- i want to do DPD with 160 MHz and 200 MHz BW signal. for this i know the sampling rate should be more than 245.76 MHz. i am applying 122.88MHz clock to J6 PORT and load the profile which has 245.76 MHz TX/RX sampling rate. but i cant get good and expected results from DPD and as can be seen adjacent channel power increases in frequency domain which i think it links to sampling rate. would you please help me to do the proper DPD measurement with 200 MHz BW signal? actually when i am trying to apply external clock with 245.76 MHz frerquency, PLL doesnt lock and i could not program it, so i thought i should ONLY apply 122.88 MHz to J6 port. am i right? i am using this profile (49)
