ADRV9029
Recommended for New Designs
The ADRV9029 is a highly integrated, radio frequency (RF) agile transceiver offering four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9029 on Analog.com
ADRV9010
The ADRV9010 is a highly integrated, radio frequency (RF) agile transceiver that offers four independently controlled transmitters, dedicated observation...
Datasheet
ADRV9010 on Analog.com
We are implementing DPD with ADRV9029. We have taken the configuration parameters for DPD from the python script given below and implemented the same in c. The model file is taken form ADI Ezone. None for the API are getting failed and the error code in DPD status is also found to be 0 but we could see the configurations are not affecting. What can be issue ?
Is there any sample c code for DPD configuration ?
Thanks in advance.
#GUI Version: 5.1.0.30
#DLL Version: 5.1.0.21
#Cmd Server Version: 5.1.0.21
#FPGA Version: 0xD9000007
#ARM Version: 5.1.0.9(ADI_ADRV9025_ARMBUILD_TESTOBJ)
#StreamVersion: 8.1.0.1
#Import Reference to the DLL
import System
import clr
import time
from math import log10, sqrt
from System import Array
clr.AddReferenceToFileAndPath("C:\\Program Files\\Analog Devices\\ADRV9025 Transceiver Evaluation Software_x64_FULL\\adrvtrx_dll.dll")
from adrv9010_dll import AdiEvaluationSystem
from adrv9010_dll import Types
from adrv9010_dll import Ad9528Types
########################## HELPER FUNCTIONS #######################################
def dpdStatusGet(txChannel):
print"***************************************"
print "Retrieving DPD status"
#dpdStatus = Types.adi_adrv9010_DpdStatus_t()
dpdStatus = Types.adi_adrv9025_DpdStatusX_t()
retVal = link.platform.board.Adrv9010Device.Dfe.DpdStatusGet(txChannel, dpdStatus)
dpdStatus = retVal[1]
print "dpdErrorCode:",dpdStatus.dpdErrorCode
print "dpdPercentComplete",dpdStatus.dpdPercentComplete
print "dpdPerformanceMetric",dpdStatus.dpdPerformanceMetric
print "dpdIterCount",dpdStatus.dpdIterCount
print "dpdUpdateCount",dpdStatus.dpdUpdateCount
print "dpdSyncStatus",dpdStatus.dpdSyncStatus
meanTu = dpdStatus.dpdStatistics.dpdMeanTuPower
peakTu = dpdStatus.dpdStatistics.dpdPeakTuPower
meanTx = dpdStatus.dpdStatistics.dpdMeanTxPower
peakTx = dpdStatus.dpdStatistics.dpdPeakTxPower
meanOrx = dpdStatus.dpdStatistics.dpdMeanOrxPower
peakOrx = dpdStatus.dpdStatistics.dpdPeakOrxPower
print "dpdModelTable",dpdStatus.dpdModelTable
if int(meanTu*10 + peakTu*10 + meanTx*10 + peakTx*10 + meanOrx*10 + peakOrx*10) != 0:
print "dpdMeanTuPower",20*log10(sqrt(meanTu) / 32768)
print "dpdPeakTuPower",20*log10(sqrt(peakTu) / 32768)
print "dpdMeanTxPower",20*log10(sqrt(meanTx) / 32768)
print "dpdPeakTxPower",20*log10(sqrt(peakTx) / 32768)
print "dpdMeanOrxPower",20*log10(sqrt(meanOrx) / 32768)
print "dpdPeakOrxPower",20*log10(sqrt(peakOrx) / 32768)
print "dpdDirectEvm",dpdStatus.dpdStatistics.dpdDirectEvm
print "dpdIndirectEvm",dpdStatus.dpdStatistics.dpdIndirectEvm
print "dpdSelectError",dpdStatus.dpdStatistics.dpdSelectError
print "dpdIndirectError",dpdStatus.dpdStatistics.dpdIndirectError
print "dpdErrorStatus0 (metrics:actions): X:X", dpdStatus.dpdErrorStatus0.dpdMetricsMask, dpdStatus.dpdErrorStatus0.dpdActionMask
print "dpdErrorStatus1 (metrics:actions): X:X", dpdStatus.dpdErrorStatus1.dpdMetricsMask, dpdStatus.dpdErrorStatus1.dpdActionMask
print "dpdPersistentErrorStatus0 (metrics:actions): X:X", dpdStatus.dpdPersistentErrorStatus0.dpdMetricsMask, dpdStatus.dpdPersistentErrorStatus0.dpdActionMask
print "dpdPersistentErrorStatus1 (metrics:actions): X:X", dpdStatus.dpdPersistentErrorStatus1.dpdMetricsMask, dpdStatus.dpdPersistentErrorStatus1.dpdActionMask
print "reservedPM",dpdStatus.reservedPM
print "reservedTP",dpdStatus.reservedTP
print "reservedPR",dpdStatus.reservedPR
def dpdTrackingConfigSet( txChMask = 0x1):
print"Setting up DPD Tracking Config"
FULL_SCALE_CODE = 32768
#Create a new instance of DPD tracking Config and read back values in the device
dpdTrackCfg = Types.adi_adrv9025_DpdTrackingConfig_t()
dpdTrackCfgGet = Types.adi_adrv9025_DpdTrackingConfig_t()
retVal = link.platform.board.Adrv9010Device.Dfe.DpdTrackingConfigGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1,dpdTrackCfgGet)
dpdTrackCfg = retVal[1]
#Update DPD mode
dpdTrackCfg.dpdUpdateMode = Types.adi_adrv9010_DpdTrackingUpdateMode_e.ADI_ADRV9025_DPD_TRACKING_UPDATE_MODE_2
#Update Peak search window and other params
dpdTrackCfg.dpdPeakSearchWindowSize = 65535
dpdTrackCfg.dpdIndirectRegularizationValue = 20
dpdTrackCfg.dpdSamples = 16384
