C code Sequence for enabling the CFR , CLGC and DPD
Product Number: ADRV9029
Hi , We want to implement the CLGC for one of the project , is there C code for that along with CFR and DPD , if there is code base could you please share it.
R D Nadaf
Thread Notes
Top Replies
  • Hi,  We don't have C-code available. Please refer the attached scripts which could be of help for implementing CLGC, CFR and DPD.
    #GUI Version: 0.0.0.939
    #DLL Version: 0.0.0.857
    #Cmd Server Version: 0.0.0.857
    #FPGA Version: 0xD9000007
    #ARM Version: 0.0.0.503
    #StreamVersion: 0.0.0.73
    #Author: Anand Kumar
    #Precondition: Ensure that Tx-ORx mapping is completed and a valid external loopback path exists between Tx to ORx.
    #Description: This script is meant for standalone CLGC setup(without internal DPD).
    # This script runs the external path delay cal, external DPD init cal(to establish DPD actuator ownership) and initializes CLGC tracking cal
    #Note: To disable active Tx atten control and only monitor Tx and ORx power levels, a value of '0' needs to be passed to the clgcConfigSet() function (line 107)
    #Import Reference to the DLL
    import System
    import clr
    import time
    from System import Array
    clr.AddReferenceToFileAndPath("C:\\Program Files\\Analog Devices\\ADRV9025 Transceiver Evaluation Software_x64_FULL\\adrvtrx_dll.dll")
    from adrv9010_dll import AdiEvaluationSystem
    from adrv9010_dll import Types
    from adrv9010_dll import Ad9528Types
    from math import log10, sqrt
    def extPathDelayAndExtDpdInit():
        errorFlag = 0
        txCals = Types.adi_adrv9010_InitCals_t()
        txCals.calMask = int(Types.adi_adrv9010_InitCalibrations_e.ADI_ADRV9010_EXTERNAL_PATH_DELAY) | int(Types.adi_adrv9010_InitCalibrations_e.ADI_ADRV9010_DPD)
        txCals.channelMask = 0x1
        txCals.warmBoot = 0
        adrv9010.Cals.InitCalsRun(txCals)
        adrv9010.Cals.InitCalsWait(6000, errorFlag)
    def clgcStatusGet(txCh):
        print"*****************************CLGC Status, Tx = ",txCh
        clgcStatusRead = Types.adi_adrv9010_ClgcStatus_t()
        retVal = link.platform.board.Adrv9010Device.Dfe.ClgcStatusGet(txCh, clgcStatusRead)
        clgcStatusRead = retVal[1]
        MAX_CODE = 2**16
        updateCount = clgcStatusRead.clgcTrackingCalStatus.updateCount
        loopGain = clgcStatusRead.clgcLoopGain
        print "CLGC Loop Gain Est:",loopGain
        #print "CLGC Tx RMS Power:",clgcStatusRead.clgcTxRmsPower
        #print "CLGC Orx RMS Power:",clgcStatusRead.clgcOrxRmsPower
        if int(loopGain*100) != 0:
            print "CLGC Loop Gain Est_dB:",20*log10(float(loopGain))
            print "CLGC Tx RMS Power_dBFS:",20*log10(clgcStatusRead.clgcTxRmsPower/MAX_CODE)
            print "CLGC Orx RMS Power_dBFS:",20*log10(clgcStatusRead.clgcOrxRmsPower/MAX_CODE)
        print "CLGC errorCode:",clgcStatusRead.clgcTrackingCalStatus.errorCode
        print "CLGC activeTxAttenIndex_dB:",clgcStatusRead.activeTxAttenIndex*0.05
        print "CLGC activeOrxGainIndex:",clgcStatusRead.activeOrxGainIndex
        print "CLGC percentComplete:",clgcStatusRead.clgcTrackingCalStatus.percentComplete
        print "CLGC varianceMetric:",clgcStatusRead.clgcTrackingCalStatus.varianceMetric
        print "CLGC iterCount:",clgcStatusRead.clgcTrackingCalStatus.iterCount
        print "CLGC updateCount:",updateCount
        print "CLGC runState:",clgcStatusRead.clgcState
        print "CLGC captureStatus:",clgcStatusRead.clgcCaptureStatus
        print "CLGC Sync status =",clgcStatusRead.clgcSyncStatus
        return clgcStatusRead
    def clgcConfigSet(controlEnable = 0):
        print"***************************************"
        clgcConfigSetObj = Array.CreateInstance(Types.adi_adrv9010_ClgcConfig_t, 1)
        clgcConfigSetObj[0] = Types.adi_adrv9010_ClgcConfig_t()
        clgcConfigSetObj[0].txChannelMask = 0x0F;
        clgcConfigSetObj[0].clgcEnableGainControl = controlEnable
        clgcConfigSetObj[0].clgcExpectedLoopGain_dB = -0.5
        clgcConfigSetObj[0].clgcTxQualifyingThreshold_dBFS = -70;
        clgcConfigSetObj[0].clgcOrxQualifyingThreshold_dBFS = -70;
        clgcConfigSetObj[0].clgcMaxGainAdjustmentStepSize_dB = 3;
