DPD status
Product Number: ADRV9029
Hi, ADI expert.
I am testing ADRV9025 DPD .
the ACLR are reduced by 10-12 dB after the application of DPD.
but the status shows below:
root@Q:/sys/kernel/debug/iio/iio:device2# cat tx0_advanced_dpd_status
ADRV9025 TX0 Advanced DPD Status
Basic Status:
Error Code: 13341
Percent Complete: 0%
Iteration Count: 1007
Update Count: 0
Sync Status: 4
Model Table: 0
Power Statistics:
Mean TU Power: -11.836 dBFS
Peak TU Power: -1.653 dBFS
Mean TX Power: -12.056 dBFS
Peak TX Power: -2.179 dBFS
Mean ORx Power: -14.993 dBFS
Peak ORx Power: -4.955 dBFS
Error Metrics:
Direct EVM: 3.1355%
Indirect EVM: 15.6139%
Select Error: 3.4977%
Indirect Error: 3.3741%
Error Status:
Error Status 0: metrics_mask=0x0380, action_mask=0x0001
Error Status 1: metrics_mask=0x0080, action_mask=0x0000
Persistent Error 0: metrics_mask=0x0000, action_mask=0x0000
Persistent Error 1: metrics_mask=0x0000, action_mask=0x0000
My question is :
The powers seemd to be right , but the Indirect EVM happened to 15%. Why did this happen . How can I resolve this problem
  • Update Count always 0 . Did DPD run correctly?
  • From the DPD statistics, there seems to be stability error (13341-->0x341D) due to which the update count never increments. Are you testing at the target output power of the PA? Can you test at 3dB/ 6dB back-off from the target power and check if the update count increments.
    https://wiki.analog.com/resources/eval/user-guides/adrv9029/dpd_error_troubleshooting
  • Taking your advice . Now I reduced the digitial signal to -5.008dBFS. but the Direct EVM: 13.9703% .
    And the error code still shows (13341-->0x341D)
    Basic Status:
    Error Code: 13341
    Iteration Count: 214
    Update Count: 0
    Sync Status: 4
    Model Table: 0
    Power Statistics:
    Mean TU Power: -15.311 dBFS
    Peak TU Power: -5.008 dBFS
    Mean TX Power: -15.311 dBFS
    Peak TX Power: -5.008 dBFS
    Mean ORx Power: -15.278 dBFS
    Peak ORx Power: -4.625 dBFS
    Error Metrics:
    Indirect EVM: 13.9703%
    Select Error: 3.2460%
    Indirect Error: 2.9754%
    Error Status:
    Error Status 0: metrics_mask=0x01c0, action_mask=0x0001
    Error Status 1: metrics_mask=0x0000, action_mask=0x0000
  • When I disable and reset DPD for a serval times. The DPD status shows:
    (The tx and orx settings kept the same. only reset DPD )
    Direct EVM: 3.1584%
    Mean TX Power: -15.167 dBFS
    Peak TX Power: 0.156 dBFS
    How could this happen.
    Basic Status:
    Error Code: 13341
    Iteration Count: 697
    Update Count: 0
    Sync Status: 4
    Model Table: 0
    Power Statistics:
    Mean TU Power: -15.215 dBFS
    Peak TU Power: -5.673 dBFS
    Mean ORx Power: -15.216 dBFS
    Peak ORx Power: -5.639 dBFS
    Error Metrics:
    Direct EVM: 3.1584%
    Indirect EVM: 20.3157%
    Select Error: 6.0937%
    Indirect Error: 5.5274%
    Error Status:
  • I was asking you to reduce the PA output power. The Peak Tx power is going beyond 0dBFS. Peak TX Power: 0.156 dBFS which means the gain expansion is more and PA must be compressing a lot.
  • root@Q:/sys/kernel/debug/iio/iio:device2# cat tx0_advanced_dpd_status
    Basic Status:
    Error Code: 0
    Iteration Count: 21
    Update Count: 0
    Sync Status: 4
    Model Table: 0
    Power Statistics:
    Mean TU Power: -13.711 dBFS
    Peak TU Power: -5.504 dBFS
    Mean TX Power: -13.711 dBFS
    Peak TX Power: -5.504 dBFS
    Mean ORx Power: -19.716 dBFS
    Peak ORx Power: -10.922 dBFS
    Error Metrics:
    Direct EVM: 9.1345%
    Indirect EVM: 9.1345%
    Select Error: 4.4056%
    Indirect Error: 4.7809%
    Error Status:
    Error Status 0: metrics_mask=0x03c0, action_mask=0x0001
    Persistent Error 0: metrics_mask=0x0080, action_mask=0x0000
    This is my result: No matter how I adjust the tx-gain or orx-gain to keep the power at an appropriate level, the EVM result is just not right.
    I have also read many posts about DPD stability, but none of them seem to solve my problem.
  • What is the Tx min average threshold and ORX min average threshold? It looks like the DPD is in unity gain mode.