dpdTrackCfg.dpdIndirectRegularizationLowPowerValue = 20
dpdTrackCfg.dpdFilterSel = 1
dpdTrackCfg.enableDirectLearning = 0
dpdTrackCfg.dpdMu = 0
#Update low power threshold
DpdLowPowerThreshold_dBFS = -46
dpdTrackCfg.minAvgSignalLevel = System.UInt16(pow(10,(DpdLowPowerThreshold_dBFS/20.0))*FULL_SCALE_CODE)
#Update ORx low power threshold
DpdLowPowerThresholdORx_dBFS = -36
dpdTrackCfg.minAvgSignalLevelOrx = System.UInt16(pow(10,(DpdLowPowerThresholdORx_dBFS/20.0))*FULL_SCALE_CODE)
#Convert M-Threshold in dBFS to linear scale
MThreshold_dBFS = -40
temp = pow(10,(MThreshold_dBFS/20.0))*FULL_SCALE_CODE
dpdTrackCfg.dpdMThreshold = pow(temp,2)
#Program the values
dpdTrackCfg.txChannelMask = txChMask
link.platform.board.Adrv9010Device.Dfe.DpdTrackingConfigSet(dpdTrackCfg)
#Read back the programmed values
print"DPD Tx Low Power Threshold(dBFS) = ",20*log10(dpdTrackCfg.minAvgSignalLevel/32768.0)
print"DPD ORx Low Power Threshold(dBFS) = ",20*log10(dpdTrackCfg.minAvgSignalLevelOrx/32768.0)
print"DPD M Threshold(dBFS) = ",20*log10(pow(dpdTrackCfg.dpdMThreshold,0.5)/32768.0)
print"DPD Peak Search Window Size = ",dpdTrackCfg.dpdPeakSearchWindowSize
print"DPD Regularization Value = ",dpdTrackCfg.dpdIndirectRegularizationValue
print"DPD Samples = ",dpdTrackCfg.dpdSamples
print"DPD Update Mode = ",dpdTrackCfg.dpdUpdateMode
print " DPD Indirect Regularization Value LowPower", dpdTrackCfg.dpdIndirectRegularizationLowPowerValue
print " dpdFilterSel", dpdTrackCfg.dpdFilterSel
print "enableDirectLearning", dpdTrackCfg.enableDirectLearning
print "dpdMu", dpdTrackCfg.dpdMu
DPD_MODEL_FILE = "C:\\Users\\pvalavan\\Desktop\\DFE\\DPD TESTING\\ADRV9025_4txDPD_TESTING\\DPD_Model\\Gen3_95coefficients.txt"
lut = Array.CreateInstance(Types.adi_adrv9010_DpdLut_e, 31)
lut[0] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT0
lut[1] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT1
lut[2] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT2
lut[3] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT3
lut[4] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT4
lut[5] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT5
lut[6] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT6
lut[7] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT7
lut[8] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT8
lut[9] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT9
lut[10] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT10
lut[11] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT11
lut[12] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT12
lut[13] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT13
lut[14] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT14
lut[15] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT15
lut[16] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT16
lut[17] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT17
lut[18] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT18
lut[19] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT19
lut[20] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT20
lut[21] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT21
lut[22] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT22
lut[23] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT23
lut[24] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT24
lut[25] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT25
lut[26] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT26
lut[27] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT27
lut[28] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT28
lut[29] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT29
lut[30] = Types.adi_adrv9010_DpdLut_e.ADI_ADRV9010_DPD_LUT30
def dpdModelRestoreFromFile(fileName = DPD_MODEL_FILE):
dpdModelRestore = Types.adi_adrv9025_DpdModelConfig_t();
cnt = 0
modelFile = open(fileName,'r')
for line in modelFile:
var = line.split()
dpdModelRestore.dpdFeatures[cnt].i = System.Byte(var[0])
dpdModelRestore.dpdFeatures[cnt].j = System.Byte(var[1])
dpdModelRestore.dpdFeatures[cnt].k = System.Byte(var[2])
dpdModelRestore.dpdFeatures[cnt].lut = lut[int(var[3])]
dpdModelRestore.dpdFeatures[cnt].coeffReal = float(var[4])
dpdModelRestore.dpdFeatures[cnt].coeffImaginary = float(var[5])
cnt = cnt + 1
modelFile.close
print "Num coeffs read from file = ",cnt
dpdModelRestore.dpdNumFeatures = cnt
dpdModelRestore.txChannelMask = 0x0F
link.platform.board.Adrv9010Device.Dfe.DpdModelConfigSet(dpdModelRestore)
