fastlock profile with more than 8 profile saving.
Hello everyone!
I have been working with fastlock profile and I wanted to use more than 8 profile to hope the frequency.now i'm able to recall 8 profile,but i'm not getting what to do if I wanted to use more than 8 profile as i'm using your --> ad9361_fastlock_save(phy, 1, profile, values); function to save more that 8 profile. if i'm going to use more than 8 frequency then while recalling only last  8 frequency are coming instead of that I want continuous chian.
my sequence of execution is :     set_lo_tx --> store  --> load --> save  --> recall
  • While recalling the first 8 profiles, donot do it in a loop(delete the highlighted lines). Instead recall each profile one by one from 1 to 8 manually using below  and see the output in spectrum analyzer for each change
    echo 1 > out_altvoltage1_TX_LO_fastlock_recall
    Similarly recall each profile for 9 to 16 manually and see the output in spectrum
  • Dear  ;
    I have few questions regarding this thread:
    1. If I needed more than 16 profiles then how can I calculate values for 17th profile or onwards  (echo 8 95,0,0,0,0,113,16,16,238,85,111,221,115,204,213,166> out_altvoltage1_TX_LO_fastlock_load); In this I understand 8 is profile number, 95 is profile center frequency and what are the rest values? And how I can find them for 17th profile and onwards(18th, 19th,20th,....................).
    2. How Can I synchronize all profiles, let say when I found Rx at 17th at the same time Tx should be on 17th?
    3. Any other settings except above shared example in PS or PL for profiles enabling like register settings or anything else.
    4. What will be the total time for all profiles hopping?
    Thanks
  • Dear ;
    I did those steps as you described but I found the different results:   echo 1 > out_altvoltage1_TX_LO_fastlock_recall for 1 to 16 recall one by one all sixteen profiles, I got only last profile at output and there is nothing on the spectrum analyzer.
    fastlock
    Script is given below:
    cd /sys/bus/iio/devices/iio\:device0/
    pwd
    for i in {1..8..1}
    do
    echo $((75000000 + $i * 25000000)) > out_altvoltage1_TX_LO_frequency
    sleep 0.1
    echo $i > out_altvoltage1_TX_LO_fastlock_store
    echo $i > out_altvoltage1_TX_LO_fastlock_save
    cat out_altvoltage1_TX_LO_fastlock_save
    cat out_altvoltage1_TX_LO_frequency
    done
    for i in {9..16..1}
    do
    sleep 0.1
    done
    echo 1 100,0,0,0,0,113,31,15,238,85,111,221,117,204,180,176> out_altvoltage1_TX_LO_fastlock_load
    echo 2 140,0,0,0,0,65,24,8,238,85,110,221,117,252,33,180> out_altvoltage1_TX_LO_fastlock_load
    echo 3 90,0,0,0,0,114,30,14,238,85,111,221,116,237,249,182> out_altvoltage1_TX_LO_fastlock_load
    echo 4 110,0,0,0,0,113,29,13,238,85,111,221,116,204,129,162> out_altvoltage1_TX_LO_fastlock_load
    echo 5 130,0,0,0,0,97,26,10,238,85,111,221,116,252,57,150> out_altvoltage1_TX_LO_fastlock_load
    echo 6 150,0,0,0,0,65,23,7,238,85,111,221,116,252,12,150> out_altvoltage1_TX_LO_fastlock_load
    echo 7 85,0,0,0,0,114,31,15,238,85,111,221,115,221,38,1832> out_altvoltage1_TX_LO_fastlock_load
    echo "recalling first 8 profiles"
    #for i in {1..8..1}
    #do
    #sleep 1
    #echo $i > out_altvoltage1_TX_LO_fastlock_recall
    echo 2 > out_altvoltage1_TX_LO_fastlock_recall
    echo 3 > out_altvoltage1_TX_LO_fastlock_recall
    echo 4 > out_altvoltage1_TX_LO_fastlock_recall
    echo 5 > out_altvoltage1_TX_LO_fastlock_recall
    echo 6 > out_altvoltage1_TX_LO_fastlock_recall
    echo 7 > out_altvoltage1_TX_LO_fastlock_recall
    echo 8 > out_altvoltage1_TX_LO_fastlock_recall
    #done
    echo 9 105,0,0,0,0,113,31,15,238,85,127,221,115,204,152,176> out_altvoltage1_TX_LO_fastlock_load
    echo 10 115,0,0,0,0,97,29,13,238,85,111,221,115,204,107,192> out_altvoltage1_TX_LO_fastlock_load
    echo 11 125,0,0,0,0,97,27,11,238,85,111,221,115,236,73,160> out_altvoltage1_TX_LO_fastlock_load
    echo 12 135,0,0,0,0,65,25,9,238,85,111,221,115,252,44,194> out_altvoltage1_TX_LO_fastlock_load
    echo 13 145,0,0,0,0,65,23,7,238,68,110,238,115,252,22,160> out_altvoltage1_TX_LO_fastlock_load
    echo 14 77,0,249,255,63,114,31,15,238,85,111,221,114,253,122,151> out_altvoltage1_TX_LO_fastlock_load
    echo 15 82,0,249,255,63,114,31,15,238,85,111,221,114,221,64,167 > out_altvoltage1_TX_LO_fastlock_load
    echo 16 87,0,249,255,63,113,27,19,238,85,111,221,114,206,14,193> out_altvoltage1_TX_LO_fastlock_load
    echo "recalling 9-16 profiles"
    #for i in {9..16..1}
    #do
    sleep 1
    echo 9 > out_altvoltage1_TX_LO_fastlock_recall
    echo 10 > out_altvoltage1_TX_LO_fastlock_recall
    echo 11 > out_altvoltage1_TX_LO_fastlock_recall
    echo 12 > out_altvoltage1_TX_LO_fastlock_recall
    echo 13 > out_altvoltage1_TX_LO_fastlock_recall
    echo 14 > out_altvoltage1_TX_LO_fastlock_recall
    echo 15 > out_altvoltage1_TX_LO_fastlock_recall
    echo 16 > out_altvoltage1_TX_LO_fastlock_recall
    #done
    Thanks
