302,-111,-6818,-3808,12163,28086,28086,12163,-3808,-6818,-111,4302,1594,-2483,-2060,1103,1961,-125,-1556,-479,1029,755,-515,-779,103,638,168,-424,-292,204,308,-34,-254,-96,195,272,168,38,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, // rx_coef[128]
    64, // rx_coef_size
    {1228800000,307200000,153600000,76800000,76800000,38400000}, // rx_path_clks[6]
    38731029 // rx_bandwidth
    AD9361_TXFIRConfig tx_fir_config = {
    3, // tx
    0, // tx_gain
    2, // tx_int
    {53,162,232,101,-179,-299,-61,230,103,-337,-397,151,518,-3,-737,-423,683,824,-528,-1364,-21,1719,816,-1920,-2074,1578,3706,-460,-6195,-2797,12233,26910,26910,12233,-2797,-6195,-460,3706,1578,-2074,-1920,816,1719,-21,-1364,-528,824,683,-423,-737,-3,518,151,-397,-337,103,230,-61,-299,-179,101,232,162,53,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, // tx_coef[128]
    64, // tx_coef_size
    {1228800000,307200000,153600000,76800000,76800000,38400000}, // tx_path_clks[6]
    33889517 // tx_bandwidth
  • Set below highlighted to zero and try:
    Also, the sampling rates that you have set is 38.4Msps for both RX and TX.So, it will not work with 61.44Msps. If you want to use 61.44Msps, then generate a filter with the same sampling rate, and then load all the coefficients and the setting generated without doing any change to it.