        clgcConfigSetObj[0].clgcDampingParam = 0.1;
        clgcConfigSetObj[0].clgcMinTxAttenAdjust_dB = 0;
        clgcConfigSetObj[0].clgcMaxTxAttenAdjust_dB = 30;
        clgcConfigSetObj[0].clgcExpectedLoopGainRipple_dB = 0.05;
        clgcConfigSetObj[0].clgcMaxSampleBatchesPerClgcRun = 512
        clgcConfigSetObj[0].clgcMeasurementBatchTime_us = 10
        clgcConfigSetObj[0].clgcOrxMinimumSnr_dB = 20
        link.platform.board.Adrv9010Device.Dfe.ClgcConfigSet(clgcConfigSetObj,1)
        print "CLGC Loop Gain(dB)",clgcConfigSetObj[0].clgcExpectedLoopGain_dB
        print "CLGC Tx qualifying threshold(dBFS)",clgcConfigSetObj[0].clgcTxQualifyingThreshold_dBFS
        print "CLGC ORx qualifying threshold(dBFS)",clgcConfigSetObj[0].clgcOrxQualifyingThreshold_dBFS
        print "CLGC Max gain adjustment step size",clgcConfigSetObj[0].clgcMaxGainAdjustmentStepSize_dB
        print "CLGC Damping Param", clgcConfigSetObj[0].clgcDampingParam
        print "Min Tx Atten(dB)",clgcConfigSetObj[0].clgcMinTxAttenAdjust_dB
        print "Max Tx Atten(dB)",clgcConfigSetObj[0].clgcMaxGainAdjustmentStepSize_dB
        print "Expected loop gain ripple(dB)",clgcConfigSetObj[0].clgcExpectedLoopGainRipple_dB
    def clgcTrackingCalEnable(enable = 0):
        if enable:
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX1_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX2_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX3_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX4_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
        else:
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX1_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX2_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX3_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX4_CLGC), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
    def clgcSetup():
        #link.platform.board.Adrv9010Device.RadioCtrl.RxTxEnableSet(0x00,0x01) #Enable Tx1, Disable other ORx channels
        #extPathDelayAndExtDpdInit() #Required if using CLGC with External DPD
        #clgcConfigSet(1) #1 - Enable loop gain control, 0- Disable loop gain control
        #clgcTrackingCalEnable(1) #1 - Enable CLGC tracking cal, 0 - Disable CLGC tracking cal
        #time.sleep(10)
        print "*********CLGC Status******************"
        clgcStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1)
    #Create an Instance of the Class
    link = AdiEvaluationSystem.Instance
    connect = False
    if (link.IsConnected() == False):
        connect = True
        link.platform.board.Client.Connect("192.168.1.10", 55556)
        print "Connecting"
    if (link.IsConnected()):
        adrv9010 = link.Adrv9010Get(1)
        print "Connected"
        ##### YOUR CODE GOES HERE #####
        clgcSetup()
    else:
        print "Not Connected"
    if (connect):
        link.platform.board.Client.Disconnect()
        print "Disconnected"
    #GUI Version: 5.1.0.30
    #DLL Version: 5.1.0.21
    #Cmd Server Version: 5.1.0.21
    #ARM Version: 5.1.0.9(ADI_ADRV9025_ARMBUILD_TESTOBJ)
    #StreamVersion: 8.1.0.1
    import System
    import clr
    import time
    ########################## HELPER FUNCTIONS #######################################
    def dpdStatusGet(txChannel):
        print "Retrieving DPD status"
        #dpdStatus = Types.adi_adrv9010_DpdStatus_t()
        dpdStatus = Types.adi_adrv9025_DpdStatusX_t()
        retVal = link.platform.board.Adrv9010Device.Dfe.DpdStatusGet(txChannel, dpdStatus)
        dpdStatus = retVal[1]
        print "dpdErrorCode:",dpdStatus.dpdErrorCode
        print "dpdPercentComplete",dpdStatus.dpdPercentComplete
        print "dpdPerformanceMetric",dpdStatus.dpdPerformanceMetric
        print "dpdIterCount",dpdStatus.dpdIterCount
        print "dpdUpdateCount",dpdStatus.dpdUpdateCount
        print "dpdSyncStatus",dpdStatus.dpdSyncStatus
        meanTu = dpdStatus.dpdStatistics.dpdMeanTuPower
        peakTu = dpdStatus.dpdStatistics.dpdPeakTuPower
        meanTx = dpdStatus.dpdStatistics.dpdMeanTxPower
        peakTx = dpdStatus.dpdStatistics.dpdPeakTxPower
        meanOrx = dpdStatus.dpdStatistics.dpdMeanOrxPower
        peakOrx = dpdStatus.dpdStatistics.dpdPeakOrxPower
        print "dpdModelTable",dpdStatus.dpdModelTable
