Strong EMC design
ADRV9029
Recommended for New Designs
The ADRV9029 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9029 on Analog.com
ADRV9026
The ADRV9026 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9026 on Analog.com
How to configure only the ARM without programming the bitstream in the adrv9029 no-os 2025.1 Vitis project?I want to program the bitstream through Vivado and observe the internal signals of the FPGA using ILA.
Ramarao - Moved from Support ADRV9022/ADRV9026/ADRV9029 to Microcontroller no-OS Drivers. Post date updated from Tuesday, April 14, 2026 8:44 AM UTC to Wednesday, April 15, 2026 12:37 PM UTC to reflect the move.
JTHY - Moved from Microcontroller no-OS Drivers to Support ADRV9022/ADRV9026/ADRV9029. Post date updated from Wednesday, April 15, 2026 12:37 PM UTC to Thursday, May 28, 2026 6:34 AM UTC to reflect the move.
Hi JTHY,
As far as I understand, the issue is that make run always re-programs the bitstream, which is overwriting the one you loaded from Vivado.
There might be two possible solutions for this:
The simpler one would be to use Vitis directly instead of make run. In the debug configurations there is an option to uncheck "Program FPGA", which allows you to run the application as many times as you want without re-programming the bitstream.
For the other one, you could bypass make run and use XSCT to initialize the ARM and load your application after programming the bitstream from Vivado Hardware Manager. The files you need should already be in your build folder from the first make run.
Hope this helps for now, someone with more expertise will follow up soon.
Kind regards
Hi JTHY,
I wanted to follow up on this thread. Do you have any updates on your end? If there's nothing further needed, I'll go ahead and close this thread.
Please let me know either way.
Thanks, Tudor
