ADRV9026 in internal digital loopback not working
Product Number: ADRV9026
Software Version: Windows 11 (64-bit); Vivado/Vitis 2022.2; Petalinux 2022.2; ADRV9026 TRx Evaluation Software (GainTables: 6.4.0.1, Api: 6.4.0.14, Firmware: 6.4.0.6, Gui: 6.4.0.17)
Dear all,
We are getting the following error while trying to configure the ADRV9026 in digital internal loopback (De-framer -> Framer):
Connecting
Connected
SPI Write Address 0x6689: 0xd5
System.FormatException: Input string was not in a correct format.
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseUInt32(String value, NumberStyles options, NumberFormatInfo numfmt)
   at adrv9010_dll.SubClasses.Adrv9010Hal.SpiByteRead(UInt16 addr, Byte& readdata)
   at CallSite.Target(Closure , CallSite , CodeContext , Object , Object , Object )
   at System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3)
   at Microsoft.Scripting.Interpreter.DynamicInstruction`5.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2)
   at Microsoft.Scripting.Interpreter.DynamicInstruction`4.Run(InterpretedFrame frame)
   at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
   at Adi.Tpg.IronPythonWindow.ScriptHost.Execute(String expression)
The testing-setup is the following:
Loop-back testing-setup
We took the script shared by PVALAVAN in the following post: Link
Incidentally, we only modified it such that the value to be written was 0xD5 (for setting up the desired configuration). The Iron Python code is the following:
#GUI Version: 5.0.0.76
#DLL Version: 5.0.0.57
#Cmd Server Version: 5.0.0.57
#FPGA Version: 0xD9000007
#ARM Version: 5.0.0.32(ADI_ADRV9025_ARMBUILD_TESTOBJ)
#StreamVersion: 8.0.0.5
#Import Reference to the DLL
import System
import clr
import time
from System import Array
clr.AddReferenceToFileAndPath("C:\\Program Files\\Analog Devices\\ADRV9025 Transceiver Evaluation Software_x64_FULL\\adrvtrx_dll.dll")
from adrv9010_dll import AdiEvaluationSystem
from adrv9010_dll import Types
from adrv9010_dll import Ad9528Types
def spiRead(address):
    data = adrv9010.Hal.SpiByteRead(address, 0)
    print "SPI Read Address " + hex(address) + ": " + hex(data[1])
def spiWrite(address, data):
    adrv9010.Hal.SpiByteWrite(address, data)
    print "SPI Write Address " + hex(address) + ": " + hex(data)
#Create an Instance of the Class
link = AdiEvaluationSystem.Instance
connect = False
if (link.IsConnected() == False):
    connect = True
    link.platform.board.Client.Connect("192.168.10.10", 22)
    print "Connecting"
if (link.IsConnected()):
    adrv9010 = link.Adrv9010Get(1)
    print "Connected"
    ##### YOUR CODE GOES HERE #####
    #spiWrite(0x6689, 0x29)
    spiWrite(0x6689, 0xD5)
    #print spiRead(0x6689)
    spiRead(0x6689)
else:
    print "Not Connected"
if (connect):
    link.platform.board.Client.Disconnect()
    print "Disconnected"
It seems there is an error regarding the function adrv9010.Hal.SpiByteRead(address, 0) which we are still trying to solve.
In addition, since the spiWrite(0x6689, 0xD5) cmd. seemed to run properly, we disregarded the spiRead(0x6689) cmd. to test the loop-back, but no data (‘0’s) was observed at the FPGA’s framer. Hence, it led us to think that the loop-back was not properly configured.
It is worth noting that the ADRV9026’s initialization was completed successfully. Moreover, the JESD204B Rx & Tx links were properly brought up. The deframer 0 status was 0x87 and framer 0 status was: [status|framerSyncNeCount|qbfStateStatus|syncNSel] = [A|4|D|0].
We would appreciate any suggestion.
Iron Python code was added
[edited by: JNPH at 3:43 PM (GMT -4) on 11 Oct 2024]
  • Please check with this:
    import System
    import clr
    import time
    connect = False
        connect = True
        link.platform.board.Client.Connect("192.168.1.10", 55556)
        print "Connecting"
        print "Connected"
        spiRead(0x6689)
    else:
    if (connect):
  • We tried the loop-back with the provided script, but unfortunately it did not work. It is worth noting that the IPv4 and port used were "192.168.10.10" and "22" (SSH) because our board is a custom-made one (which is connected via ethernet to the PC) instead of an ADI evaluation one. Moreover, the same error was issued upon running the code:
    Connecting
    Connected
    SPI Write Address 0x6689: 0x29
    I was wondering if there is a way to set the TRx in internal digital loop-back through the API instead of Iron Python.