        if int(meanTu*10 + peakTu*10 + meanTx*10 + peakTx*10 + meanOrx*10 + peakOrx*10) != 0:
            print "dpdMeanTuPower",20*log10(sqrt(meanTu) / 32768)
            print "dpdPeakTuPower",20*log10(sqrt(peakTu) / 32768)
            print "dpdMeanTxPower",20*log10(sqrt(meanTx) / 32768)
            print "dpdPeakTxPower",20*log10(sqrt(peakTx) / 32768)
            print "dpdMeanOrxPower",20*log10(sqrt(meanOrx) / 32768)
            print "dpdPeakOrxPower",20*log10(sqrt(peakOrx) / 32768)
        print "dpdDirectEvm",dpdStatus.dpdStatistics.dpdDirectEvm
        print "dpdIndirectEvm",dpdStatus.dpdStatistics.dpdIndirectEvm
        print "dpdSelectError",dpdStatus.dpdStatistics.dpdSelectError
        print "dpdIndirectError",dpdStatus.dpdStatistics.dpdIndirectError
        print "dpdErrorStatus0 (metrics:actions): X:X", dpdStatus.dpdErrorStatus0.dpdMetricsMask, dpdStatus.dpdErrorStatus0.dpdActionMask
        print "dpdErrorStatus1 (metrics:actions): X:X", dpdStatus.dpdErrorStatus1.dpdMetricsMask, dpdStatus.dpdErrorStatus1.dpdActionMask
        print "dpdPersistentErrorStatus0 (metrics:actions): X:X", dpdStatus.dpdPersistentErrorStatus0.dpdMetricsMask, dpdStatus.dpdPersistentErrorStatus0.dpdActionMask
        print "dpdPersistentErrorStatus1 (metrics:actions): X:X", dpdStatus.dpdPersistentErrorStatus1.dpdMetricsMask, dpdStatus.dpdPersistentErrorStatus1.dpdActionMask
        print "reservedPM",dpdStatus.reservedPM
        print "reservedTP",dpdStatus.reservedTP
        print "reservedPR",dpdStatus.reservedPR
    def dpdTrackingConfigSet( txChMask = 0x1):
        print"Setting up DPD Tracking Config"
        FULL_SCALE_CODE = 32768
        #Create a new instance of DPD tracking Config and read back values in the device
        dpdTrackCfg = Types.adi_adrv9025_DpdTrackingConfig_t()
        dpdTrackCfgGet = Types.adi_adrv9025_DpdTrackingConfig_t()
        retVal = link.platform.board.Adrv9010Device.Dfe.DpdTrackingConfigGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1,dpdTrackCfgGet)
        dpdTrackCfg = retVal[1]
        #Update DPD mode
        dpdTrackCfg.dpdUpdateMode =  Types.adi_adrv9010_DpdTrackingUpdateMode_e.ADI_ADRV9025_DPD_TRACKING_UPDATE_MODE_2
        #Update Peak search window and other params
        dpdTrackCfg.dpdPeakSearchWindowSize = 65535
        dpdTrackCfg.dpdIndirectRegularizationValue = 20
        dpdTrackCfg.dpdSamples = 16384
        dpdTrackCfg.dpdIndirectRegularizationLowPowerValue = 20
        dpdTrackCfg.dpdFilterSel = 1
        dpdTrackCfg.enableDirectLearning = 0
        dpdTrackCfg.dpdMu = 0
        #Update low power threshold
        DpdLowPowerThreshold_dBFS = -46
        dpdTrackCfg.minAvgSignalLevel = System.UInt16(pow(10,(DpdLowPowerThreshold_dBFS/20.0))*FULL_SCALE_CODE)
        #Update ORx low power threshold
        DpdLowPowerThresholdORx_dBFS = -36
        dpdTrackCfg.minAvgSignalLevelOrx = System.UInt16(pow(10,(DpdLowPowerThresholdORx_dBFS/20.0))*FULL_SCALE_CODE)
        #Convert M-Threshold in dBFS to linear scale
        MThreshold_dBFS = -40
        temp = pow(10,(MThreshold_dBFS/20.0))*FULL_SCALE_CODE
        dpdTrackCfg.dpdMThreshold = pow(temp,2)
        #Program the values
        dpdTrackCfg.txChannelMask = txChMask
        link.platform.board.Adrv9010Device.Dfe.DpdTrackingConfigSet(dpdTrackCfg)
        #Read back the programmed values
        print"DPD Tx Low Power Threshold(dBFS) = ",20*log10(dpdTrackCfg.minAvgSignalLevel/32768.0)
        print"DPD ORx Low Power Threshold(dBFS) = ",20*log10(dpdTrackCfg.minAvgSignalLevelOrx/32768.0)
        print"DPD M Threshold(dBFS) = ",20*log10(pow(dpdTrackCfg.dpdMThreshold,0.5)/32768.0)
        print"DPD Peak Search Window Size = ",dpdTrackCfg.dpdPeakSearchWindowSize
        print"DPD Regularization Value = ",dpdTrackCfg.dpdIndirectRegularizationValue
        print"DPD Samples = ",dpdTrackCfg.dpdSamples
        print"DPD Update Mode = ",dpdTrackCfg.dpdUpdateMode
        print " DPD Indirect Regularization Value LowPower", dpdTrackCfg.dpdIndirectRegularizationLowPowerValue
        print " dpdFilterSel", dpdTrackCfg.dpdFilterSel
        print "enableDirectLearning", dpdTrackCfg.enableDirectLearning
        print "dpdMu", dpdTrackCfg.dpdMu
    DPD_MODEL_FILE = "C:\\Ram\\model92.txt"