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4, Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9025_DPD_LUT_RESTORE)
def resetDpdFull(TxChannel = 1):
if TxChannel == 1:
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
if TxChannel == 2:
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
if TxChannel == 3:
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
if TxChannel == 4:
link.platform.board.Adrv9010Device.Dfe.DpdReset(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4,Types.adi_adrv9010_DpdResetMode_e.ADI_ADRV9010_DPD_RESET_FULL)
def runExtPathDelayInitCal(chMask):
initCal = Types.adi_adrv9010_InitCals_t()
initCal.calMask = int(Types.adi_adrv9010_InitCalibrations_e.ADI_ADRV9010_EXTERNAL_PATH_DELAY)
initCal.channelMask = chMask
initCal.warmBoot = 0
print "calMask:", hex(initCal.calMask)
link.platform.board.Adrv9010Device.Cals.InitCalsRun(initCal)
print "Path delay cal blocking wait status:", link.platform.board.Adrv9010Device.Cals.InitCalsWait(3000, 0)[1]
def getExtPathDelay(txCh):
extPathDelay = Types.adi_adrv9010_ExternalPathDelay_t()
retVal = link.platform.board.Adrv9010Device.Cals.ExternalPathDelayGet(txCh, extPathDelay)
extPathDelay = retVal[1]
print "fifoDelay:",extPathDelay.fifoDelay
print "interpolationIndex:", extPathDelay.interpolationIndex
def dpdTrackingCalEnable(enable = 1):
print"***********************************"
if(enable == 1):
print"Enabling DPD Tracking Cal"
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX1_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX2_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX3_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX4_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_ENABLE)
else:
print"Disabling DPD Tracking Cal"
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX1_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX2_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX3_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
link.platform.board.Adrv9010Device.Cals.TrackingCalsEnableSet(int(Types.adi_adrv9010_TrackingCalibrations_e.ADI_ADRV9010_TRACK_TX4_DPD), Types.adi_adrv9010_TrackingCalEnableDisable_e.ADI_ADRV9010_TRACKING_CAL_DISABLE)
def spiRead(address):
data = adrv9010.Hal.SpiByteRead(address, 0)
print "SPI Read Address " + hex(address) + ": " + hex(data[1])
def spiWrite(address, data):
adrv9010.Hal.SpiByteWrite(address, data)
print "SPI Write Address " + hex(address) + ": " + hex(data)
#Create an Instance of the Class
link = AdiEvaluationSystem.Instance
connect = False
if (link.IsConnected() == False):
connect = True
link.platform.board.Client.Connect("192.168.1.10", 55556)
print "Connecting"
if (link.IsConnected()):
adrv9010 = link.Adrv9010Get(1)
print "Connected"
##### YOUR CODE GOES HERE #####
dpdModelRestoreFromFile()
resetDpdFull(1)
dpdTrackingConfigSet()
runExtPathDelayInitCal(0x1)# Should be 0XF for enabling path delay all four Tx channel #Run 1st after loading signal-> PA on -> Settign Tx atten and ORx gain index
time.sleep(1)
getExtPathDelay(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1) #Run 2nd to confirm extPathDelay ran fine
dpdTrackingCalEnable(1) #Enable DPD tracking cal
time.sleep(10)
print "TX1"
dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX1) #Read back DPD Status
print "TX2"
dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX2) #Read back DPD Status
print "TX3"
dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX3) #Read back DPD Status
print "TX4"
dpdStatusGet(Types.adi_adrv9010_TxChannels_e.ADI_ADRV9010_TX4) #Read back DPD Status
else:
print "Not Connected"
if (connect):
link.platform.board.Client.Disconnect()
print "Disconnected"
Can you please make sure that you are executing the external path delay cal?
Please make sure that you are executing the DpdReset with ADI_ADRV9025_DPD_LUT_RESTORE after executing DpdModelConfigSet().
cnt = 0
var = line.split()
cnt = cnt + 1
modelFile.close
We don't have any sample "C" code.
Hi
Thanks for your reply.
We are executing all the APIs that you have mentioned in last post but still there is no change. Here I am attaching the main.c file where we have implemented DPD. Can you please help us finding where we are going wrong.
This is the current DPD status and for dpdStatistics also all the values are found to be 0.
* \file main.c
* \brief Contains extern declarations for adrv9025 data structures initializations
* ADRV9025 API Version: 5.1.0.21
* Copyright 2015 - 2018 Analog Devices Inc.
