ADRV9026
Recommended for New Designs
The ADRV9026 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9026 on Analog.com
ADRV9029
The ADRV9029 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9029 on Analog.com
Dear Analog Devices Support Team,
I am working with the ADRV9026 SDR transceiver on the ADS9-V2EBZ motherboard, which includes an Avnet MicroZed board with a Zynq FPGA, running Linux, and a Kintex Ultrascale FPGA. I am exploring the signal processing capabilities with Linux, but without using a GUI.
My question is as follows:
1. With Linux in place, do I need to access and modify the FPGA code for signal processing tasks, or can these tasks be handled entirely by the Linux system and the available APIs?
2. How can signal processing be performed in a Linux environment without a GUI, using the existing tools and APIs?
Any advice on using Linux for signal processing with the ADRV9026, and how to work without a GUI, would be greatly appreciated.
Thank you for your support.
talebinezhad
Ramarao - Moved from Design Support ADRV9026/ADRV9029 to Linux Software Drivers. Post date updated from Wednesday, December 4, 2024 5:29 PM UTC to Thursday, December 5, 2024 8:26 AM UTC to reflect the move.
travisfcollins - Moved from Linux Software Drivers to Design Support ADRV9026/ADRV9029. Post date updated from Thursday, December 5, 2024 8:26 AM UTC to Thursday, December 5, 2024 3:56 PM UTC to reflect the move.
ADRV9026 on ADS9 does not use our standard Linux drivers, and uses the API directly for evaluation. Ramarao does that system support any embedded development?
-Travis
Dear Travis,
Thank you for your response. I have a couple of additional questions regarding the use of the ADRV9026 on the ADS9-V2EBZ motherboard:
For signal processing, which FPGA should I load the code onto – the Zynq FPGA on the MicroZed board or the Kintex Ultrascale FPGA on the motherboard itself?
How can I use the APIs for configuring the transceiver in a non-Linux environment? What is the recommended approach for interacting with the APIs without relying on Linux?
Your guidance on these points would be very helpful.
Ali Talebi
Its the Kintex Ultrascale FPGA that we use or JESD signal transfer and signal processing.
https://github.com/analogdevicesinc/no-OS/tree/main/projects/adrv902x
Please check Software integration section of the User guide.
Could you please share your project details, what are you trying to come up with?
Thank you for your previous responses.
My goal is to measure the time interval between multiple Gaussian pulses after receiving them. Specifically, I want to process these pulses in an embedded environment. For example, one of my tasks is to receive multiple Gaussian pulses, measure the time interval between them, and count the number of pulses received.
I would like to clarify the following points:
If I write my code on the Kintex Ultrascale FPGA, since it does not have an ARM core, I understand that I won’t be able to execute APIs for communication.
On the other hand, if I write my code on the Avnet Zynq FPGA, I know that it doesn’t have a JESD204B connection to the FMC interface, so it wouldn’t be possible to send data directly through this FPGA.
Given these limitations, I would like to know the best approach for my project: should I write the code for the Kintex FPGA or the Zynq FPGA? And how can I manage the communication and data transfer in an embedded environment where I won’t be relying on a PC?
I would greatly appreciate it if you could provide more detailed guidance on how to handle the data transfer, signal generation, and processing in this embedded setup, as the documentation provides general information, but the exact implementation steps are unclear.
Thank you
The MicroZed board is the embedded Linux system on which the ADRV902X Command Server will execute. The ultrascale design connects to the MicroZed through the AXI Bridge. The Ultrascale FPGA interfaces to the ADRV902X evaluation board through a FPGA Mezzanine (FMC) connector.
The MicroZed connects to a PC through a TCP/IP connection between the command server (running on the MicroZed) and the client DLL (running on the PC). Command and control to ADRV902X as well as the FPGA peripherals are performed over the TCP/IP connection.
We donot provide the reference design for the Ultrascale FPGA.
Since, you want to add your own IP in the FPGA, it would be good, if you use ZCU102 FPGA and ADRV9026 and use the Linux drivers for building it. Please follow the below link for the guidelines
ADRV9026 & ADRV9029 Prototyping Platform User Guide [Analog Devices Wiki]
The HDL reference design is provided in the below link:
