10MHz Reference Input
Product Number: ADRV9026-MB/PCBZ
We have a running system using the ADRV9026-MB/PCBZ using an 122.88MHz reference clock on the J613. However, we'd like to use a 10MHz reference input instead. We are using the 90_nonLinkSharing profile. We tried modifying the ad9528InitInst as follows:
    ad9528InitInst.pllLockTimeout_ms = 1000;
    ad9528InitInst.pll1Settings.refA_Frequency_Hz = 10000000;
    ad9528InitInst.pll1Settings.refA_Divider = 125;
    ad9528InitInst.pll1Settings.vcxo_Frequency_Hz = 122880000;
    ad9528InitInst.pll1Settings.nDividerPll1 = 768;  // N1
    ad9528InitInst.pll2Settings.rfDivider = 3;       // M1
    ad9528InitInst.pll2Settings.n2Divider = 20;      // N2
    ad9528InitInst.pll2Settings.r1Divider = 2;       // R2
    ad9528InitInst.pll2Settings.totalNdiv =
        ad9528InitInst.pll2Settings.rfDivider * ad9528InitInst.pll2Settings.n2Divider;  // M1 * N2
    ad9528InitInst.sysrefSettings.sysrefDivide = 256;
However, the result is that the LO frequency is oscillating around 1kHz around the center frequency (with a period of around 1Hz), so it looks like the PLL1 / onboard VCXO of 122.88MHz is not locking properly.
Did you have any success in using a 10MHz reference clock instead of the 122.88MHz?
  • AD9528 generates Devclk for ADRV9029 and Refclk for FPGA which is integer multiples of Reference input. All our use cases are configured with multiples of 122.88MHz reference frequency. So, it is not recommended to use other than this.
    The performance may not be guaranteed with 10MHz reference, you can try 30.72MHz reference clock if it is ok for your design.