    #DPD_MODEL_FILE = "C:\\Users\\MVinod\\OneDrive - Analog Devices, Inc\\Documents\\customers\\IISC\\Gen3_95coefficients.txt"
    lut = Array.CreateInstance(Types.adi_adrv9010_DpdLut_e, 31)
    lut[0] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT0
    lut[1] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT1
    lut[2] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT2
    lut[3] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT3
    lut[4] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT4
    lut[5] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT5
    lut[6] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT6
    lut[7] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT7
    lut[8] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT8
    lut[9] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT9
    lut[10] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT10
    lut[11] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT11
    lut[12] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT12
    lut[13] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT13
    lut[14] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT14
    lut[15] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT15
    lut[16] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT16
    lut[17] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT17
    lut[18] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT18
    lut[19] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT19
    lut[20] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT20
    lut[21] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT21
    lut[22] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT22
    lut[23] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT23
    lut[24] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT24
    lut[25] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT25
    lut[26] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT26
    lut[27] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT27
    lut[28] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT28
    lut[29] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT29
    lut[30] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT30
    def dpdModelRestoreFromFile(fileName = DPD_MODEL_FILE):
        dpdModelRestore = Types.adi_adrv9025_DpdModelConfig_t();
        cnt = 0
        modelFile = open(fileName,'r')
        for line in modelFile:
            var = line.split()
            dpdModelRestore.dpdFeatures[cnt].i = System.Byte(var[0])
            dpdModelRestore.dpdFeatures[cnt].j = System.Byte(var[1])
            dpdModelRestore.dpdFeatures[cnt].k = System.Byte(var[2])
            dpdModelRestore.dpdFeatures[cnt].lut = lut[int(var[3])]
            dpdModelRestore.dpdFeatures[cnt].coeffReal = float(var[4])
            dpdModelRestore.dpdFeatures[cnt].coeffImaginary = float(var[5])
            cnt = cnt + 1
        modelFile.close
        print "Num coeffs read from file = ",cnt
        dpdModelRestore.dpdNumFeatures = cnt
        dpdModelRestore.txChannelMask = 0x0F
        link.platform.board.Adrv9010Device.Dfe.DpdModelConfigSet(dpdModelRestore)
        link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
        link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
        link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
        link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
    def resetDpdFull(TxChannel = 1):
        if TxChannel == 1:
            link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
        if TxChannel == 2:
            link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
        if TxChannel == 3:
            link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
        if TxChannel == 4:
            link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
    def runExtPathDelayInitCal(chMask):
        initCal = Types.adi_adrv9010_InitCals_t()
        initCal.calMask = int(Types.adi_adrv9010_InitCalibrations_e.ADI_ADRV9010_EXTERNAL_PATH_DELAY)
        initCal.channelMask = chMask
        initCal.warmBoot = 0
        print "calMask:", hex(initCal.calMask)