* Released under the ADRV9025 API license, for more information
* see the "LICENSE.txt" file in this zip file.
#include <stdio.h>
#include <unistd.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include <getopt.h>
#include <math.h>
#include "string.h"
#include "adi_platform.h"
#include "adi_adrv9025_daughter_board.h"
#include "adi_adrv9025_utilities.h"
#include "adi_adrv9025.h"
#include "adi_adrv9025_radioctrl.h"
#include "adi_adrv9025_tx.h"
#include "adi_common_error.h"
#include "adi_fpga9025.h"
#include "adi_ad9528.h"
#include "initdata.h"
#include "platform_utils/adi_fmc_fru.h"
#include "platform_utils/adi_fmc_eeprom.h"
#include "daughterboards/adi_daughterboard_trx_types.h"
#include "motherboards/adi_motherboard_trx.h"
#include "adi_adrv9025_dfe_types.h"
#include "adi_adrv9025_dfe.h"
#define PROGNAME "adrv9029Init"
#define PROGVERSION 1
#define DPD_MODEL_FILENAME "Gen3_95coefficients.txt"
void lws_enable_gpio();
static void help(void);
static void version(void);
adi_motherboard_trx_t *motherboard = NULL;
#if 0
adi_adrv9025_DpdLut_e lut_var;
unsigned int lut_t [31] = {0};
//adi_adrv9025_DpdLut_e lut_t = {31};
//adi_adrv9025_CfrCtrlConfig_t CfrCtrlConfig = {0};
lut_t[0] = (int) ADI_ADRV9025_DPD_LUT0;
lut_t[1] = ADI_ADRV9025_DPD_LUT1;
lut_t[2] = ADI_ADRV9025_DPD_LUT2;
lut_t[3] = ADI_ADRV9025_DPD_LUT3;
lut_t[4] = ADI_ADRV9025_DPD_LUT4;
lut_t[5] = ADI_ADRV9025_DPD_LUT5;
lut_t[6] = ADI_ADRV9025_DPD_LUT6;
lut_t[7] = ADI_ADRV9025_DPD_LUT7;
lut_t[8] = ADI_ADRV9025_DPD_LUT8;
lut_t[9] = ADI_ADRV9025_DPD_LUT9;
lut_t[10] = ADI_ADRV9025_DPD_LUT10;
lut_t[11] = ADI_ADRV9025_DPD_LUT11;
lut_t[12] = ADI_ADRV9025_DPD_LUT12;
lut_t[13] = ADI_ADRV9025_DPD_LUT13;
lut_t[14] = ADI_ADRV9025_DPD_LUT14;
lut_t[15] = ADI_ADRV9025_DPD_LUT15;
lut_t[16] = ADI_ADRV9025_DPD_LUT16;
lut_t[17] = ADI_ADRV9025_DPD_LUT17;
lut_t[18] = ADI_ADRV9025_DPD_LUT18;
lut_t[19] = ADI_ADRV9025_DPD_LUT19;
lut_t[20] = ADI_ADRV9025_DPD_LUT20;
lut_t[21] = ADI_ADRV9025_DPD_LUT21;
lut_t[22] = ADI_ADRV9025_DPD_LUT22;
lut_t[23] = ADI_ADRV9025_DPD_LUT23;
lut_t[24] = ADI_ADRV9025_DPD_LUT24;
lut_t[25] = ADI_ADRV9025_DPD_LUT25;
lut_t[26] = ADI_ADRV9025_DPD_LUT26;
lut_t[27] = ADI_ADRV9025_DPD_LUT27;
lut_t[28] = ADI_ADRV9025_DPD_LUT28;
lut_t[29] = ADI_ADRV9025_DPD_LUT29;
lut_t[30] = ADI_ADRV9025_DPD_LUT30;
#endif
/* If Json file used for profile then set to 1
* if structure initialization taken from "initdata.c" then set to 0*/
#define USE_JSON_FILE 0
static adi_fpga9025_Init_t fpga9025DeviceInitInst = { { { 0 } } };
static adi_ad9528_Init_t ad9528InitInst = { { 0 } };
adi_adrv9025_StreamSettings_t streamSettingsInst = { 0 };
///* Platfrom files settings */
static adi_adrv9025_PlatformFiles_t platformFiles = { {"./resources/adrv9025/arm_firmware/ADRV9025_FW.bin;./resources/adrv9025/arm_firmware/ADRV9025_DPDCORE_FW.bin"},
{"./resources/adrv9025/arm_firmware/stream_image_A9A69F235992D2096E93E82C75508C29.bin"},
{ {{"./resources/adrv9025/gain_tables/RxGainTable.csv"}, 0xFF} },
1,
{ {{"./resources/adrv9025/gain_tables/TxAttenTable.csv"}, 0x0F} },
1};
static int32_t adi_adrv9025_EnableTxExample (adi_adrv9025_Device_t *device)
int32_t recoveryAction = 0;
if (device == NULL)
printf("NULL ADRV9025 device pointer\n");
return -1;
/* Setup internal Tx test tone frequency */
adi_adrv9025_TxTestToneCfg_t toneCfg = { 0 };
toneCfg.txChannelMask = ADI_ADRV9025_TXALL;
toneCfg.txToneFreq_Hz = 5000000;
toneCfg.txToneGain = ADI_ADRV9025_TX_NCO_0_DB;
toneCfg.enable = 1;
recoveryAction = adi_adrv9025_TxTestToneSet(device, &toneCfg, 1);
if (recoveryAction != ADI_COMMON_ACT_NO_ACTION)
printf("Failed to setup ADRV9025 Tx Test Tone\n");
printf("ERROR: Error number %d, Recovery action %d. In file %s, in function %s, in line %d, variable name %s. Error message %s.\n",
device->common.error.errCode,
device->common.error.newAction,
device->common.error.errFile,
device->common.error.errFunc,
device->common.error.errLine,
device->common.error.varName,
device->common.error.errormessage);
/* Call action handler */
return ADI_COMMON_ACT_ERR_RESET_FULL;
adi_adrv9025_TxAtten_t txAtten = { 0 };
txAtten.txChannelMask = ADI_ADRV9025_TXALL;
txAtten.txAttenuation_mdB = 25000; /* Back off Tx output power by 30dB */
recoveryAction = adi_adrv9025_TxAttenSet(device, &txAtten, 1);
printf("Failed to set ADRV9025 Tx Attenuation\n");
/* Enable Tx1 output : NOTE, make sure transmitter outputs are 50 ohm terminated or risk
* possible damage to Tx output
recoveryAction = adi_adrv9025_RxTxEnableSet(device, 0, ADI_ADRV9025_TXALL);
printf("Failed to enable ADRV9025 Tx RF output\n");
