JESD204B Rx link up, ILAS correct, but framer sends constant zeros when noise is expected; DecPower shows signal
Product Number: ADRV9026
Software Version: 7.0.0.14
Custom board, Zynq UltraScale+ (Xilinx JESD204 v7.2 + PHY v4.0), LMK04828 clocking, device clock 245.76 MHz. Use case: 4 Rx / 2 Tx, Rx framer 0 with L=4, M=8, F=4, K=32, N′=16, Subclass 1, lane rate 9.8304 Gbps. All files (profile, stream, ARM firmware, gain tables, init.c) generated by TES from the same profile. API version: [7.0.0.14], firmware: [7.0.0.11], TES: [7.0.0.15].
Status:
  • MCS status 0x17, PllStatusGet 0xF, init cals complete with no errors
  • JESD link up, received ILAS configuration matches (DID=1, BID=0, L=4, M=8, F=4, K=32)
  • Scrambling disabled for debug: lanes show the /F/ and /A/ replacement pattern of constant zero data
  • adi_adrv9025_RxTxEnableGet (SPI mode): readback Rx 0xFF, Tx 0x00 (didnt enable tx on purpose to solve rx first); Rx1 decimated power ≈ −59 dBFS when enabled, 0 when disabled
  • Framer 0 crossbar: Rx1 I/Q … Rx4 I/Q; framer 1 and 2 unused
  • FramerTestDataSet with PATTERN_REPEAT at SERIALIZER works; however, RAMP at FRAMERINPUT (all framers) has no effect (gives constant zero data)
  • RF ports were not terminated during init cals.
My Init sequence: adrv9025_HwReset → PreMcsInit_v2 → PreMcsInit_NonBroadcast → MCS → PostMcsInit → framer link / SYSREF steps → RxTxEnableSet
Question: what could prevent Rx datapath samples (and the framer-input test ramp) from reaching framer 0, when RxDecPowerGet shows signal power?