        link.platform.board.Adrv9010Device.Cals.InitCalsRun(initCal)
        print "Path delay cal blocking wait status:", link.platform.board.Adrv9010Device.Cals.InitCalsWait(3000, 0)[1]
    def getExtPathDelay(txCh):
        extPathDelay = Types.adi_adrv9010_ExternalPathDelay_t()
        retVal = link.platform.board.Adrv9010Device.Cals.ExternalPathDelayGet(txCh, extPathDelay)
        extPathDelay = retVal[1]
        print "fifoDelay:",extPathDelay.fifoDelay
        print "interpolationIndex:", extPathDelay.interpolationIndex
    def dpdTrackingCalEnable(enable = 1):
        print"***********************************"
        if(enable == 1):
            print"Enabling DPD Tracking Cal"
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX1_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX2_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX3_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX4_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
        else:
            print"Disabling DPD Tracking Cal"
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX1_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX2_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX3_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
            link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX4_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
    def spiRead(address):
        data = adrv9010.Hal.SpiByteRead(address, 0)
        print "SPI Read Address " + hex(address) + ": " + hex(data[1])
    def spiWrite(address, data):
        adrv9010.Hal.SpiByteWrite(address, data)
        print "SPI Write Address " + hex(address) + ": " + hex(data)
    connect = False
        connect = True
        link.platform.board.Client.Connect("192.168.1.90", 55556)
        print "Connecting"
        print "Connected"
        dpdModelRestoreFromFile()
        resetDpdFull(1)
        time.sleep(1)
        resetDpdFull(2)
        time.sleep(1)
        resetDpdFull(3)
        time.sleep(1)
        resetDpdFull(4)
        time.sleep(1)
        dpdTrackingConfigSet()
        runExtPathDelayInitCal(0xF)# Should be 0XF for enabling path delay all four Tx channel #Run 1st after loading signal-> PA on -> Settign Tx atten and ORx gain index
        time.sleep(1)
        getExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1) #Run 2nd to confirm extPathDelay ran fine
        time.sleep(1)
        getExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2) #Run 2nd to confirm extPathDelay ran fine
        time.sleep(1)
        getExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3) #Run 2nd to confirm extPathDelay ran fine
        time.sleep(1)
        getExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4) #Run 2nd to confirm extPathDelay ran fine
        dpdTrackingCalEnable(1) #Enable DPD tracking cal
        for i in range(1):
            time.sleep(2)
            print "TX1"
            dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1) #Read back DPD Status
            time.sleep(6)
            print "TX2"
            dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2) #Read back DPD Status
            time.sleep(6)
            print "TX3"
            dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3) #Read back DPD Status
            time.sleep(6)
            print "TX4"
            dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4) #Read back DPD Status
    else:
    if (connect):
    #GUI Version: 0.0.0.718
    #DLL Version: 0.0.0.670
    #Cmd Server Version: 0.0.0.670
    #ARM Version: 0.0.0.412(ADI_ADRV9025_ARMBUILD_TESTOBJ)
    #StreamVersion: 0.0.0.64
    import System
    import clr
    import time
    #clr.AddReferenceToFileAndPath("C:\\Program Files\\Analog Devices\\ADRV9025 Transceiver Evaluation Software_x64_FULL_eDPD_6P0\\adrvtrx_dll.dll")
    #CFR_CORRECTION_PULSE_FILENAME = "C:\\Users\\pvalavan\\Desktop\\CFR TEST COMMSCOPE\\Tok_Mad_CFR_Pulse_Generation\\correction pulse\\122P88_MSPS\\CFR PULSE\\LTE_5MHZ_122P88MSPS.txt"
    CFR_CORRECTION_PULSE_FILENAME = "C:\\Users\\RBitra\\Desktop\\CFR_Pulse_NR_5MHz_15kHz_122.88MSPS_1x.txt"
    def cfrCorrectionPulseLoadFromFile(fileName = ""):
        listRealCoeff = []
        listImgCoeff = []
        cnt = 0
        halfpulse = open(fileName,'r')