return 0;
void dpdModelRestoreFromFile (adi_adrv9025_Device_t *device )
printf("Inside cfrCorrectionPulseLoadFromFile function\n");
adi_adrv9025_DpdModelConfig_t dpdModelRestore;
FILE* fd;
fd = fopen (DPD_MODEL_FILENAME, "r");
if (fd == NULL )
printf("Can't DPD Model file name file\n");
fclose (fd);
exit(0);
int i = 0; /*!< Memory term of the DPD feature */
int j = 0; /*!< Cross term of the DPD feature */
int k = 0; /*!< Power term of the DPD feature */
//uint8_t i = 0; /*!< Memory term of the DPD feature */
//uint8_t j = 0; /*!< Cross term of the DPD feature */
//uint8_t k = 0; /*!< Power term of the DPD feature */
int lutparam = 0; /*!< Target LUT index for this feature. Valid values are LUT0 - LUT30 */
float coeffReal = 0; /*!< Real part of the complex co-efficient for this feature */
float coeffImaginary = 0;
//int coeffReal = 0; /*!< Real part of the complex co-efficient for this feature */
//int coeffImaginary = 0;
int cnt = 0;
while (!feof (fd))
//while (cnt < 95)
//while ( fscanf (fd, "%d %d %d %d %f %f", &i, &j, &k, &lutparam, &coeffReal, &coeffImaginary) == 6 )
fscanf (fd, "%d %d %d %d %f %f", &i, &j, &k, &lutparam, &coeffReal, &coeffImaginary);
printf("mode: %d %d %d %d %f %f\n",i, j, k, lutparam, coeffReal, coeffImaginary);
dpdModelRestore.dpdFeatures[cnt].i = i;
dpdModelRestore.dpdFeatures[cnt].j = j;
dpdModelRestore.dpdFeatures[cnt].k = k;
//dpdModelRestore.dpdFeatures[cnt].lut = lut_t[lutparam];
dpdModelRestore.dpdFeatures[cnt].lut = lutparam;
dpdModelRestore.dpdFeatures[cnt].coeffReal = coeffReal;
dpdModelRestore.dpdFeatures[cnt].coeffImaginary = coeffImaginary;
cnt = cnt + 1;
if (cnt == 95)
break;
fclose (fd);
printf("Num coeffs read from file = %d",cnt);
//cnt = 95;
dpdModelRestore.dpdNumFeatures = cnt;
dpdModelRestore.txChannelMask = 0x0F;
recoveryAction = adi_adrv9025_DpdModelConfigSet( device, &dpdModelRestore);
printf("Failed to setup ADRV9025 CFR HARDCLIPPER\n");
//return ADI_COMMON_ACT_ERR_RESET_FULL;
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX1, ADI_ADRV9025_DPD_LUT_RESTORE);
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX2, ADI_ADRV9025_DPD_LUT_RESTORE);
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX3, ADI_ADRV9025_DPD_LUT_RESTORE);
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX4, ADI_ADRV9025_DPD_LUT_RESTORE);
void resetDpdFull(adi_adrv9025_Device_t *device, int TxChannel)
if (TxChannel == 1)
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX1, ADI_ADRV9025_DPD_RESET_FULL);
if (TxChannel == 2)
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX2, ADI_ADRV9025_DPD_RESET_FULL);
if (TxChannel == 3)
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX3, ADI_ADRV9025_DPD_RESET_FULL);
if (TxChannel == 4)
adi_adrv9025_DpdReset(device, ADI_ADRV9025_TX4, ADI_ADRV9025_DPD_RESET_FULL);
void dpdTrackingConfigSet (adi_adrv9025_Device_t *device, uint32_t txChMask)
printf("Setting up dpd tracking config\n");
printf("\n***************************************\n");
int FULL_SCALE_CODE = 32768;
//Create a new instance of DPD tracking Config and read back values in the device
adi_adrv9025_DpdTrackingConfig_t dpdTrackCfg;
adi_adrv9025_DpdTrackingConfig_t dpdTrackCfgGet1;
adi_adrv9025_DpdTrackingConfigGet (device, ADI_ADRV9025_TX1, &dpdTrackCfgGet1);
//Update DPD mode
dpdTrackCfg.dpdUpdateMode = ADI_ADRV9025_DPD_TRACKING_UPDATE_MODE_2;
//Update Peak search window and other params
dpdTrackCfg.dpdPeakSearchWindowSize = 65535;
dpdTrackCfg.dpdIndirectRegularizationValue = 20;
dpdTrackCfg.dpdSamples = 16384;
dpdTrackCfg.dpdIndirectRegularizationLowPowerValue = 20;
dpdTrackCfg.dpdFilterSel = 1;
dpdTrackCfg.enableDirectLearning = 0;
dpdTrackCfg.dpdMu = 0;
//Update low power threshold
int DpdLowPowerThreshold_dBFS = -46;
dpdTrackCfg.minAvgSignalLevel = (uint16_t) ( (pow (10, (DpdLowPowerThreshold_dBFS/20.0) ) ) *FULL_SCALE_CODE);
printf (" dpdTrackCfg.minAvgSignalLevel = %d\n",dpdTrackCfg.minAvgSignalLevel);
//Update ORx low power threshold
int DpdLowPowerThresholdORx_dBFS = -36;
dpdTrackCfg.minAvgSignalLevelOrx = (uint16_t) ( (pow (10, (DpdLowPowerThresholdORx_dBFS/20.0) ) ) *FULL_SCALE_CODE);
printf (" dpdTrackCfg.minAvgSignalLevelOrx = %d\n",dpdTrackCfg.minAvgSignalLevelOrx);
//Convert M-Threshold in dBFS to linear scale
int MThreshold_dBFS = -40;
int temp = pow(10,(MThreshold_dBFS/20.0))*FULL_SCALE_CODE;
dpdTrackCfg.dpdMThreshold = pow(temp,2);
printf (" dpdTrackCfg.dpdMThreshold = %d\n",dpdTrackCfg.dpdMThreshold);
//Program the values
dpdTrackCfg.txChannelMask = txChMask;
