For the EVAL-ADRV9026/ADRV9029, why does the ADP1762ACPZ-1.0-R7 output 0V?
Product Number: ADRV9026 ADRV9029
Hi, ADI team:
    When i got the EVAL-ADRV9026/ADRV9029 board , powered up and then enabled the adp5056(VDDA1P3_AN outputed 1.3v; VDDA1P0 outputed 1.0v; VDDA1P8 outputed 1.8v; 3P3_CLOCK outputed 3.3v ). i found ,the ADP1762ACPZ-1.0-R7 outputed 0V.  Is it right?
    From the Schematics, it looks like that, after enable adp5056, the ADP1762ACPZ-1.0-R7 should output 1V.  But for my board ,the  ADP1762ACPZ-1.0-R7, always outputed 0V.
So my question is: After power up and enable the adp5056, does the  ADP1762ACPZ-1.0-R7 output 1V or 0V?
Thanks a lot!
Thread Notes
Ramarao - Moved from RF and Microwave to Design Support ADRV9026/ADRV9029. Post date updated from Friday, December 1, 2023 to Friday, December 1, 2023 to reflect the move.
  • So my question is: After power up and enable the adp5056, does the  ADP1762ACPZ-1.0-R7 output 1V or 0V?
    The voltage out from this chip must be 1V and this supply is being used for JESD related Pins.
    When you say enabled, are you trying to enable manually/ power up the regulators? Is it not a complate EVB setup- ADS9 + ADRV CE Board?
    If you have another Power board daughter card, can you check with that and let me know?
  • Thank you very much for your reply.
    ----.No, It is not ADS9+ADRV CE Board. I use a gpio to power up the regulators. My hardware platform is ZC706 (www.xilinx.com/.../ek-z7-zc706-g.html) EVAL-ADRV9026/ADRV9029. Enable adp5056 means that, a gpio (3.3v level) from ZC706 connects the net EN_ALL of ADP5056_PWR_BOARD. After the EN_ALL net gets a High Level, the VDDA1P3_AN outputs 1.3v; VDDA1P0 outputs 1.0v; VDDA1P8 outputs 1.8v; 3P3_CLOCK outputs 3.3v. but the adp1762 outputs 0v.
    So now , i have another question:
    if the adp1762 is broken, may i put the R119 on and remove R117 (that means that use vdd_1p0 to power  JESD related Pins )?
    Thanks a lot.
  • It looks like 1P0 should come from FPGA board through the FMC and it does not seem to be coming. Can you check why the 1P0 supply is not coming?
    If you are not able to drive this supply from FPGA board, you may need to enable the ADP1762 thats on the daughter power board.