        for line in halfpulse:
            var = line.split()
            cnt = cnt + 1
            listRealCoeff.append(int(var[0]))
            listImgCoeff.append(int(var[1]))
        halfpulse.close
        cfrCorrectionPulse = Array.CreateInstance(Types.adi_adrv9010_CfrCorrectionPulse_t, 1)
        cfrCorrectionPulse[0] = Types.adi_adrv9010_CfrCorrectionPulse_t()
        numCoeff = 128
        cfrCorrectionPulse[0].coeffRealHalfPulse = System.Array[System.Int16](listRealCoeff)
        cfrCorrectionPulse[0].coeffImaginaryHalfPulse = System.Array[System.Int16](listImgCoeff)
        cfrCorrectionPulse[0].numCoeffs = numCoeff;
        link.platform.board.Adrv9010Device.Dfe.CfrCorrectionPulseWrite_v2(0xF,cfrCorrectionPulse,1)
    def cfrStatusGet(txCh):
        cfrStatusRead = Types.adi_adrv9010_CfrStatus_t()
        retVal = link.platform.board.Adrv9010Device.Dfe.CfrStatusGet(txCh, cfrStatusRead)
        if (retVal[0] != 0):
            print "CfrStatusGet failed, result =", retVal[0]
            return -1
        cfrStatusRead = retVal[1]
        print "cfrStatus:", cfrStatusRead.cfrErrorCode
        print "cfrEngine1PeaksDetected:",cfrStatusRead.cfrStatistics.cfrEngine1PeaksDetected
        print "cfrEngine1PeaksSkipped:",cfrStatusRead.cfrStatistics.cfrEngine1PeaksSkipped
        print "cfrEngine2PeaksDetected:",cfrStatusRead.cfrStatistics.cfrEngine2PeaksDetected
        print "cfrEngine2PeaksSkipped:",cfrStatusRead.cfrStatistics.cfrEngine2PeaksSkipped
        print "cfrEngine3PeaksDetected:",cfrStatusRead.cfrStatistics.cfrEngine3PeaksDetected
        print "cfrEngine3PeaksSkipped:",cfrStatusRead.cfrStatistics.cfrEngine3PeaksSkipped
        print "cfrNumSamplesClipped:",cfrStatusRead.cfrStatistics.cfrNumSamplesClipped
        retList = [cfrStatusRead.cfrErrorCode,cfrStatusRead.cfrStatistics.cfrNumSamplesClipped,
                   cfrStatusRead.cfrStatistics.cfrEngine1PeaksDetected,cfrStatusRead.cfrStatistics.cfrEngine1PeaksSkipped,
                   cfrStatusRead.cfrStatistics.cfrEngine2PeaksDetected,cfrStatusRead.cfrStatistics.cfrEngine2PeaksSkipped,
                   cfrStatusRead.cfrStatistics.cfrEngine3PeaksDetected,cfrStatusRead.cfrStatistics.cfrEngine3PeaksSkipped,
                   cfrStatusRead.cfrStatistics.cfrNumSamplesClipped]
        return cfrStatusRead, retList
    connect = False
        connect = True
        print "connect = True"
        print "Connecting"
        print "Connected"
        #adrv9010 = Link.Adrv9010Get(1)
         # cfrctrlConfigSet
        cfrCtrlCfg = Types.adi_adrv9010_CfrCtrlConfig_t()
        cfrCtrlCfg.txChannelMask = 0xF
        cfrCtrlCfg.cfrMode = Types.adi_adrv9010_CfrModeSel_e.ADI_ADRV9010_CFR_MODE1
        cfrCtrlCfg.cfrInterpolationFactor = Types.adi_adrv9010_CfrInterpolationSel_e.ADI_ADRV9010_CFR_INTERPOLATION_4X
        cfrCtrlCfg.cfrPeakThreshold =  0.55	#   Values based on -12dBFS RMS 0.5623 7.0dB, 0.5957 7.5dB; .6467 8.2dB
        cfrCtrlCfg.cfrTxDelay = 511  #same for all CFR engines
        cfrCtrlCfg.cfrEngine1MaxNumOfPeaks = 5 #Max Peaks per group
        cfrCtrlCfg.cfrEngine2MaxNumOfPeaks = 5
        cfrCtrlCfg.cfrEngine3MaxNumOfPeaks = 5
        cfrCtrlCfg.cfrCorrectionThresholdScaler = 0.98 #Default
        cfrCtrlCfg.cfrEngine1PeakThresholdScaler = 0.98 #default
        cfrCtrlCfg.cfrEngine2PeakThresholdScaler = 0.985 # default
        cfrCtrlCfg.cfrEngine3PeakThresholdScaler = 0.99 #default
        #CFR enable
        cfrEn = Types.adi_adrv9010_CfrEnable_t()
        cfrEn.txChannelMask = 0xF
        cfrEn.cfrEngine1Enable = 01
        cfrEn.cfrEngine1BypassEnable = 0
        cfrEn.cfrEngine2Enable = 01
        cfrEn.cfrEngine2BypassEnable = 0
        cfrEn.cfrEngine3Enable = 01
        cfrEn.cfrEngine3BypassEnable = 0
        cfrCtrlArray = Array.CreateInstance(Types.adi_adrv9010_CfrCtrlConfig_t, 1)
        cfrEnArray = Array.CreateInstance(Types.adi_adrv9010_CfrEnable_t, 1)
        cfrCtrlArray[0] = cfrCtrlCfg
        cfrEnArray[0] = cfrEn
        link.platform.board.Adrv9010Device.Dfe.CfrCtrlConfigSet(cfrCtrlArray, 1)
        link.platform.board.Adrv9010Device.Dfe.CfrEnableSet(cfrEnArray, 1)
        #Enable CFR hard clipper
        cfrHardClipperCfg = Types.adi_adrv9010_CfrHardClipperConfig_t()