  • I would like to mention that we have tried to use the following functions without success:
    • adrv9010.Control.ProductIdGet() -> Error: System.FormatException: Input string was not in a correct format.
    • adrv9010.Tx.TxAttenGet() -> Error: System.FormatException: Input string was not in a correct format.
    • adrv9010.DataInterface.DeframerStatusGet() -> Error: System.ArgumentException: respString parameter did not have enough comma separated values to correctly parse
    • adrv9010.RadioCtrl.RxTxEnableGet() -> Error: System.ArgumentException: respString parameter did not have enough comma separated values to correctly parse
    Here is our code: test_ADRV9026conn.py
    We are not sure whether these errors are related to the ADRVTRX Eval. Soft. because we got a few errors during the installation:
    Error 1Error 2
  • Please provide the FPGA details used in your setup?
    Are you using the ADRV9026 -SDCARD image from here ADRV9029 Datasheet and Product Info | Analog Devices
    Could you please try writing and reading from Scratch pad register 0x00A multiple iterations to check SPI functionality.
  • Are you using the ADRV9026 -SDCARD image from here
    No, we are not. Since our board is custom-made (as mentioned in a previous reply), we are using our own SD card featuring Petalinux. It is worth mentioning that we imported all necessary files regading the ADI API into Vitis for building and launching the application.
    As long as we use the API, we are able to initialize, configure and monitor the transciever. Therefore, we are pretty sure the SPI is up and running properly.
    The very same error was issued when we tried to read the indicated register. A time.sleep(0.5) cmd. was added after both the spiWrite() and spiRead() ones, although they are not shown in the code below. In fact, they were removed because strangely the time.sleep() cmd. was not allowed to be present in the inserted code.
    Code:
    #GUI Version: 6.4.0.17
    #DLL Version: 6.4.0.14
    #FPGA Version: Not Connected
    #ARM Version: Not Connected
    #StreamVersion: 9.4.0.1
    import System
    import clr
    import time
    connect = False
        connect = True
        #link.platform.board.Client.Connect("192.168.1.10", 55556)
        print "Connecting"
        print "Connected"
    	for i in range(10):
    		spiWrite(0x00A, i+1)
    		spiRead(0x00A)
    else:
    if (connect):
    Issued error:
    Connecting
    Connected
    SPI Write Address 0xa: 0x1
    Moreover, the "System.Net.Sockets.SocketException (0x80004005): An established connection was aborted by the software in your host machine" error was issued, when we tried to write the indicated register more than two times.
    Code:
    import System
    import clr
    import time
    connect = False
        connect = True
        print "Connecting"
        print "Connected"
    	for i in range(10):
    		# spiRead(0x00A)
    else:
    if (connect):
    Issued error:
    Connecting
    Connected
    SPI Write Address 0xa: 0x2
       at AdiCmdServerClient.CmdServerClient.Query(String writeString)
       at adrv9010_dll.SubClasses.Adrv9010Hal.SpiByteWrite(UInt16 addr, Byte data)
       at Microsoft.Scripting.Interpreter.FuncCallInstruction`4.Run(InterpretedFrame frame)
       at Microsoft.Scripting.Interpreter.LightLambda.Run5[T0,T1,T2,T3,T4,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4)
       at Microsoft.Scripting.Interpreter.LightLambda.Run3[T0,T1,T2,TRet](T0 arg0, T1 arg1, T2 arg2)
    We tend to think these errors suggest that it might not be possible to use Iron Python for completely configure and monitor the transceiver in our specific case.
  • Can you try running a basic script printing "Hello world" using Iron python in your setup and confirm that the environment is fine?
  • Upon running the suggested basic script, we concluded the environment was working just fine.Hello World
  • Is there any new update here?
    Can you try writing a different register and readback if its successful?
  • We got the very same errors as before. We continue to be unable to use Iron Python for completely configure and monitor the transceiver in our specific case and custom board.
