May we put a metalic enclosure above the ADRV9009 ?
The distance (in Z direction) between the ADRV9009 case and the metalic enclosure is 1mm.
The ADRV9009 performance should remain the same ?
Thanks
ADRV9009
Recommended for New Designs
The ADRV9009 is a highly integrated, radio frequency (RF), agile transceiver offering dual transmitters and receivers, integrated synthesizers, and digital...
Datasheet
ADRV9009 on Analog.com
Thanks
Moved thread to design support for ADRV9009.
It should not disturb performance .
Why do you want to design a shield which has only 1mm gap?
We need a metal cover above our PCB (for EMC) .
The mechanical configuration constrains the cover to be 1mm above the ADRV9009.