        cfrHardClipperCfg.cfrHardClipperEnable = 1
        cfrHardClipperCfg.cfrHardClipperThreshold = 0.55
        cfrHardClipperCfg.txChannelMask = 0xF
        hcArray = Array.CreateInstance(Types.adi_adrv9010_CfrHardClipperConfig_t, 1)
        hcArray[0] = cfrHardClipperCfg
        link.platform.board.Adrv9010Device.Dfe.CfrHardClipperConfigSet(hcArray, 1)
        #CFR Correction Pulse Write
        cfrCorrectionPulseLoadFromFile(CFR_CORRECTION_PULSE_FILENAME)
        #Run CFR init cal
        initCal.calMask = int(Types.adi_adrv9010_InitCalibrations_e.ADI_ADRV9010_CFR_INIT)
        initCal.channelMask = 0x0F
        x = 0
        link.platform.board.Adrv9010Device.Cals.InitCalsWait(10000,x)
        time.sleep(10)
        cfrStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1)
        link.platform.board.Adrv9010Device.Dfe.CfrCtrlConfigGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1, cfrCtrlCfg)
        print cfrCtrlCfg.txChannelMask
        print cfrCtrlCfg.cfrMode
        print cfrCtrlCfg.cfrInterpolationFactor
        print cfrCtrlCfg.cfrPeakThreshold
        print cfrCtrlCfg.cfrTxDelay
        print  cfrCtrlCfg.cfrEngine1MaxNumOfPeaks
        print cfrCtrlCfg.cfrEngine2MaxNumOfPeaks
        print cfrCtrlCfg.cfrEngine3MaxNumOfPeaks
        print cfrCtrlCfg.cfrCorrectionThresholdScaler
        print cfrCtrlCfg.cfrEngine1PeakThresholdScaler
        print cfrCtrlCfg.cfrEngine2PeakThresholdScaler
        print cfrCtrlCfg.cfrEngine3PeakThresholdScaler
        link.platform.board.Adrv9010Device.Dfe.CfrEnableGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1, cfrEn)
        print cfrEn.txChannelMask
        print cfrEn.cfrEngine1Enable
        print cfrEn.cfrEngine1BypassEnable
        print cfrEn.cfrEngine2Enable
        print cfrEn.cfrEngine2BypassEnable
        print cfrEn.cfrEngine3Enable
        print cfrEn.cfrEngine3BypassEnable
    else:
    if (connect):
  • Hi Ramarao ,
    We did the changes for CLGC in the radio script , we followed the CLGC sequence mentioned in the document for ADRD9025  and all APIs are running properly with out any error but when u read the CLGC status , i am getting always zeros in CLGC status structure , as follows
    cd vyapiv3p1_AD9545+ADRV9025_Init_v0r0p1/
    root@Vyapi:~/vyapiv3p1_AD9545+ADRV9025_Init_v0r0p1# clear
    root@Vyapi:~/vyapiv3p1_AD9545+ADRV9025_Init_v0r0p1# cp radiolib_Clgc.so /lib/
    root@Vyapi:~/vyapiv3p1_AD9545+ADRV9025_Init_v0r0p1# chmod 777 EnableClgcMay3nd
    root@Vyapi:~/vyapiv3p1_AD9545+ADRV9025_Init_v0r0p1# ./EnableClgcMay3nd
    Rx lo Frequency in Hz : 880000000
    Tx lo Frequency in Hz : 925000000
    Orx lo Frequency in Hz : 925000000
    Tx attenuation : 10 dB
    Rx gain : 10 dB
    ORx gain : 25 dB
    Radio Pin control Mode :0(FDD)
    Powering Off the on board PAs and LNAs
    Devices reset is done
    Executing the adi_daughterboard_Discover
    Executing the adi_daughterboard_Create
    Executing the BoardDispatch Executing the adi_adrv9025Board_Dispatch
    if (actionFlags == TRX_BOARD_ACTION_DEVICE_ALLOC)
    Transceiver Vendor Id_0: 56
    Transceiver Vendor Id_1: 4
    Executing motherboard->daughterboards[0]->BoardProgram(motherboard->daughterboards[0])
    Resetting JESD
    JESD reset is done
    EXEC adrv9025_ClocksSet
    Loading stream image ...
    Stream Image firmware loaded successfully
    Loading ARM image ...
    ARM Image firmware loaded successfully
    Setting up the attenuation before doing calibration
    Setting up the gain before doing calibration
    ADI_NULL_DEVICE_PTR_RETURN
    ADI_FUNCTION_ENTRY_LOG
    ADI_NULL_PTR_RETURN
    adrv9025_InitCalStructureCheck = 0
    adi_adrv9025_CpuMemWrite = 0
    adi_adrv9025_CpuCmdWrite = 0
    ADI_NULL_PTR_RETURN
    adi_board_adrv9025_JesdBringup completed
    The Tx channel status :f
    The Rx channel status :f
    TX 1 Minimum Attenuation : 10000mdB
    TX 2 Minimum Attenuation : 10000mdB
    TX 3 Minimum Attenuation : 10000mdB
    TX 4 Minimum Attenuation : 10000mdB
    Orx 1 Minimum Gain : 25dB
    Orx 2 Minimum Gain : 25dB
    Orx 3 Minimum Gain : 25dB
    Orx 4 Minimum Gain : 25dB
    JESD reset is done
    Deframer 0 status : 87
    Framer 0 status : a
    Tx Lo Frequency :925000000
    Rx Lo Frequency :880000000