recoveryAction = adi_adrv9025_DpdTrackingConfigSet(device, &dpdTrackCfg);
printf("Failed to setup DpdTrackingConfigSet \n");
//Read back the programmed values
adi_adrv9025_DpdTrackingConfig_t dpdTrackCfgGet;
recoveryAction = adi_adrv9025_DpdTrackingConfigGet(device, txChMask, &dpdTrackCfgGet);
//dpdTrackCfg = retVal[1];
printf("DPD Tx Low Power Threshold(dBFS) = %d\n",( 20 * ( log10(dpdTrackCfg.minAvgSignalLevel/32768.0) ) ) );
printf("DPD ORx Low Power Threshold(dBFS) = %d\n",( 20 * ( log10(dpdTrackCfg.minAvgSignalLevelOrx/32768.0) ) ) );
printf("DPD M Threshold(dBFS) = %d\n",( 20 * ( log10(pow(dpdTrackCfg.dpdMThreshold,0.5)/32768.0) ) ) );
printf("DPD Peak Search Window Size = %d\n",dpdTrackCfg.dpdPeakSearchWindowSize);
printf("DPD Regularization Value = %d\n",dpdTrackCfg.dpdIndirectRegularizationValue);
printf("DPD Samples = %d\n",dpdTrackCfg.dpdSamples);
printf("DPD Update Mode = %d\n",dpdTrackCfg.dpdUpdateMode);
printf("DPD Indirect Regularization Value LowPower = %d\n", dpdTrackCfg.dpdIndirectRegularizationLowPowerValue);
printf("dpdFilterSel = %d\n", dpdTrackCfg.dpdFilterSel);
printf("enableDirectLearning = %d\n", dpdTrackCfg.enableDirectLearning);
printf("dpdMu = %d\n", dpdTrackCfg.dpdMu);
printf("DPD Tx Low Power Threshold(dBFS) = %d\n", dpdTrackCfgGet.minAvgSignalLevel );
printf("DPD ORx Low Power Threshold(dBFS) = %d\n", dpdTrackCfgGet.minAvgSignalLevelOrx);
printf("DPD M Threshold(dBFS) = %d\n", dpdTrackCfgGet.dpdMThreshold);
printf("DPD Peak Search Window Size = %d\n", dpdTrackCfgGet.dpdPeakSearchWindowSize);
printf("DPD Regularization Value = %d\n", dpdTrackCfgGet.dpdIndirectRegularizationValue);
printf("DPD Samples = %d\n", dpdTrackCfgGet.dpdSamples);
printf("DPD Update Mode = %d\n", dpdTrackCfgGet.dpdUpdateMode);
printf("DPD Indirect Regularization Value LowPower = %d\n", dpdTrackCfgGet.dpdIndirectRegularizationLowPowerValue);
printf("dpdFilterSel = %d\n", dpdTrackCfgGet.dpdFilterSel);
printf("enableDirectLearning = %d\n", dpdTrackCfgGet.enableDirectLearning);
printf("dpdMu = %d\n", dpdTrackCfgGet.dpdMu);
void runExtPathDelayInitCal ( adi_adrv9025_Device_t *device, uint32_t chMask)
//adi_adrv9025_InitCals_t dpdcal = {0};
adi_adrv9025_InitCals_t dpdcal ;
dpdcal.calMask = ADI_ADRV9025_EXTERNAL_PATH_DELAY;
dpdcal.channelMask = chMask;
dpdcal.warmBoot = 0;
recoveryAction = adi_adrv9025_InitCalsRun (device, &dpdcal);
printf("Failed to setup ADRV9025 dpd Run Init cals\n");
uint8_t errFlags;
recoveryAction = adi_adrv9025_InitCalsWait (device, 3000, &errFlags);
printf("Failed to setup ADRV9025 dpd wait init cals \n");
void getExtPathDelay (adi_adrv9025_Device_t *device, uint32_t txCh)
adi_adrv9025_ExternalPathDelay_t extPathDelay;
recoveryAction = adi_adrv9025_ExternalPathDelayGet (device, txCh, &extPathDelay);
printf("Failed to getExtPathDelay\n");
printf ("fifoDelay :%d\n",extPathDelay.fifoDelay);
printf ("interpolationIndex :%d\n", extPathDelay.interpolationIndex);
void dpdTrackingCalEnable (adi_adrv9025_Device_t *device, int enable )
printf("***********************************\n");
if(enable == 1){
printf("Enabling DPD Tracking Cal\n");
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX1_DPD, ADI_ADRV9025_TRACKING_CAL_ENABLE);
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX2_DPD, ADI_ADRV9025_TRACKING_CAL_ENABLE);
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX3_DPD, ADI_ADRV9025_TRACKING_CAL_ENABLE);
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX4_DPD, ADI_ADRV9025_TRACKING_CAL_ENABLE);
else{
printf("Disabling DPD Tracking Cal\n");
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX1_DPD, ADI_ADRV9025_TRACKING_CAL_DISABLE);
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX2_DPD, ADI_ADRV9025_TRACKING_CAL_DISABLE);
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX3_DPD, ADI_ADRV9025_TRACKING_CAL_DISABLE);
adi_adrv9025_TrackingCalsEnableSet (device, ADI_ADRV9025_TRACK_TX4_DPD, ADI_ADRV9025_TRACKING_CAL_DISABLE);
printf("***********************************");
void dpdStatusGet( adi_adrv9025_Device_t *device, uint32_t txChannel)
printf("***************************************\n");
printf ("Retrieving DPD status\n");
//dpdStatus = Types.adi_adrv9010_DpdStatus_t()
//dpdStatus = Types.adi_adrv9025_DpdStatusX_t()
adi_adrv9025_DpdStatus_t dpdStatus;
recoveryAction = adi_adrv9025_DpdStatusGet (device, txChannel, &dpdStatus);
printf ("dpdErrorCode :0x%x\n",dpdStatus.dpdErrorCode);
printf ("dpdPercentComplete :%d\n",dpdStatus.dpdPercentComplete);
