Hello ADI team,
Based on your advice regarding the question below, I applied a BW 50MHz 5GNR signal at a Tx data rate of 122.88Msps.
RE: Inquiry Regarding DPD Usage with Tx Data Rate Below 122.88MSPS
I created and used the attached CFR Pulse file for the test.
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 -1 0 0 0 1 0 1 0 0 0 -2 0 -1 0 1 0 2 0 0 0 -3 0 -2 0 2 0 4 0 1 0 -4 0 -4 0 2 0 5 0 2 0 -4 0 -5 0 1 0 7 0 4 0 -5 0 -8 0 0 0 8 0 6 0 -5 0 -10 0 -2 0 10 0 9 0 -5 0 -13 0 -4 0 11 0 12 0 -3 0 -16 0 -7 0 12 0 16 0 -1 0 -18 0 -12 0 11 0 21 0 2 0 -20 0 -17 0 10 0 25 0 7 0 -22 0 -22 0 7 0 29 0 13 0 -22 0 -29 0 3 0 33 0 19 0 -21 0 -35 0 -2 0 36 0 27 0 -19 0 -42 0 -10 0 37 0 36 0 -14 0 -48 0 -19 0 37 0 46 0 -8 0 -53 0 -29 0 36 0 55 0 1 0 -57 0 -41 0 31 0 65 0 12 0 -59 0 -54 0 25 0 73 0 25 0 -59 0 -67 0 15 0 81 0 40 0 -56 0 -81 0 2 0 86 0 57 0 -50 0 -94 0 -14 0 89 0 76 0 -40 0 -107 0 -32 0 89 0 95 0 -26 0 -117 0 -54 0 84 0 114 0 -9 0 -125 0 -78 0 76 0 133 0 13 0 -129 0 -103 0 63 0 151 0 39 0 -129 0 -130 0 44 0 166 0 69 0 -124 0 -158 0 20 0 177 0 102 0 -113 0 -184 0 -10 0 184 0 138 0 -96 0 -210 0 -46 0 186 0 176 0 -71 0 -232 0 -87 0 181 0 216 0 -38 0 -251 0 -134 0 168 0 255 0 3 0 -263 0 -185 0 146 0 293 0 52 0 -269 0 -241 0 113 0 329 0 110 0 -266 0 -299 0 70 0 360 0 177 0 -253 0 -361 0 13 0 386 0 254 0 -227 0 -423 0 -57 0 403 0 340 0 -186 0 -486 0 -143 0 410 0 436 0 -127 0 -547 0 -248 0 404 0 543 0 -47 0 -607 0 -375 0 381 0 664 0 61 0 -663 0 -530 0 335 0 801 0 205 0 -714 0 -723 0 258 0 962 0 401 0 -760 0 -975 0 136 0 1164 0 680 0 -798 0 -1326 0 -63 0 1441 0 1113 0 -829 0 -1879 0 -418 0 1889 0 1896 0 -852 0 -2964 0 -1201 0 2883 0 3890 0 -866 0 -6575 0 -4515 0 8553 0 25174 0 32767 0 25174 0 8553 0 -4515 0 -6575 0 -866 0 3890 0 2883 0 -1201 0 -2964 0 -852 0 1896 0 1889 0 -418 0 -1879 0 -829 0 1113 0 1441 0 -63 0 -1326 0 -798 0 680 0 1164 0 136 0 -975 0 -760 0 401 0 962 0 258 0 -723 0 -714 0 205 0 801 0 335 0 -530 0 -663 0 61 0 664 0 381 0 -375 0 -607 0 -47 0 543 0 404 0 -248 0 -547 0 -127 0 436 0 410 0 -143 0 -486 0 -186 0 340 0 403 0 -57 0 -423 0 -227 0 254 0 386 0 13 0 -361 0 -253 0 177 0 360 0 70 0 -299 0 -266 0 110 0 329 0 113 0 -241 0 -269 0 52 0 293 0 146 0 -185 0 -263 0 3 0 255 0 168 0 -134 0 -251 0 -38 0 216 0 181 0 -87 0 -232 0 -71 0 176 0 186 0 -46 0 -210 0 -96 0 138 0 184 0 -10 0 -184 0 -113 0 102 0 177 0 20 0 -158 0 -124 0 69 0 166 0 44 0 -130 0 -129 0 39 0 151 0 63 0 -103 0 -129 0 13 0 133 0 76 0 -78 0 -125 0 -9 0 114 0 84 0 -54 0 -117 0 -26 0 95 0 89 0 -32 0 -107 0 -40 0 76 0 89 0 -14 0 -94 0 -50 0 57 0 86 0 2 0 -81 0 -56 0 40 0 81 0 15 0 -67 0 -59 0 25 0 73 0 25 0 -54 0 -59 0 12 0 65 0 31 0 -41 0 -57 0 1 0 55 0 36 0 -29 0 -53 0 -8 0 46 0 37 0 -19 0 -48 0 -14 0 36 0 37 0 -10 0 -42 0 -19 0 27 0 36 0 -2 0 -35 0 -21 0 19 0 33 0 3 0 -29 0 -22 0 13 0 29 0 7 0 -22 0 -22 0 7 0 25 0 10 0 -17 0 -20 0 2 0 21 0 11 0 -12 0 -18 0 -1 0 16 0 12 0 -7 0 -16 0 -3 0 12 0 11 0 -4 0 -13 0 -5 0 9 0 10 0 -2 0 -10 0 -5 0 6 0 8 0 0 0 -8 0 -5 0 4 0 7 0 1 0 -5 0 -4 0 2 0 5 0 2 0 -4 0 -4 0 1 0 4 0 2 0 -2 0 -3 0 0 0 2 0 1 0 -1 0 -2 0 0 0 1 0 1 0 0 0 -1 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
The results are shown in the image below (iBW 50MHz, TM1.1).
Looking at the image above, could you advise whether there is an issue with the CFR Pulse file or with the CFR threshold? Any suggestions would be appreciated.
Additionally, I set the OSR to 1, but could you also let me know how to use the OSR for DPD? Thank you.
If there is an issue with the CFR Pulse file, could you generate a new CFR Pulse file and send it to me?
- BW 50MHz (CF +/-25MHz)
- SCS 30KHz
- Data rate 122.88Msps
Please let me know if you need any additional information regarding my request.
Paul
Edit Notes
..[edited by: PaulJung at 2:45 AM (GMT -4) on 16 Jul 2024]