    TX2ORX mapping is successfulg=0
    adi_adrv9025_RxGainSet is successfulg=0
    Powering on the on board PAs and LNAs
    ADI_NULL_PTR_RETURN
    ADI_ADRV9025_EXTERNAL_PATH_DELAY is successfulg=0
    External path delay calibiration in CLGC Done = 0
    External path delay init cals Wait in CLGC Done = 0
    RUNNING LEAKAGE CALIB CLGC ADI_NULL_DEVICE_PTR_RETURN
    ADI_NULL_PTR_RETURN
    CLGC initial Calibirations are done
    ADI_NULL_PTR_RETURN
    CFR Parameters Readback:
    Tx Channel Mask:1
    cfrMode:0
    cfrTxDelay: 511
    cfrPeakThreshold:0.400000
    cfrEngine1PeakThresholdScaler:0.980000
    cfrEngine2PeakThresholdScaler:0.985000
    cfrEngine3PeakThresholdScaler:0.990000
    cfrCorrectionThresholdScaler:0.980000
    cfrInterpolationFactor:2
    cfrEngine1MaxNumOfPeaks:1
    cfrEngine2MaxNumOfPeaks:1
    cfrEngine3MaxNumOfPeaks:1
    CFR Enable Read:
    tx Channel Mask:1
    cfr Engine1 Enable:1
    cfr Engine1 Bypass Enable:0
    cfr Engine2 Enable:1
    cfr Engine2 Bypass Enable:0
    cfr Engine3 Enable:1
    cfr Engine3 Bypass Enable :0
    CFR HardClipper Readback:
    Tx Channel Mask:1
    CFR Hard Clipper Enable:1
    CFR Hard Clipper Threshold:0.399994
    CFR Status Readback:
    CFR_Error_Code:0
    cfr Engine1 Peaks Detected:15280
    cfr Engine1 Peaks Skipped: 4348
    cfr Engine2 Peaks Detected: 7741
    cfr Engine2 Peaks Skipped: 1613
    cfr Engine3 Peaks Detected: 4203
    cfr Engine3 Peaks Skipped: 721
    cfr NumSamples Clipped: 6693
    DPD programming is started
    adi_adrv9025_DpdModelConfigSet Done = 0
    resteDPDLutRestore Done = 0
    resteDPDFull Done = 0
    adi_adrv9025_DpdTrackingConfigSet Done = 0
    ADI_NULL_PTR_RETURN
    DPD adi_adrv9025_InitCalsRun Done = 0
    DPD adi_adrv9025_InitCalsWait Done = 0
    Setup DPD fault conditions and recovery actions(optional)
    Get the CLG STATUS
    CLGC status Read Successful
    adi_adrv9025_ClgcConfigSet Successful
    CLGC adi_adrv9025_TrackingCalsEnableSet successful
    CLGC DPP Tracking Calibiration is Successful = 0
    CLGC Enable CLGC tracking suuccessful
    dpdErrorCode :0x0
    dpdPercentComplete :0
    dpdPerformanceMetric :0
    dpdIterCount :8
    dpdUpdateCount :7
    dpdSyncStatus :4
    dpdModelTable :0
    dpdMeanTuPower :-13.531085
    dpdPeakTuPower :-7.596758
    dpdMeanTxPower :-13.536119
    dpdPeakTxPower :-7.602159
    dpdMeanOrxPower :-13.730960
    dpdPeakOrxPower :-7.766534
    dpdDirectEvm :0.008892
    dpdIndirectEvm :0.009472
    dpdSelectError :0.004946
    dpdIndirectError :0.004832
    dpdErrorStatus0 (metrics:actions): X:X :0:1
    dpdErrorStatus1 (metrics:actions) :0:0
    dpdPersistentErrorStatus0 (metrics:actions) :0:0
    dpdPersistentErrorStatus1 (metrics:actions) :0:0
    reservedPM :40240960
    reservedTP :42137458
    reservedPR :42137458
    Monitor DPD tracking calibration status Successful
    adi_adrv9025_ClgcConfigGet SUCCESS
    clgc_configFg_st.txChannelMask = 1
    clgc_configFg_st.clgcEnableGainControl = 1
    clgc_configFg_st.clgcMeasurementBatchTime_us = 10
    clgc_configFg_st.clgcMaxSampleBatchesPerClgcRun = 0
    clgc_configFg_st.clgcExpectedLoopGain_dB = -9.000000
    clgc_configFg_st.clgcExpectedLoopGainRipple_dB = 0.050000
    clgc_configFg_st.clgcTxQualifyingThreshold_dBFS = -70.000000
    clgc_configFg_st.clgcOrxQualifyingThreshold_dBFS = -70.000000
    clgc_configFg_st.clgcOrxMinimumSnr_dB = 0.000000
    clgc_configFg_st.clgcMaxGainAdjustmentStepSize_dB = 3.000000
    clgc_configFg_st.clgcDampingParam = 0.100000
    clgc_configFg_st.clgcMinTxAttenAdjust_dB = 5.000000
    clgc_configFg_st.clgcMaxTxAttenAdjust_dB = 30.000000
    Getting the CLGC status for the ADI_ADRV9025_TX1 = 0
    CLGC Status = 0
    clgc_coinfig_status[0].clgcLoopGain = 0.000000
    clgc_coinfig_status[0].clgcTxRmsPower = 0.000000
    clgc_coinfig_status[0].clgcOrxRmsPower = 0.000000
    clgc_coinfig_status[0].activeTxAttenIndex = 0
    clgc_coinfig_status[0].activeOrxGainIndex = 0
    clgc_coinfig_status[0].clgcCaptureStatus = 0
    clgc_coinfig_status[0].clgcSyncStatus = 0
    clgc_coinfig_status[0].clgcState = 0
    Radio initialized successfully.
    Can you please check and let me know if anything we need to take care further.
    R D Nadaf