printf ("dpdPerformanceMetric :%d\n",dpdStatus.dpdPerformanceMetric);
printf ("dpdIterCount :%d\n",dpdStatus.dpdIterCount);
printf ("dpdUpdateCount :%d\n",dpdStatus.dpdUpdateCount);
printf ("dpdSyncStatus :%d\n",dpdStatus.dpdSyncStatus);
float meanTu = dpdStatus.dpdStatistics.dpdMeanTuPower;
float peakTu = dpdStatus.dpdStatistics.dpdPeakTuPower;
float meanTx = dpdStatus.dpdStatistics.dpdMeanTxPower;
float peakTx = dpdStatus.dpdStatistics.dpdPeakTxPower;
float meanOrx = dpdStatus.dpdStatistics.dpdMeanOrxPower;
float peakOrx = dpdStatus.dpdStatistics.dpdPeakOrxPower;
printf ("dpdModelTable :%d\n",dpdStatus.dpdModelTable);
if (((int)(meanTu*10 + peakTu*10 + meanTx*10 + peakTx*10 + meanOrx*10 + peakOrx*10)) != 0)
printf ("dpdMeanTuPower :%f\n",20*log10(sqrt(meanTu) / 32768));
printf ("dpdPeakTuPower :%f\n",(20*log10(sqrt(peakTu) / 32768)));
printf ("dpdMeanTxPower :%f\n",(20*log10(sqrt(meanTx) / 32768)));
printf ("dpdPeakTxPower :%f\n",20*log10(sqrt(peakTx) / 32768));
printf ("dpdMeanOrxPower :%f\n",20*log10(sqrt(meanOrx) / 32768));
printf ("dpdPeakOrxPower :%f\n",20*log10(sqrt(peakOrx) / 32768));
printf ("dpdDirectEvm :%f\n",dpdStatus.dpdStatistics.dpdDirectEvm);
printf ("dpdIndirectEvm :%f\n",dpdStatus.dpdStatistics.dpdIndirectEvm);
printf ("dpdSelectError :%f\n",dpdStatus.dpdStatistics.dpdSelectError);
printf ("dpdIndirectError :%f\n",dpdStatus.dpdStatistics.dpdIndirectError);
printf ("dpdErrorStatus0 (metrics:actions): X:X :%d:%d\n", dpdStatus.dpdErrorStatus0.dpdMetricsMask,
dpdStatus.dpdErrorStatus0.dpdActionMask);
printf ("dpdErrorStatus1 (metrics:actions) :%d:%d\n", dpdStatus.dpdErrorStatus1.dpdMetricsMask,
dpdStatus.dpdErrorStatus1.dpdActionMask);
printf ("dpdPersistentErrorStatus0 (metrics:actions) :%d:%d\n", dpdStatus.dpdPersistentErrorStatus0.dpdMetricsMask,
dpdStatus.dpdPersistentErrorStatus0.dpdActionMask);
printf ("dpdPersistentErrorStatus1 (metrics:actions) :%d:%d\n", dpdStatus.dpdPersistentErrorStatus1.dpdMetricsMask,
dpdStatus.dpdPersistentErrorStatus1.dpdActionMask);
printf ("reservedPM :%d\n",dpdStatus.reservedPM);
printf ("reservedTP :%d\n",dpdStatus.reservedTP);
printf ("reservedPR :%d\n",dpdStatus.reservedPR);
printf ("***************************************\n");
#define dpdInitMain main
int dpdInitMain()
int c;
adi_adrv9025_Device_t *device = NULL;
adi_fpga9025_Device_t *fpga9025Device = NULL;
adi_ad9528_Device_t *ad9528Device = NULL;
// Discover board and platform.
recoveryAction = adi_motherboard_Discover(&motherboard);
if ((recoveryAction != ADI_COMMON_HAL_OK) || (motherboard == NULL))
printf("ERROR: adi_Motherboard_Discover has failed.\n");
lws_enable_gpio();
// Discover daughterboard.
recoveryAction = adi_daughterboard_Discover(motherboard);
printf("ERROR: ERPC-SERVER: %s:%u has failed.\n", __func__, __LINE__);
return (-1);
recoveryAction = adi_motherboard_SaveInfo(motherboard, (uintptr_t)&adrv9025InitInst, TRX_PLATFORM_DATA_SAVE_TRX_SETTING_INIT);
if (recoveryAction != ADI_COMMON_HAL_OK)
printf("ERROR: CMD-SERVER: %s:%u has failed.\n", __func__, __LINE__);
return (-1);
recoveryAction = adi_motherboard_SaveInfo(motherboard, (uintptr_t)&adrv9025PostMcsInitInst, TRX_PLATFORM_DATA_SAVE_TRX_SETTING_POST_MCS);
return (-1);
recoveryAction = adi_motherboard_SaveInfo(motherboard, (uintptr_t)&ad9528InitInst, TRX_PLATFORM_DATA_SAVE_CLOCK_SETTING_INIT);
return (-1);
recoveryAction = adi_motherboard_SaveInfo(motherboard, (uintptr_t)&fpga9025DeviceInitInst, TRX_PLATFORM_DATA_SAVE_FPGA_SETTING_INIT);
return (-1);
recoveryAction = adi_motherboard_SaveInfo(motherboard, (uintptr_t)&platformFiles, TRX_PLATFORM_DATA_SAVE_TRX_SETTING_PLATFORM_FILES);
return (-1);
recoveryAction = adi_motherboard_SaveInfo(motherboard, (uintptr_t)&streamSettingsInst, TRX_PLATFORM_DATA_SAVE_STREAM_SETTING_INIT);
return (-1);
device = (adi_adrv9025_Device_t *) motherboard->daughterboards[0]->trxDevice;
//fpga9025Device = (adi_fpga9025_Device_t*) motherboard->daughterboards[0]->fpgaDevice;
ad9528Device = (adi_ad9528_Device_t *) motherboard->daughterboards[0]->clockDevice;
device->common.error.logEnable = 1;
//fpga9025Device->memoryPageSize = 0x10000000;
#if 0
if (USE_JSON_FILE)
if ((recoveryAction = adi_adrv9025_ConfigFileLoad(device, "/home/analog/adrv9025_c_example/resources/adrv9025/profiles/public/ADRV9025Init_StdUseCase13_nonLinkSharing.profile", &adrv9025InitInst)) != ADI_COMMON_ACT_NO_ACTION)
printf("Error loading the requested profile to ADRV9025 init");
else
/* ADRV9025 settings are used from initdata.c
* they are already loaded in adrv9025InitInst.
* Verify that the structure was generated for the same API */
adi_adrv9025_ApiVersion_t apiVersion;
recoveryAction = adi_adrv9025_ApiVersionGet(device, &apiVersion);
printf("ERROR: adi_adrv9025_ApiVersionGet has failed.\n");
if (initStructApiVersion.majorVer != apiVersion.majorVer || initStructApiVersion.minorVer != apiVersion.minorVer || initStructApiVersion.maintenanceVer != apiVersion.maintenanceVer || initStructApiVersion.buildVer != apiVersion.buildVer)
printf("ERROR: Device initialization structure in \"initdata.c\" was generated for API version %d.%d.%d.%d, but the detected version on the device is %d.%d.%d.%d.\n\n",
initStructApiVersion.majorVer, initStructApiVersion.minorVer, initStructApiVersion.maintenanceVer, initStructApiVersion.buildVer,
apiVersion.majorVer, apiVersion.minorVer, apiVersion.maintenanceVer, apiVersion.buildVer);
/* Init Ad9528 */
recoveryAction = motherboard->daughterboards[0]->ClockConfigure(
//ToDo: motherboard->daughterboards[0], (uintptr_t)&ad9528InitInst, adrv9010InitInst.clocks.deviceClock_kHz, 122880, 122880, adrv9010InitInst.clocks.deviceClock_kHz);
(uintptr_t) &ad9528InitInst,
245760,
122880,
30720,
245760);
return recoveryAction;
#endif
* Function will Program the devices
recoveryAction = motherboard->daughterboards[0]->BoardProgram(motherboard->daughterboards[0]);
printf("Failed to initialize ADRV9025 Board\n");
printf("ERROR: ADRV9025 Error number %d, Recovery action %d. In file %s, in function %s, in line %d, variable name %s. Error message %s.\n",
printf("ERROR: fpga9025Device Error number %d, Recovery action %d. In file %s, in function %s, in line %d, variable name %s. Error message %s.\n",
fpga9025Device->common.error.errCode,
fpga9025Device->common.error.newAction,
fpga9025Device->common.error.errFile,
fpga9025Device->common.error.errFunc,
fpga9025Device->common.error.errLine,
fpga9025Device->common.error.varName,
fpga9025Device->common.error.errormessage);
printf("ERROR: ad9528Device Error number %d, Recovery action %d. In file %s, in function %s, in line %d, variable name %s. Error message %s.\n",
ad9528Device->common.error.errCode,
ad9528Device->common.error.newAction,
ad9528Device->common.error.errFile,
ad9528Device->common.error.errFunc,
ad9528Device->common.error.errLine,
ad9528Device->common.error.varName,
ad9528Device->common.error.errormessage);
printf("\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\n");
printf("Configuring DPD model restore from file\n");
dpdModelRestoreFromFile (device);
printf("Resetting DPD full\n");
resetDpdFull (device, 1);
printf("Programming DPD tracking config set\n");
dpdTrackingConfigSet (device, ADI_ADRV9025_TX1);
/*Should be 0XF for enabling path delay all four Tx channel
#Run 1st after loading signal-> PA on -> Settign Tx atten and ORx gain index */
printf("Programming runExtPathDelayInitCal \n");
runExtPathDelayInitCal (device, 1);
printf("Programming getExtPathDelay \n");
getExtPathDelay (device, ADI_ADRV9025_TX1); //Run 2nd to confirm extPathDelay ran fine
printf("Programming dpdTrackingCalEnable\n");
dpdTrackingCalEnable (device, 1); //Enable DPD tracking cal
printf("Programming dpdStatusGet\n");
printf ("TX1\n");
dpdStatusGet (device, ADI_ADRV9025_TX1); //Read back DPD Status
#if 0
printf ("TX2\n");
dpdStatusGet (ADRV9025_TX2); //Read back DPD Status
printf ("TX3\n");
dpdStatusGet(ADRV9025_TX3); //Read back DPD Status
printf ("TX4\n");
dpdStatusGet(ADRV9025_TX4); //Read back DPD Status
#endif
recoveryAction = motherboard->Destroy(motherboard);
motherboard = NULL;
printf("Failed to destroy motherboard and daughterboard\n");
printf("ADRV9026 initialized successfully\n");
Are you using pin control mode or API mode enabling/disabling Tx channel?
Can you please readback and check whether the Tx path is enabled are not?
adi_adrv9025_RxTxEnableGet()
If Tx channels are not enabled try enabling the Tx channels using
adi_adrv9025_RxTxEnableSet()
Readback the ORX Channel enabled/disabled using
If ORX channels are enabled, disable all ORX channel using adi_adrv9025_RxTxEnableSet().
After enabling DPD, when you transmit baseband signal are you able to see ADRV9025 Tx output in spectrum analyzer? Can you please share Tx output spectrum?
What is the power level input of ORX?
Can you please read the power of ORX with adi_adrv9025_RxDecPowerGet()?
If above steps are not helping, Please share the full log for the ADRV9025 with log level set to 255.
Hi
Thanks for your quick response.
We are having separate individual scripts for initialisation of ADRV9029, CFR and DPD. And our sequence of initialisation is as below.
1 - Initialising ADRV9029 and transmitting base band signal.
2- Initialising CFR.
3- Initialising DPD.
We are using API mode to enable tx path and all the tx and rx channels are enabled. We are not enabling ORX channels. Here I am attaching the adi_adrv9025_RxTxEnableGet() status. I have attached the log files as well.
After Initialising ADRV9029 and transmitting baseband signal, Tx output image:
After initialising DPD Tx output image:
It is -22.168 dBm.
Are you still reading the DPD statistics as zero?
Are you able to read back the DPDConfigGet and DPD Model file correctly?
One thing i could see from your "DPD C" code is that after enabling the DPD tracking cal, you are directly reading the DPD status. Can you please add some delay (few sec) and try?
Please refer below delay numbers from python script,
time.sleep(10)
print "TX1"
Also i could see few CFR related instance in the code, Please check.
Yes Still I am reading the DPD statistics as 0.
Yes I am able to read back the DPDConfigGet and DPD model file correctly.
Tried adding delay of 10 sec after dpdTrackingCalEnable but it did not help.
Please ignore this as these are some prints mistake.
In the previous post you have asked to disable the ORX . Are you sure we should disable ORX channels while testing DPD ? Or there is some kind of confusion. Can you please clarify on the same because I can adi_adrv9025_RxDecPowerGet() is getting failed saying error message as below
Thanks !
While testing DPD we recommend to disable the ORX Path. Before enabling DPD you can enable ORX path and measure ORXDecpower if required.
While DPD tracking cal is executing the DPD status will be reporting the ORX power. User need not to try measuring ORX power using adi_adrv9025_RxDecPowerGet().
Are you able to Run Ext_LoL init calibration?.
I hope you are using TX1 and ORX1 channels in your custom board.
Can you please read back and share the adi_adrv9025_TxToOrxMappingGet() API response?
Are you seeing this issue on all Tx channels?
Please make sure that you are following the below programming sequence for enabling DPD,
